Old Feb 19, 2005, 08:21 AM
xzd is online now
xzd
Find More Posts by xzd
xzd
Joined Jul 2004
200+WATTS from an 88.5g Lead-acid battery!
Anyone who have tried it?
http://www.gpbatteries.com.hk/pic/100TMFSC_TDS.pdf
xzd is online now Find More Posts by xzd
Old Feb 19, 2005, 08:44 AM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
On the surface they sem heavy and low capacity, however, they also put out about 50% more volts under load than a nimh would, and have the ability to handle high currents.
I would think that 6 of these would be roughly the equivilent volts under load as a 9 cell gp3300, and weigh a bit less, but have much less capacity under load, 0.6 amp hours instead of 3.3.
I doubt if they would be much use for e-flight, but if they're cheap enough, maybe could make up a field power source from them?
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Feb 19, 2005, 08:48 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
It can't be a traditional lead acid battery because its nominal voltage is 2V/cell. Lead acid voltage is 1.5V/cell. If there's a single cell in that can, there must be some new chemistry here.
If they're seriously suggesting that you can discharge it at 500A and that it will survive 1000A for short periods, there's defininitely something new here.
It's not April Fools Day in China today is it?
DaveSawers is offline Find More Posts by DaveSawers
Old Feb 19, 2005, 08:54 AM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
Traditional lead acid is 2V/cell.
M Ashmore is offline Find More Posts by M Ashmore
Old Feb 19, 2005, 09:53 AM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
Every VRLA lead acid battery has 2 volts/cell voltage. Any 12V battery is made of 2v cells.
However usually the short circuit current is above 1000A only for batteries larger than 15-20 Ah weighting more than 6 kg.
50A is usually nothing for a lead acid batteries but it is virtually impossible to have 1Ah for less than 300g. Herebelow are some of the best (highest density) lead battery and the smallest 8Ah still weights 2.7 kg.
http://www.enersysreservepower.com/d...S_001_0103.pdf
So they would have managed to increase 3 folds the energy density as well as reducing the internal resistance. But still that yields less energy than a single GP2200 or 3300 (up to about 140A @ +/- 0.75 V) with more weight and about 5 times less capacity. So not too interesting for us.
Maybe for an embarked glow batt in a glow plane!
Protocooler is offline Find More Posts by Protocooler
Question How many charges from a 4AH sealed lead-acid battery ? borgs Batteries and Chargers 18 Feb 25, 2003 04:55 AM
Another lead/acid battery question Tony Oliver Batteries and Chargers 4 Jun 24, 2002 04:40 PM
Lead acid battery charging domlou Power Systems 6 Jun 20, 2002 01:00 PM
charging a lead acid battery cenman Power Systems 6 Feb 24, 2002 10:10 PM
Running charger on mains with 'car charger' and 12V lead acid battery? Ben C Power Systems 7 Jun 08, 2001 08:56 PM
