Old Feb 16, 2005, 11:17 PM
txfly is offline
Find More Posts by txfly
txfly's Avatar
frisco,tx
Joined Oct 2003
is it necessary to modify the formosa for 200 watts?
i usually run a light setup(rz 300, 3s 1500) no gear no mods. and apc 9x7.5. flys great. but, i would switch back and forth with a 2025 himax and larger lipo. for a higher wing load and more speed. (all this time keeping a light airframe). will it rip apart? aileron flutter? any comment would be appreciated. -txfly
txfly is offline Find More Posts by txfly
Old Feb 18, 2005, 02:30 PM
kenkamm is online now
Find More Posts by kenkamm
Maryland
Joined Dec 2002
Tons of people run high power himaxx setups in their formosas, and many do add some structural enhancement.
Make sure your ailerons don't have any slop in them where the aileron torque rod is glued into the aileron. There are lots of ways to reinforce this without adding much weight if you want to. If things are loose, you might get flutter.
The wing seems to be stiff enough, but some people will use a stiffer carbon rod in place of the fiberglass rod, or even use carbon rods on top and bottom of the wing.
The fuse is also stiff enough, but tends to break behind the wing when it does break, so some people put some packing tape or glass or carbon in that area to reinforce.
I think that's all that's necessary for the formosa with lots of power. I think a lot of people fly them stock and it does quite well from what I have read.
kenkamm is online now Find More Posts by kenkamm
Old Feb 18, 2005, 06:43 PM
RC4ZEKE is offline
Find More Posts by RC4ZEKE
Whistling Death
RC4ZEKE's Avatar
WA,USA
Joined Jun 2004
Should stay together as long as you reinforce it like Kenkamm states. I'm having a blast with mine. Still holding up with over 200 watts on it.
Himax 2025-5300
GWS 6.6:1 gear
Kokam 3S2P 3000
11x8 prop
RC4ZEKE is offline Find More Posts by RC4ZEKE
Old Feb 18, 2005, 06:58 PM
yorbenator is offline
Find More Posts by yorbenator
fly-crash and resurect
yorbenator's Avatar
Joined Jun 2004
hows the speed/thrust wuth that setup?
i'm running-
himax 2025-4200
tamhazo gb-200 6:1
polyquest 3s 1500
12 x 6 apc
i'm getting vertical at slightly more than half throttle, but in a word.....it is SLOOOOOOWW i'm only getting 33 mph pitch speed :O
yorbenator is offline Find More Posts by yorbenator
Old Feb 18, 2005, 08:30 PM
RC4ZEKE is offline
Whistling Death
RC4ZEKE's Avatar
WA,USA
Joined Jun 2004
It's fast and shoots straight up like a rocket. I can hold a short hover a bit over quarter throttle. Tons of fun!!!
Old Feb 18, 2005, 09:29 PM
Ben Lanterman is offline
Find More Posts by Ben Lanterman
Ben Lanterman's Avatar
St. Charles, MO USA
Joined Jan 2001
Don't you need some kind of a license to fly it at those power ratings :-)
Ben Lanterman is offline Find More Posts by Ben Lanterman
Old Feb 19, 2005, 08:35 PM
txfly is offline
txfly's Avatar
frisco,tx
Joined Oct 2003
yorb, try a smaller gear and prop. 5.33:1/9 X 7.5 will increase your speed and still give faster verticle. i use 12x6 for slow 3d type planes
Old Feb 19, 2005, 08:42 PM
txfly is offline
txfly's Avatar
frisco,tx
Joined Oct 2003
rz4, do you have a pic of the inside of your formosa? i have all the equipment you have ,but not sure where your putting everything. does your have dual aileron servos to open up the bottom area?
Old Feb 19, 2005, 11:53 PM
RC4ZEKE is offline
Whistling Death
RC4ZEKE's Avatar
WA,USA
Joined Jun 2004
Sorry no picture. All my servos are in the original cutouts and I only use one HS-55 servo for both ailerons. Had to cut out the whole inside of fuse area to fit my battery and so I could get to my electronics because with this much power, I needed to glue the wing on. Hope this helps.
Discussion Outrunner for 10X4.7 & 200 watts? lrsudog Power Systems 8 Mar 05, 2006 04:40 PM
losi xxx-t nib for $200 shipped h22a4 Cars - Cars and Parts (FS/W) 1 Jul 13, 2003 12:50 PM
Gearbox for 900+ watts? -Draken- Power Systems 11 Apr 25, 2003 09:57 AM
200 watts /lb KWIK-E! Gerald Sport Planes 10 Jun 03, 2002 05:23 AM
Y/A F18 200 watts per pound Plane Crazy Electric Ducted Fan Jet Talk 33 Dec 23, 2001 08:01 PM
