Old Feb 17, 2005, 11:10 AM
DWS is offline
DWS
Find More Posts by DWS
DWS
D.W. Schmidt
United States, IL, Scott AFB
Joined Sep 2004
Are outrunners more efficient at partial throttle
I thought I had read somewhere that while the high rpm/geared hackers and other such motors were more efficient at high power settings, the outrunners (such as the Axi brand) actually had an advantage when just cruising at half throttle. I realize this is more applicable to sport or trainer type aircraft, but is it true?
I am assuming in my question the same ESC and battery being used for both.
Thanks!
D.W. Schmidt
DWS is offline Find More Posts by DWS
Old Feb 17, 2005, 12:13 PM
CharlieS is offline
Find More Posts by CharlieS
Registered Electron User
CharlieS's Avatar
Ithaca, New York, USA
Joined Jun 2001
I would like to know the answer to your question. It may be true due to the relatively high inductance of multi-pole motors such as outrunners. The higher inductance could smooth out the PWM by suppressing the higher harmonics, thereby reducing torque ripple and possibly other power absorbing effects. Anyone know for sure?
Charlie
CharlieS is offline Find More Posts by CharlieS
Old Feb 17, 2005, 01:59 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Thanks!
D.W. Schmidt
The short answer is no. The issue is not simple--the controller plays a big part in this discussion.
Motor type is really not a issue.
One fun note--brushed motors (the good ones) often are better at part throttle.
Steve
sneu is offline Find More Posts by sneu
Old Feb 18, 2005, 08:57 AM
DWS is offline
DWS
DWS
D.W. Schmidt
Joined Sep 2004
Thanks Steve,
I seem to recall you wrote a couple of your columns in Quiet Flyer about partial throttle efficiency regarding different controllers. Any plans to do more tests or were the differences to small to worry about?
D.W.
Discussion Why are inrunners more efficient than outrunners? Surly_Schmidt Power Systems 34 Oct 23, 2006 06:07 AM
Discussion less amps with more lipos for a given RPM at partial throttle? Nethole Batteries and Chargers 30 Oct 12, 2006 05:50 AM
Question Outrunners - more efficient at high or low RPM? hilgert Power Systems 3 May 15, 2005 07:40 AM
is a speed control under more stress at lower throttle settings? Matthew Cotten Power Systems 5 Oct 24, 2003 07:15 PM
Is flying at partial throttle with a sensorless brushless motor bad? Mitch G Power Systems 6 Dec 12, 2001 02:15 PM
