Old Mar 19, 2002, 04:51 PM
RobZ is offline
Find More Posts by RobZ
MAAC 6251
Ottawa, Ontario, Canada
Joined Jan 2002
Anyone ever heard of a motor manufacturer named Air Supply, Inc.?y
Hi.
I have an 05 size motor with a sticker that reads Air Supply, Inc.
Machida, Tokyo, Japan.
It is very deep brown (looks black in some light) and has ball bearings. It has stong coging like a Magnetic Mayhem motor.
Anyone ever heard of these guys and have any technical info on this motor?
Thanks.
Rob.
RobZ is offline Find More Posts by RobZ
Old Mar 19, 2002, 09:02 PM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
I seem to remember these about 12 years ago. Mitch Poling wrote about them There was a gold and silver version - I don't remember if there was a quality difference or a winding difference between the two. They were quality ferrite motors, possibly strontium ferrite magnets.
Cheers,
Martin Irvine is offline Find More Posts by Martin Irvine
Old Mar 20, 2002, 06:54 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Cheers,
Closer to 20! I used one in a very early electric project of mine which would put it in the 1982-83 range. I think Mitch might have even been out of the column writing business by 1990 - maybe not...
Chris True is offline Find More Posts by Chris True
Old Mar 20, 2002, 10:54 AM
Trent Hare is offline
Find More Posts by Trent Hare
Micro Hydro Racer
Trent Hare's Avatar
Rocklin, Ca. USA
Joined May 2001
Had 2 of them - they were very strong...
My first one was the best (several years older than the second). It appeared to contain cobalt magnets, and would absolutely rip the tires off my 1/10th scale pan cars. It was the "ND10 - neo" motor of it's day.
"World engines" or "Global engines" I can't remember which, was the importer of the motor at the time. Since the first motor I had was purchased used, but very good, I decided to purchase a second new motor from the importer. It unfortunately was of a slightly less quality construction, and the magnets felt weaker. Still good, but not as good as the first.
I have since modified an 05 endbell to fit the original (best) can to enable the use of regular 05 armatures and modern brushes. It was one of my favorite motors - until I discovered the brushless motors.
Trent Hare is offline Find More Posts by Trent Hare
Old Mar 20, 2002, 11:33 AM
RobZ is offline
MAAC 6251
Joined Jan 2002
Hi Trent.
That's my motor alright (except for the rear end bell). Do you by chance remember how many turns this motor has?
Thanks.
Rob.
Old Mar 20, 2002, 12:06 PM
Micro Hydro Racer
Trent Hare's Avatar
Rocklin, Ca. USA
Joined May 2001
I believe mine was 17 turns.
I didn't unwrap it to verify. However, it's aramature stack was about 1-2mm shorter than a regular 05.
Old Mar 20, 2002, 12:54 PM
Andrew Mifsud is offline
Find More Posts by Andrew Mifsud
Gibraltar
Joined Jan 2001
I got one with my Kalt Whisper kit. It was a nice motor but didn't last long in the heli due to overheating. I have skimmed the armature and replaced the brushes and it now runs well.
It's a high quality ferrite with 2 ball bearings, replaceable brushes, variable timing,and triple wound. I don't know how many turns are on it.
There's some talk about them here.
http://www.iroquois.free-online.co.uk/whispomt.htm
Mine has an orange/red label and is called Air Supply Pro Trix.
Andrew
Andrew Mifsud is offline Find More Posts by Andrew Mifsud
Old Mar 20, 2002, 04:20 PM
RobZ is offline
MAAC 6251
Joined Jan 2002
Thanks to all you guys for the help.
Trent.
I'd like to know more about your modifications to the rear end bell. Even a picture of it would help. It sounds very interesting. Have you done this kind of mod. on other motors too?
Thanks.
Rob.
Old Mar 20, 2002, 06:28 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
AirSupply is actually one of the biggest motor can/endbell OEM supplier in Japan. Several big name US car motor mfg uses their can and endbell, and hand wound the armatures here in the states.
Steph280 is offline Find More Posts by Steph280
Old Mar 21, 2002, 05:19 AM
Tim Jonas is offline
Find More Posts by Tim Jonas
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
In addition to making those motors, they were also a hideous 80's band.
Tim Jonas is offline Find More Posts by Tim Jonas
Old Mar 21, 2002, 07:06 AM
RobZ is offline
MAAC 6251
Joined Jan 2002
Thanks again to those who posted answers.
I paid $12.00 for this motor. Is that an alright price for it?
I might be able to get another one at the same price. Should I do it?
Rob.
Old Mar 21, 2002, 08:17 AM
Micro Hydro Racer
Trent Hare's Avatar
Rocklin, Ca. USA
Joined May 2001
...That's your call. But I would if it wasn't damaged.
12.00 bucks is cheap.
Modifications - Here's what I did - your mileage may vary. (see pic in above post):
Can - I ground off about 4-5mm off the brush end of the can. That allows the correct spacing for the new endbell and armatures. You'll have to measure yours and cut accordingly.
Endbell - I used an old "modified" endbell and turned down the aluminum retaining ring, and the inner most lip on the plastic housing. Their diameter was too large to fit inside the air-supply can.
I also believe I had to press small handmade pins into the can to provide the hold downs required by the new endbell.
It's a lot of trial and error basically. Don't attempt it if you feel unsure about messing up a good motor. They work pretty good as is.
Old Mar 22, 2002, 01:12 PM
RobZ is offline
MAAC 6251
Joined Jan 2002
Thanks for the info Trent.
The com and brushes are still new so I think I'll wait untill they are used up a bit more.
Rob.
Old Mar 22, 2002, 01:25 PM
EBob is offline
Find More Posts by EBob
Sacramento, CA
Joined Sep 2001
Nice nostalgia trip and good info. Thanks, guys.
I have an AS cobalt lying in a corner of my workbench.. will have get it out and dust it off.
Mitch Polling was my e-god for years... he did some tests on connector loss when he was the e-columnist for Model Builder, and so I still use the Dean's 4 pin for my S400 motors/battery packs at his recommendation.
EBob is offline Find More Posts by EBob
Old Mar 22, 2002, 04:43 PM
RobZ is offline
MAAC 6251
Joined Jan 2002
Hi EBOB.
Are you saying that the Air Supply motor in Trent's photo has cobalt magnets? If so I have a real find here.
Rob.
Has anyone ever heard of this kit? 525cj Fuel Plane Talk 2 May 14, 2008 09:55 PM
Anyone ever heard of this story??/ rumme Life, The Universe, and Politics 8 Jan 07, 2006 11:10 AM
Anyone ever heard of the overlord LANDING!!! Flying Wings 3 Aug 28, 2005 10:47 AM
Anyone ever heard of BUI BISSAU PG?!?! P-51 fan Life, The Universe, and Politics 5 Dec 31, 2003 05:37 PM
Has anyone ever heard of a HS-80 servo? kushal_22 Foamies (Kits) 8 Apr 30, 2002 12:29 PM
