Old Feb 16, 2005, 03:55 PM
LJH is online now
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Whats the big deal about haveing Lipo cut off on your ESC?
I see this time and again about people saying that they have to have Lipo LVC on there ESC's. I have been flying E power for 6 years now and still fly lots of planes that were put together way before we had even heard of Lipo batteries for E flight and I have no issues. Just fly the plane for set amount of time that you will know is safe, then just charge the pack and see how many Mah goes back in and you can get a pretty good idea how long you can fly. I have gotten to the point that I can guesstamate within a min. of how long I can fly for.
Getting off my soap box now.
Cheers,
Jim
LJH is online now Find More Posts by LJH
Old Feb 16, 2005, 03:59 PM
nickrage is offline
Find More Posts by nickrage
Strathmore, Alberta Canada
Joined Jan 2004
I have a apache 2020 charger and do not know how to calculate how much I put back into a partially charged pack.. is there some way to calculate this.
I.E charging back at 750mah for 45mins or something
nickrage is offline Find More Posts by nickrage
Old Feb 16, 2005, 04:08 PM
sirdirk007 is offline
Find More Posts by sirdirk007
crashin with a smile
sirdirk007's Avatar
Los Angeles Industry, California, United States
Joined Jul 2004
Well after a few $50 mistakes in your timing you will see the importance of lvc for lipos. Its not that there is timing issues it is simply that if a lipo charge reaches below 3.6 per cell the batt can go flat and render it useless. I have jump started a few that I have accidentally forgot to change lvc for but they were pretty much useless when it came to having the same punch or longevity
Just my 2 cents but don't be surprised to see many more agree with me.
sirdirk007 is offline Find More Posts by sirdirk007
LJH is online now
LJH
LJH
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Hmmm....Nick you bring up a good point. I guess for someone who does not have a charger with a Mah readout you could use you DVM to check voltage after a flight and figure out how long you can fly by your voltage.
Cheers,
Jim
Old Feb 16, 2005, 04:17 PM
LJH is online now
LJH
LJH
LJH's Avatar
Greenwich CT.
Joined Sep 2000
SD7,
I am going to have to disagree, I have been flying Lipo since the first Kokam 1020's came out and now own close to 20 Lipo packs and I have never distroyed a pack flying it. You can safely bring a lipo cell down to 3V if not a skoch lower with out distroying it. My 4 E-Tech 1200HP 3S packs normally show 9.3-9.5V resting after a flight and two of them are closeing in on 100 cycles (still taking over 1100mah) and the other two are around 50 cycles (taking around 1225mah).
Cheers,
Jim
Old Feb 16, 2005, 04:27 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
Jim, I am another one that times the flights. I too watch what I put back in and get a 'good' estimate of flying time. I set my LVC at 7.2 (for a 3S pack) and go fly (timed of course) . I have accidently flown 'longer' than I should have a couple of times, but it is very apparent when it's about time to land and of course I do so immediately with minimum throttle to get the plane down.... Never saw a problem with the pack(s) ....
I can see with cheap chargers you probably would have to rely on the LVC .... Of course once you 'hit' the LVC you should have a good idea of the time and time your flights from then on anyway....
rclark is offline Find More Posts by rclark
Old Feb 16, 2005, 04:50 PM
sirdirk007's Avatar
Joined Jul 2004
Jim Remember that running voltage and standing voltage are two different things. I also set my cutoff at 7.2 for 3S but when it is cutoff the standing voltage on ground is still around 9.8 to 10v. I am simply trying to help you understand why we use this system. If you can time flight and judge power of the cell great for you. I know on my gas slimers I have to as well time all flights. Especially with my tequila sunrize. That baby flies awesome but deadstick it drops like a rock
Old Feb 16, 2005, 05:00 PM
MartinL is offline
Find More Posts by MartinL
Australia
Joined Oct 2000
I am the same with my Etec packs..about 8 packs...close to 50 cycles without a Lipo Esc..all is well if u stop flying when the 1st cutoff drops in. My biggest is 3S. I will not do that with packs greater than 3S.
MartinL is offline Find More Posts by MartinL
Lipo cut off - under load or off load? NickT Batteries and Chargers 13 Aug 05, 2004 02:53 AM
maiden'd TigerMoth. OK..... So, whats the big deal? L.I.A. Parkflyers 16 Jun 25, 2003 08:09 PM
Low volt cut off on a non BEC controler? Steven D Electric Plane Talk 2 Jun 07, 2002 12:46 PM
What's the big deal about governor mode Arthur Knowles Electric Heli Talk 7 Apr 29, 2002 08:15 AM
Dumb question: Whats the big deal about autorota jasonstory Electric Heli Talk 15 Sep 30, 2001 02:05 AM
