Old Feb 15, 2005, 09:43 AM
Yardbird's Avatar
Northford, CT
Joined Feb 2005
Can old Monokote be stripped off?
I am thinking about re-covering an old project and want to strip off the existing monokote.
Any problems with this? Thanks
Yardbird is offline Find More Posts by Yardbird
Old Feb 15, 2005, 10:12 AM
Milwaukee G Mitchell, Wisconsin, United States
Joined Mar 2002
just start peeling. Some might stick, but if you use some heat (heat gun) it will come off.
I just recovered my 20 year old Aquila. I had to use a heat gun because I used balsarite and it was stuck down verrrry well. It left some color in alot of spots but sanded smooth and covered with non-transparent stuff it was no big deal.
davekra is offline Find More Posts by davekra
Old Feb 15, 2005, 10:19 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I just recovered a wing myself.. depending on how well it's stuck, it can be a bit of a pain, and you need to be careful not to ding up the balsa too much. It's a 'while sitting in front of the TV' kind of activity..
..a
Old Feb 16, 2005, 02:56 PM
Yardbird's Avatar
Northford, CT
Joined Feb 2005
In front of the TV project, okay, that explains the magnitude of the job better than anything.
Tks Andy
Old Feb 16, 2005, 06:52 PM
jollyroger
Central Lake, Mi.
Joined Nov 2002
Peeling Monocote
I've removed alot of the covering and the one problem I've always had is the adhesive/color residue. I found that acetone will help to disolve the adhesive and make it easier to clean up. After that, some light sanding or filling and you're ready for your next finish. Good luck. John Z.
John Z is offline Find More Posts by John Z
Discussion can a gy201 be turned off in flight? jeff262 Mini Helis 4 Apr 04, 2007 01:03 PM
Question Can MonoKote be painted jhamm Scale Fuel Planes 4 Jan 17, 2007 06:24 PM
Can my ESC be fixed? mopar_man Power Systems 14 Aug 03, 2001 12:54 AM
Can a folding prop be used in pusher config? MtnGoat Power Systems 2 Jul 26, 2001 09:44 PM
