Old Jun 04, 2002, 05:39 PM
Schluter60 is offline
Find More Posts by Schluter60
Experienced Member
Schluter60's Avatar
East Hartford, CT. U.S.A.
Joined Jan 2001
Pedal Launcher Article
Your welcome Malcom, as you can see, that is the pedal launcher I built and I must say it works very well. Dave Lilley has said he is going to add the Pedal Launcher article I wrote to the Ezone family of construction articles to help other Ezoners.
Schluter60 is offline Find More Posts by Schluter60
Old Jun 04, 2002, 06:21 PM
Peter W is offline
Find More Posts by Peter W
Peter W's Avatar
London
Joined Jul 2001
this is very cool indeed, but could it be put on the roof of a car and then you launch, fly your plane in front of the windshield..........
Pete
Peter W is offline Find More Posts by Peter W
Old Jun 04, 2002, 09:53 PM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
This is great Schluter. Excellent photos and explanations ! Looking forward to your article.
Al
Al P is offline Find More Posts by Al P
Old Jun 05, 2002, 08:13 AM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Multiplex Twinjet Ready for launch
Just step on the pedal, small amount of up elevons, release the ship and away you go !
Old Jun 05, 2002, 09:47 AM
saint152 is offline
Find More Posts by saint152
saint152's Avatar
Formerly CA now Missouri
Joined Sep 2001
Schluter60....
What are you using for a nylon hook mounted on the bottom of your plane?
saint152 is offline Find More Posts by saint152
Old Jun 05, 2002, 12:25 PM
Dan H. is offline
Find More Posts by Dan H.
Crashez-vous sans stress!
Dan H.'s Avatar
Chicago
Joined Nov 2001
Looked like a cut-down control horn to me...that right Schluter?
Dan H. is offline Find More Posts by Dan H.
Old Jun 05, 2002, 03:02 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
The ends of the bungee with metal "eyes" were attached by Hollyday Designs when I purchased the 20' bungee.
What type of buisness is Hollyday Designs?
I'd like to get a professionally made bungee like that....Oh and what diameter is it?
Schluter, you also said you use a fish scale to determine the pull on the bungee for different planes. Can you give some examples?
Thanks in advance,
Wiz
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jun 05, 2002, 07:32 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Pedal launcher Questions / Answers
Saint 152, I use different types of hooks depending on the type of aircraft. On the Multiplex Picojet Combat I use a modified nylon control horn. On the Twinjet I use a small metal screw eye (with the eye 1/2 cut off) through a 1" long piece of maple located in the channel on the bottom. The maple is light for a small piece and it stregthens the mount to withstand the launch and landing. I find the hooks take more abuse on landing than on launch if you don't bleed off almost all of the airspeed before you touch down.
Mike W., I ordered the bungee with ends from Hollydale Designs. http://www.hollyday.com/. Last I checked they were taking the summer off, but they should be back in the fall. I've seen surgical tubing at our local Lowes that would also work for about 1.35 a foot. I used a fish scale at firat to get a starting point, but now I just pace off the distance and drive in my anchor stake. The bungee I use is 20' long and I stretch it out to 60' (3 : 1 ) for the planes I'm launching. I definately woouldn't stand in front of one ready for launch, they come off the launcher like an aircraft carrier launch.
Old Jun 05, 2002, 08:12 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Foam pipe insulation?
I imagine the insulation protects the undersides of the wings from bumps etc, but do you need to use anything else for the wings to slide freely on launch? Maybe the foam is slicker than it looks
scirocco is offline Find More Posts by scirocco
Old Jun 05, 2002, 09:00 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Foam Insulation
The foam insulation is regular pipe insulation. It protects the wings and the rails are adjustable so you can keep the servos and linkages clear. These planes are very light and the bungee provides plenty of power so the drag created by the foam is negligible.
Old Jun 05, 2002, 10:05 PM
saint152 is offline
saint152's Avatar
Joined Sep 2001
Schluter60...
Thanks for the info......looks like I've got yet another project to do!........It's bungee time!
Old Jun 06, 2002, 12:46 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Thanks again for the info and great pictures, Schluter.
Wiz
Old Jun 06, 2002, 02:54 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
ayes i would like to say thanks once agian. This type of peddle launcher is just wjhat i need(PVC) as it is light enough for me to pick up and carry in my wheelchair. Yet strong enough to handle the loads put on it. Great JOB!!
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Jun 07, 2002, 08:24 PM
hmx is offline
hmx
Find More Posts by hmx
hmx
Pittsburgh,pa
Joined Jun 2002
Launcher
Many thanks. This is exactly what I was looking for. I couldn't figure out how the release pedal and pin worked.
Again thanks,
HMX
hmx is offline Find More Posts by hmx
Old Jun 08, 2002, 08:20 AM
BioHazard is offline
Find More Posts by BioHazard
CMFC Secretary (UK)
BioHazard's Avatar
Swindon, UK
Joined Oct 2000
Here's mine.
Same idea, but shorter PVC tubing ( can have extension pieces inserted into end ) and smaller launch mechanism.
BioHazard is offline Find More Posts by BioHazard
PVC pedal launcher in UK? stegla Electric Ducted Fan Jet Talk 21 Feb 08, 2003 02:15 PM
PVC Pedal Launcher Slope Nut Electric Plane Talk 11 Sep 24, 2002 10:18 AM
PVC Pedal Launcher dave_lilley Modeling Science 2 Aug 25, 2002 01:35 AM
PVC Pedal Launcher dave_lilley Site Chat 0 Aug 23, 2002 01:20 AM
pvc pedal launcher hmx Electric Plane Talk 3 Jun 05, 2002 02:19 PM
