Old Feb 16, 2005, 11:15 AM
rumme is offline
Find More Posts by rumme
Joined Apr 2004
Can anyone recommend A plane with less then 30" wingspan..
that is a hot flyer and consistent flyer ..that takes 3 channels..I will be using a brushless himax 2812-1080 direct drive in it..would like something with some good speed characteristics {40mph+}...please help...can be a RTF or ARF...Ive tryed the mini piper twice..and no luck with it...so no need to recoemmend that specific plane..be nice if it was also crashworthy...thanks
rumme is offline Find More Posts by rumme
Old Feb 16, 2005, 12:30 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Would 30 and 1/8 inches be okay?
Take a look at the Wattage Hawk, it's small, fast and durable.
http://www.hobbypeople.net/gallery/128415.asp
Basketcase is offline Find More Posts by Basketcase
Old Feb 16, 2005, 12:37 PM
Tim Trick is offline
Find More Posts by Tim Trick
Tim Trick's Avatar
The Netherlands
Joined Apr 2004
Have a look at the RBC Embrear 314 Super Tucano. From what i have seen it is real cracker of a plane at 27 inch:
http://www.rbckits.com
Cheers
Tim
Tim Trick is offline Find More Posts by Tim Trick
Old Feb 16, 2005, 12:44 PM
TooTall is offline
Find More Posts by TooTall
victim of the system
TooTall's Avatar
Home of the Toledo RC show
Joined Jul 2003
SA micro cap 232
TooTall is offline Find More Posts by TooTall
Old Feb 16, 2005, 01:32 PM
rumme is offline
Joined Apr 2004
thanks I will look at all 3 of these...keep the recomendations coming..
Old Feb 16, 2005, 01:35 PM
rumme is offline
Joined Apr 2004
who sells the sa micro cap232??
Old Feb 16, 2005, 01:42 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
www.stevensaero.com
Old Feb 16, 2005, 02:02 PM
sirdirk007 is offline
Find More Posts by sirdirk007
crashin with a smile
sirdirk007's Avatar
Los Angeles Industry, California, United States
Joined Jul 2004
The micro cap is cool and I have scratch built one very similar to it. The reason I mention it is I just wanted you to know it is a very advanced fun 3d plane. Not a good choice as a second plane, but if your pilot skills are great then go for it and you will not regret it.
sirdirk007 is offline Find More Posts by sirdirk007
Old Feb 16, 2005, 02:37 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
When you say 3 channel you mean rudder, elevator and throttle right? The micro Cap is gonna be 4 channel. If you are talking 4 channel I like the Littlebirdz.com G-Nat. Flies great on CD motor.
bildo baggins is offline Find More Posts by bildo baggins
Old Feb 16, 2005, 03:04 PM
sirdirk007's Avatar
Joined Jul 2004
A plane with the capabilities you are referring to would usually be 4 channel and you would want that anyway because using the rudder in flight is a great learning adventure and good practice to better your pilot skills. I had the hardest time learning 3d flying because I learned to fly using rudder only as a ground control thing.
Old Feb 16, 2005, 03:28 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
40 mph is actually pretty fast. It seems slow when you think about it but when measured with a speed gun you would be surprised. I saw a speed wing I thought was doing 70+ easy and it was in the mid 50s. Agree on the 4 channel thing unless you want elevator aileron only. That is entirely possible for a pylon type plane.
Old Feb 16, 2005, 04:17 PM
kscbob1 is offline
Find More Posts by kscbob1
Semper Fi, Do or Die
kscbob1's Avatar
Titusville, Fla
Joined Jan 2003
Any of these will knock your socks off in the speed department. They're depron pusher jets and they are very fast with a hot brushless motor.
Here's Steve Shumate aka jetset44s links.
http://www.rcgroups.com/forums/showthread.php?t=289276 F-15 Eagle
http://www.rcgroups.com/forums/showthread.php?t=308830 JAS-39 Gripen
http://www.rcgroups.com/forums/showthread.php?t=271581 FA-18 Hornet
http://www.rcgroups.com/forums/showthread.php?t=306817 T-38 Talon/F-5/F-20
Steve is very prolific and he is currently working on a F-14 if you don't mind waiting a little bit.
If that wasn't enough, Steve has inspired others to use his technique as follows:
http://www.rcgroups.com/forums/showthread.php?t=318369 A-6 Intruder
http://www.rcgroups.com/forums/showthread.php?t=297515 F4 Phantom II
http://www.rcgroups.com/forums/showthread.php?t=330458 SR-71 Blackbird
And for those who asked "Why not ducted?"
http://www.rcgroups.com/forums/showthread.php?t=305059
P.S. All of the above plans are free, you just supply your own 6mm Depron or 1/4" blue or pink fan fold foam(FFF).
P.P.S. Plans for the A6 and SR-71 are in the works and are not available yet. There are enough photos in both threads for the adventurous to make their own.
Bob
kscbob1 is offline Find More Posts by kscbob1
Old Feb 16, 2005, 04:34 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
==40 mph is actually pretty fast. It seems slow when you think about it but when measured with a speed gun you would be surprised.==
This man knows of that which he speaks! I own a speed gun and clock planes at fly-ins, most of the people are disappointed when they find out what their planes are -really- doing I have a little delta EDF that people were guessing flew 65+. BUT, fastest clock on it has been 52. The small size (16" wingspan) really makes it looks like it's moving. I have another little EDF that I just clocked at 60 2 days ago. The thing looks like it's going Mach 2 though
Regarding the topic at hand, HET-RC makes some nice little 3 channel balsa ARFs that are under 30" and can be quite fast on direct drive. Here are some links:
http://www.nesail.com/detail.php?productID=2856
http://www.nesail.com/detail.php?productID=2855
Tres Wright is offline Find More Posts by Tres Wright
Old Feb 16, 2005, 04:37 PM
Forney, TX
Joined Mar 2002
Oops, hang on, are you looking for 3 channel as in rudder/elev/throttle or aileron/elev/throttle? I assumed aileron as 40+ mph planes usually are.
can anyone recommend a moter for my shogun with Good power hihptsi Mini Helis 9 Sep 27, 2005 03:19 PM
Can anyone recommend a good, real looking Indoor flyer? Sport Flyer Parkflyers 6 Sep 25, 2004 06:21 PM
can anyone help me with a download Marcos Foamies (Kits) 2 Sep 27, 2002 12:27 AM
can anyone help me with Aspach GPS position?! henke Electric Plane Talk 5 May 27, 2002 11:41 AM
Can anyone recommend any SR X-250 Performance Improvements? p-zag Sport Planes 7 Oct 06, 2001 05:23 PM
