Old Feb 20, 2005, 11:01 AM
wrenwright is offline
Find More Posts by wrenwright
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Futaba "J" connectors vs. JR-type connectors
What is the difference between Hitec HS-81 servos with a Futaba "J" connector and the ones with the JR-type plug?
The guy at the LHS sold me some Hitec 81's that are JR's, but I'm using them with a GWS Rx and a Futaba Tx.
Is the only difference that the Futaba J-style have the locator tab on the plug?
Seems like JR-type servos will plug into the Futaba Rx, but not the other way around.
Will I be ok using these with a GWS Rx and Futaba radio?
Thanks.
wrenwright is offline Find More Posts by wrenwright
Old Feb 20, 2005, 11:04 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
The keying tab on the Futaba J, and the fact that the corners are beveled on the JR, are the only difference. You will have no problem, but will have to pay attention to keying orientation.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Feb 20, 2005, 11:16 AM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
OK I thought the servos themselves were the same. I have to check the wire orientation on the GWS Rx anyway, so that's not a problem.
I suppose JR brand servos could be used on a Futaba Rx, but not the other way around then?
Old Feb 20, 2005, 02:12 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
JR, Hitec, and new Airtronics plugs can be universaly used. Futaba plugs must be modified to fit most other receivers, unless they are without hard cases.
Bill
ebill3 is offline Find More Posts by ebill3
Old Feb 21, 2005, 02:42 AM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Ebill3,
Well, that pic you posted cleared up everything!
Thanks.
Wren
Discussion Futaba F9C super VS JR 9XII pkpichit Fuel Heli Talk 2 Feb 25, 2007 06:04 AM
Futaba 9z WC2 vs. JR 9303 oakman7004 Radios 7 Nov 10, 2005 03:54 AM
Sourcing JR/Futaba J Connectors Smokey Rotor DIY Electronics 15 Jun 08, 2004 04:47 AM
JR or Futaba Gear Connectors Tarpon Shawn Beginner Training Area (Aircraft-Electric) 5 Sep 24, 2002 01:29 PM
