Old Mar 19, 2002, 09:22 PM
AMTJIM is offline
Find More Posts by AMTJIM
"Bible Thumper"
AMTJIM's Avatar
United States, AZ, Tucson
Joined Mar 2001
whats the smallest readily available servo
Is the smallest servo available still the hs55 size?
AMTJIM is offline Find More Posts by AMTJIM
Old Mar 19, 2002, 10:59 PM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
The HS-50 is smaller. The indoor stuff like WES-Technik is even smaller still. Check out http://www.toddsmodels.com/servo.htm
ScottS is offline Find More Posts by ScottS
Old Mar 20, 2002, 01:07 AM
omega blood is offline
Find More Posts by omega blood
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
CS-10 molecular servo. available through http://www.hobbypeople.net/
omega blood is offline Find More Posts by omega blood
Old Mar 20, 2002, 07:45 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I think the GWS Pico servo is smaller & lighter than an HS50, don't have the figures to hand though.
I use the GWSs (with JST connectors) for indoor models and HS50s for small outdoor models (S280 etc).
Bill Glover is offline Find More Posts by Bill Glover
Old Mar 20, 2002, 08:22 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I like the GWS Pico servos. You get more arms and extra screws. The screw that holds the arms on goes in easy, the HS's go in hard, not good for wimpy models. I hard wired a GWS receiver and two Pico servos together in a brick and got the weight down to 14 grams total. The three pieces weighted 19 grams before I started. Now I can add a retract servo and have the same weight in the plane.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Mar 20, 2002, 08:44 AM
flailing is offline
Find More Posts by flailing
Houston, Texas
Joined Oct 2000
Jamara Bit servos 5gm at www.eam.net
flailing is offline Find More Posts by flailing
Old Mar 20, 2002, 09:31 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Tiny servo
Heard a rumor that GWS is coming out with a new tiny servo, probably similar to the expensive German linear outout servos.
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 21, 2002, 06:23 PM
Fred Marks is offline
Find More Posts by Fred Marks
Ijamsville, MD, U.S.A.
Joined Mar 2001
The FMA Direct PS 30 is the smallest and lightest available with the exception of the Westek. PS 30 also uses a full size output shaft that accepts other manufacurers output arms. Finally, it has twisted, self-shielding cable that is highly flexible and has 65 starnds of #44 wire.
Fred Marks is offline Find More Posts by Fred Marks
Old Mar 21, 2002, 07:38 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Fred: The specs and picture of the PS30 remind me of the Expert SL110 that I picked up a while back on an emergency run to the LHS, and it was all they had. I can't complain about it, seems fine, except the leads were pretty short. Are these 'close relatives'?
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 21, 2002, 11:24 PM
Quacker is offline
Find More Posts by Quacker
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Hi Fred. I'm a little lost. your specs claim .28oz but the GWS Pico and HS-50 both claim to be sigificantly lighter. Can you help?
Q
Quacker is offline Find More Posts by Quacker
Site Sponsor
Old Mar 22, 2002, 03:52 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
I've actually weighed the GWS Pico BB 101 and the HS-50. They each weigh 0.22 oz. as claimed. The HS-55 came in at 0.28 oz.
Maybe FMA is shooting themselves in the foot when they state 0.28 oz for the PS-30.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Mar 22, 2002, 04:04 AM
Joined Nov 2000
The difference is maybe that the GWS is available with JST leads & connectors ... definitely lighter than standard connectors. All my GWS Picos are the JST lead ones, I use Multiplex Pico 3/4 Rxs for my indoor models but the GWS R4P is available with a JST block too.
Old Mar 22, 2002, 06:20 AM
Newark, DE USA
Joined May 2001
Nope. My 0.22 oz. 101s and HS-50s have regular (JR, HiTech etc.) plugs and leads. The JST would be even lighter.
I weighed them on a digital reloading scale that measures to 0.10 grain. One grain = around 1/15 of a gram.
RB
Old Mar 22, 2002, 06:54 AM
JonB is offline
Find More Posts by JonB
Gladstone, NJ. USA
Joined May 2000
AZ Chuck, Can you elaborate on your "BRICK"?
Dear AZ Chuck:
Can you explain and or post some pics on exactly how you fabricated the "Brick" configuration of 2 servos + receiver @14grams AUW?
Sincerely,
Jon B. Shereshaw
JonB is offline Find More Posts by JonB
Old Mar 22, 2002, 02:09 PM
Joined Nov 2000
OK, I use the Pico F STD which is a little lighter than the Pico BB. The quoted weights are 5.4g and 6.2g ... I assume the lighter weight is with the JST lead. The Pico BB is quoted as 5.7g / 6.5g. 6.5g is 0.229 oz, that's pretty close to what you measured with JR lead fitted.
So to come back to the original question of the thread, at 5.4g (0.19 oz) I think the Pico F with JST lead may well be the smallest & lightest mass-produced servo around.
Whats the best way to use a Servo to trigger Mini 3 RandyK1 Aerial Photography 2 Nov 21, 2003 06:43 AM
Whats the Smallest Brushless motor Available??? JonB Scratchbuilt Indoor and Micro Models 10 Nov 14, 2003 04:49 AM
lightest readily available foam? aeropenguin Scratchbuilt Indoor and Micro Models 13 Sep 15, 2003 09:51 PM
What is the smallest metal geared servo? tempest411 Electric Plane Talk 8 Nov 20, 2001 09:40 PM
