Old Feb 18, 2005, 06:11 PM
wwkayaker1252@yahoo.com
Guest
n/a Posts
Great Planes Super Sportster EP
Has anyone else flown the Super Sportster EP. I flew mine for the first
time last weekend and let me say, WOW! This is one great flying bird. I
only have one concern. The ESC that came with the plane momentarily
applies brakes to the prop when the throttle is pulled all the way
back. This doesn't affect the handling of the plane but I'm afraid I'll
strip the plastic gear in the gear box. Anyone know of a possible
solution to this??
Thanks and have fun flying !!!
Double Ace
Double Ace
Guest
n/a Posts
Re: Great Planes Super Sportster EP
My guess is that it is the same controller that is used in the Great
Planes Spectra ARF which has a folding prop. The brake is used to stop
the prop so that it can fold along the fuseage sides thus reducing
drag. You are right, the braking action puts a lot of load on the
gearbox.
The Super Sportster EP is a heck of deal at $120. Comes with Motor,
controller, and 2100 mah battery.
first
I
I'll
> solution to this??
Old Mar 02, 2005, 12:45 PM
Haze_b is offline
Find More Posts by Haze_b
Haze_b's Avatar
Honolulu, Hi
Joined Feb 2005
I'm still waiting on mine. Should be here any day. Can't wait to build it and get it airborne.
Haze_b is offline Find More Posts by Haze_b
Old Oct 19, 2005, 01:47 AM
RCDuggiedug is offline
Find More Posts by RCDuggiedug
Dumb Thumbs
RCDuggiedug's Avatar
Virginia
Joined May 2003
Does anyone know if the ESC is 3 cell 11.1v LiPo capable?
RCDuggiedug is offline Find More Posts by RCDuggiedug
Old Oct 19, 2005, 02:18 PM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
What do you mean? Can handle 11.1 volts?
RC Flight Simulator
skirtz is offline Find More Posts by skirtz
Old Oct 19, 2005, 11:20 PM
Dumb Thumbs
Virginia
Joined May 2003
RC Flight Simulator
Just wanted to know if the ESC that came with the Super Sportster EP can handle 3 cell LiPo.
Old Oct 20, 2005, 10:11 AM
MK
MK
Guest
n/a Posts
By handle do you mean is the cut off voltage set so that it will not ruin a
3 cell LiPo? Are you asking about connectors?
Most ESCs will let you plug in a LiPo but the will let it run down below a
voltage level that won't ruin them. I do not know if you ESC you are asking
about is settable or set for a 3 cell LiPo.
mk
"RCDuggiedug" <RCDuggiedug.1x6q4b@rcgroups.com> wrote in message
news:RCDuggiedug.1x6q4b@rcgroups.com...
>> 'RC Flight Simulator' (http://rcflightsim.com)
> RCDuggiedug
> RCDuggiedug's Profile: http://www.rcgroups.com/forums/member.php?u=17447
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=337444
Old Oct 20, 2005, 12:11 PM
Robert A. Plourde Jr.
Guest
n/a Posts
You could use it but you will have to keep track of the voltage yourself.
It is not going to cut out at the proper voltage level for a 3 cell LiPo.
Here is a link to the info page. Note that this esc has been discontinued
in favor of a 35 amp LiPo compatible esc.
http://www2.towerhobbies.com/cgi-bin...?&I=LXUR96&P=7
Replacement esc that is LiPo compatible.
http://www2.towerhobbies.com/cgi-bin...?&I=LXKBF5&P=7
"RCDuggiedug" <RCDuggiedug.1x510b@rcgroups.com> wrote in message
news:RCDuggiedug.1x510b@rcgroups.com...
> RCDuggiedug
> Luv RC
Doug McLaren
Doug McLaren
Guest
n/a Posts
In article <UTO5f.1502$mV4.1115@dukeread02>,
Of course, by `LiPo compatible' you mean that either 1) the cutoff
voltage is configurable, or 2) it's default is appropriate for
whatever number of LiPo cells you're using.
Most ESCs that aren't adjustable cut off around 5-6 volts. For a two
cell LiPo pack, they'll usually work as is. Yes, 5 volts works out to
2.5 volts per cell, which is too low, but if the battery is under load
the voltage will drop a bit anyways.
In any event, you don't really _need_ an ESC that knows when to cut
off. Instead, it should be quite obvious to you when the batteries
are running out of juice -- the power will go way down first.
As long as you're paying attention and actually land the plane when
you notice that the power is going down, you'll not have any problems.
The only possible exception that I see is a motorized glider where you
may fly it far out and a loss of power may not be very noticable.
Doug McLaren, dougmc@frenzy.com
If ignorance is bliss, why aren't there more happy people in the world?
Old Jul 19, 2006, 09:46 PM
trensber is offline
Find More Posts by trensber
trensber
Joined Jul 2006
Anyone try a direct 2 cell replacement for the 7 cell nicad- stock motor, esc?
trensber is offline Find More Posts by trensber
Old Aug 20, 2006, 10:11 PM
Charle & Peggy Robinson
Guest
n/a Posts
> motor, esc?
I guess you mean a 2 cell lipo. If s, it's a waste of $$ unless you
have one around. The stock motor is anemic. I tried better brushed
motors, finally went brushless and lipo. It's a great flying model with
enuff power.
CR
Article Great Planes Super Sportster EP ARF Review wahrhaftig Electric Plane Talk 12 Sep 14, 2009 07:55 PM
Wanted Great Planes Super Sportster EP dsliwins Aircraft - Electric - Airplanes (FS/W) 13 Jul 30, 2007 11:44 PM
For Sale Great Planes Super Sportster EP 48" RCMC Aircraft - Electric - Airplanes (FS/W) 0 Jan 23, 2006 12:46 PM
Found Great Planes Super Sportster EP ARF 48" smurf Aircraft - Electric - Airplanes (FS/W) 7 Aug 11, 2005 07:03 PM
Great Planes Super Sportster EP Arf mickydee Electric Plane Talk 11 Nov 15, 2004 05:27 PM
