Old Mar 19, 2002, 08:43 PM
Schluter60 is offline
Find More Posts by Schluter60
Experienced Member
Schluter60's Avatar
East Hartford, CT. U.S.A.
Joined Jan 2001
Pedal Launcher Bungee Missing
The bungee portion isn't in the photo. The 1" metal ring is attached to the plane to be launched, the nylon cord (white) is tied to the ring attached to the plane and tied to the 1" metal ring attached to the release pin. The bungee is attached to the metal ring on the release pin also. When you step on the pedal the ring is forced off the release pin and the tension provided by the stretched bungee is transferred to the plane thru the nylon cord attached to the metal ring attached to the plane.
Schluter60 is offline Find More Posts by Schluter60
Old Mar 19, 2002, 08:50 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Thanks!
drbird is offline Find More Posts by drbird
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Pedal Launcher Release Pin
In this picture it is hard to see the nylon cord, but the metal ring with the red streamer attaches to the plane to be launched and the other metal ring attaches to the release pin. The bungee also attaches to the metal ring on the release pin.
Old Mar 20, 2002, 11:21 AM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Photo of Bungee Tubing and Connectors
If it would be helpful to anyone considering building a pedal launcher, I can attach a picture of the bungee tubing and connector tonight when I get home to my digital camera.
Old Mar 22, 2002, 03:45 PM
CESARNOGUEIRA is offline
Find More Posts by CESARNOGUEIRA
MULTI ENGINE FANACTIC
CESARNOGUEIRA's Avatar
SAO PAULO,S.P.,BRAZIL
Joined Dec 2000
Re: Pedal Launcher Release Pin
SIMPLE, AFFORDABLE, EASY TO BE DONE!
Congratulations!
CESARNOGUEIRA is offline Find More Posts by CESARNOGUEIRA
Old Mar 29, 2002, 08:32 AM
joegib is offline
Find More Posts by joegib
Manchester, Ct
Joined Mar 2001
I'm finding that I need to build a launcher cause my planes are getting bigger (graduated from the park flyers and into edfs now).. I love this launcher and wonder if anyone has the plans from the S&E sept/2001 issue they could send me or post..
I have questions though..??
1. where do you buy the bungee cord? homedepots?, camper places? on internet?
2. Why the nylon cord? can't you just hook the bungee directly to the plane?
3. It must work...but isn't the "quick pull" of the bungee too much for the foamies, balsa planes.. and it just "rips out" the tow hook on lauch... seems like a lot of pull regardless of how much you strengthen the two hook.. am I missing something here?
joegib is offline Find More Posts by joegib
Old Mar 29, 2002, 11:28 AM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
SEModeler Pedal Launcher Plans
Joe,
If you do a Ezone search on Pedal Launchers, Bungee launcher, bungee, or catapault, you will find pictures of the SEModeler Plans. I must tell you though, there are no dimensions or plans, only pictures and text. Actually, the pictures I posted are much clearer and detailed.
You can purchase 3/8" surgical tubing at Lowes in Manchester. Some Home Depots carry it as well, but not Manchester or Glastonbury.
You can not hook the bungee directly to the plane because you won't have a "trigger" mechanism. The tension of the stretched bungee is held by the release pin and the nylon cord transfers the power to the plane once you step on the pedal and release the bungee. I just got back from the field today and it works wonderful. I could make a small sized circuit and land if necessary without running the plane's motor.
The quick pull does no damage to the hook because there is no slack in the cord or resistance to the plane's forward flight. Release the bungee and the plan takes off like it was shot out of a gun.
The strength of the bungee can be regulated for the size / weight of the plane you are trying to launch. I use a fish scale and pull the bungee to a predetermined tension for different planes.
Old Mar 29, 2002, 11:54 AM
Tim Jonas is offline
Find More Posts by Tim Jonas
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
me too. I would appreciate an idiot-proof description of how the set up goes.
cheers,
Tim
Tim Jonas is offline Find More Posts by Tim Jonas
Old Mar 29, 2002, 12:08 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Pedal Launcher Diagram
stake Launcher Release Pin Plane
0-------------bungee----------------------------------0--------------------X
Pedal Launcher is staked to ground (front & back) and lead end of bungee is staked to ground after being stretched to correct tension. The other end of bungee is attached to release pin on pedal launcher. A nylon cord ties to bungee ring on release pin and attaches to hook on plane. When you step on pedal it forces the tensioned bungee off of the release pin and the tension shoots the plane up the launcher ramp and into the air. Applying a little up elevator raises the plane on release and insures the bungee releases from the hook. Review the previous pictures and the detail is shown. If this doesn't clear it up, I'll post a photo of the bungee and ring assembly. Tell me if you want to see the bungee itself.
Old Mar 30, 2002, 09:57 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Bungee Closeup Detail
The bungee is coiled up, but you can see all the connecting points.
Old Mar 30, 2002, 09:59 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Connecting Bungee to Anchor stake
The two rings on the other end of bungee connect to release pin and plane being launched.
Old Apr 25, 2002, 01:46 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Good pictures, they explain alot. One question, how did you connect the bungee to the metal rings?
Paul
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Apr 25, 2002, 03:06 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
I have seen people putting a parachute on the steaked end of the bungee cord too. It dose nothing there, untill the unfournate day that the steaked end decides to let loose of the ground. Then the steak and bungee comes at you at a much slower pace.
sp?
Kevin Murray is offline Find More Posts by Kevin Murray
Old Apr 25, 2002, 05:05 PM
Experienced Member
Schluter60's Avatar
Joined Jan 2001
Attaching Bungee to Metal Rings
The ends of the bungee with metal "eyes" were attached by Hollyday Designs when I purchased the 20' bungee. The ends (2) were $3.00 extra if I remember correctly and they attached them for free. I attach the eye end of the bungee to the stake using split (key) ring type connectors.
Old Jun 04, 2002, 03:02 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Schulter60 Thanks!!!
Thank you so very much This was EXACTLY THE THREAD i was looking for.
Malcom
kushal_22 is offline Find More Posts by kushal_22
PVC pedal launcher in UK? stegla Electric Ducted Fan Jet Talk 21 Feb 08, 2003 02:15 PM
PVC Pedal Launcher Slope Nut Electric Plane Talk 11 Sep 24, 2002 10:18 AM
PVC Pedal Launcher dave_lilley Modeling Science 2 Aug 25, 2002 01:35 AM
PVC Pedal Launcher dave_lilley Site Chat 0 Aug 23, 2002 01:20 AM
pvc pedal launcher hmx Electric Plane Talk 3 Jun 05, 2002 02:19 PM
