Old Feb 21, 2005, 01:30 AM
Jetset is offline
Find More Posts by Jetset
Jetset's Avatar
Kingston, Canada
Joined Mar 2002
Question
Mousse can muffler with stock muffler
Just curious, has anyone added a mousse can muffler to their engine with the stock muffler on it as well? I was think of how I could quiet my .32 heli engine even more so I wanted to see if anyone has ever added a mousse can muffler to an existing stock engine/muffler set up.
Myles
Jetset is offline Find More Posts by Jetset
Old Feb 22, 2005, 01:52 PM
Sport Flyer is offline
Find More Posts by Sport Flyer
Hi ya! Car ride!?
Sport Flyer's Avatar
Portage La Prairie, Manitoba Canada
Joined Sep 2003
My brother used to fly at a field with very strict sound requirements for 2 stroke glow engines. He would regularly add a mouse can muffler as an aftermuffler to his engines and it did work quite well. There will, however be a slight power
loss.
Sport Flyer is offline Find More Posts by Sport Flyer
Old Feb 22, 2005, 04:50 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Yes. They work well in tandem. And old fuel tank with random holes drilled in it works well too as an after muffler.
Once you put on an effective silencer, prop noise becomes much more of a factor. Prop noise is directly proportional to prop tip speed. To slow down prop tips without losing power, switch to a three bladed prop with one inch less diameter than your normal two blader. The engine will turn it at the same rpm but the smaller diameter means less tip speed and hence less noise. Not applicable to helis of course, just a general comment...
Whn you've done that, the next most significant area of noise is from the air intake. This can be silenced by an air filter and is something that works well on helis. Again, a little power loss, but that's better than losing a flying field.
DaveSawers is offline Find More Posts by DaveSawers
Old Feb 22, 2005, 05:09 PM
Jetset is offline
Jetset's Avatar
Kingston, Canada
Joined Mar 2002
Hmm, thanks for those comments guys. I think I will try one out see what the outcome is.
DaveSawers,
Are you talking just a normal nylon fuel tank like a Sullivan?
Myles
Old Feb 22, 2005, 06:49 PM
Joined Oct 1999
Originally Posted by Jetset
DaveSawers,
Myles
Yes. The advantage of the non rigid walls is that the tank "breathes" with the pressure pulses from the exhaust, reducing the resonance you can sometime get from a thin walled metal after muffler.
It doesn't look at all elegant but it is effective.
Discussion mousse can muffler? chase4556 Fuel Plane Talk 3 Sep 06, 2006 10:16 PM
Sold O.S. .46FX with Mousse Can Muffler DTB Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 14, 2006 10:51 AM
TZ30 Mousse Can Muffler sharkyZA Fuel Heli Talk 8 Jun 01, 2005 08:10 AM
mousse can muffler sizing rcsoar4fun Engines 4 Oct 16, 2004 07:19 PM
Macs Header with Mousse can muffler for a .46 Steve H. Aircraft - Fuel - Airplanes (FS/W) 1 Oct 03, 2004 09:32 PM
