Old May 09, 2008, 10:57 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Here's what might work.
1. Cut a small slit at the bottom of the bubble.
2. Fill the void with glue or WBPU.
3. Starting at the top of the bubble, squeegee the air/glue mixture out toward the bottom. The trapped air and extra glue will flow out of the slit.
4. Surface tension should hold the silkspan in place until the glue dries.
Well, at least it sounds good on paper.
jetcaptain is offline Find More Posts by jetcaptain
Old May 09, 2008, 11:00 PM
J Morgan is online now
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
It's sure worth a try over repainting! The slits will still show some but will look better than the bubbles. I'll let you know how it works.
J
J Morgan is online now Find More Posts by J Morgan
Old May 09, 2008, 11:05 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Congrat GOK on the maiden and that is a very nice video too. It's a wonderful flying design isn't it.
J
Old May 09, 2008, 11:16 PM
jetcaptain's Avatar
Joined Jul 2006
Good Luck Sir J.
Old May 10, 2008, 04:41 AM
electriceye is offline
Find More Posts by electriceye
Kiss the Sky
electriceye's Avatar
Dorking, Surrey, UK
Joined Jul 2006
Originally Posted by GOK
Finally I maidened my F-16 as well. FANTASTIC flyer!
I don't think a maiden could get any better than this.
GOK
Congrats GOK, great looking F-16, great maiden!! I have said it before but no harm saying again, it is, in my opinion one of the finest foamie pusher jet designs.
electriceye is offline Find More Posts by electriceye
Old May 10, 2008, 05:21 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Hey Gok, just watched your video. Well done!! That looks awesome in the air. You need to find a nice soft landing spot! Ouch!
aerophilia is offline Find More Posts by aerophilia
Old May 10, 2008, 12:44 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks JC
We'll get this, somethings just take time.
Here's a sitrep on the progress. I cut off the old mount. Installed the stick mount. CN knows I don't like stick mounts. Pain to get straight, very hard I think to change thrustlines once they are glued in. Anyway, it's in, motor mounted and everythings a go.....except. I wonder if I should leave some room around it like the one pic shows( had to cut out the opening because of the lower motor off the stick mount. Or use a balsa piece cut to fit closer?
I also wonder if part of the secret of the F-4E cooling is that the motor sticks out a ways like the pic shows? If so I'll have to cut and splice a longer piece in on the stick. See why I don't like stick mounts? I need to make a decision on this so I can try it again. But we have severe weather coming down on us again. So it might be awhile before I try it.
J
Old May 10, 2008, 01:24 PM
GotrekGurnisson is offline
Find More Posts by GotrekGurnisson
It's a trap!
GotrekGurnisson's Avatar
Brisbane, Australia
Joined Feb 2006
J you have the engine intake closed off to house the battery don't you? Having that open to some degree to pipe some air in to the motor would seem like the best option to me. Can you run some ducting back to the motor from there?
Lol yeah. I was wondering why he didn't land on the grass in the background rather than the gravel.
GotrekGurnisson is offline Find More Posts by GotrekGurnisson
Old May 10, 2008, 01:29 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
J, you realy got to get that motor out in the air, there will never be enough going throu the fuse to keep them cool. Unless you open the tail pipe completly.
The whole in back has to be bigger than than the whole in front.
Tom
62pilot is offline Find More Posts by 62pilot
Old May 10, 2008, 02:23 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hey John,
Yes it does help to have it sticking out a bit. Convection cooling is a big part of it. If it is behind the cowl, it recieves no benefit of the cool air around it. When it is behind the cowl it's like being in an oven
rvincent is offline Find More Posts by rvincent
Old May 10, 2008, 05:44 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Well, here is what I wound up with. It is almost exactly the same as the F-4E. CN and I talked about it and decided too much air might be back pressure too thereby reducing circulation. So I closed( taped) the upper openings shut and extended the motor stick to get her out there.
J
Old May 10, 2008, 05:58 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
That looks great J!
Now I think we need to try changing your ESC setting too I like these on mine;
No Brake
Soft cut off
Auto Lipo
Hard start or Fast start
timing is tough because every Castle Firmware version is different! Try high timing, and read your watt meter, then low timing and read your watt meter. If the motor stitters on low timing, you have no choice but to use high timing. Also check it through the entire throttle range to be sure it is smooth. Sometimes low timing with newer firmware version will cause a motor stutter at 1/2 throttle. Basically the best timing setting will be the one that allows smooth running and lowest watt reading
I personally have found that an "OLD" firmware version 1.13 works the best, but I have not played with the newest after 1.54. Let me know what you end up with. I like the way it looks back there no I think that will do it!
Old May 10, 2008, 06:03 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Just to clarify something really quick, I have found that higher timing can often lead to higher amps with no real gain in performance. Many times as many as 5 amps for only 500 rpm's
Old May 10, 2008, 06:07 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I sent you an e-mail on settings. Check it please when you have time.
J
Old May 10, 2008, 06:08 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Ignore that, I missed your previous post! sheesh. Hands work before the brain does!
J
Fan Fold F-16 Falcon Tim H. Foamies (Kits) 21 Feb 16, 2009 06:51 PM
NIB Ripmax F-16 Falcon for sale jra111 Aircraft - Electric - Airplanes (FS/W) 1 May 22, 2003 11:40 AM
F-16 Falcon Flying Styro kit on EBAY, Cheap! Arthur_GA Aircraft - Electric - Airplanes (FS/W) 0 May 01, 2003 04:11 PM
F S Falcon flycracker Aircraft - Electric - Airplanes (FS/W) 1 Feb 23, 2003 12:46 PM
im looking for some good f-16c cross sections... i-fly Power Systems 1 Oct 21, 2001 02:54 PM
