Old Apr 26, 2001, 06:32 PM
SFRCer is offline
Find More Posts by SFRCer
Los Angeles, CA
Joined Apr 2001
Sources for micro motors
Hello,
I noticed some of you Ezoners trying to find very small motors to power your small (13" span Peanut scale or under) models.
Smoovy and Namiki (Swiss and Japanese firm, respectively) are two large makers. New motors can cost as much as $100 from the smoovy site. You don't need to pay this. Look at the Solarbotics link and find one for a lot less.
Discount surplus electronics places like all electronics, digikey and solarbotics often have the same motors you end up paying ten times for in other places. Most micromotors are used exclusively in the PC hardware industry in Hard-drives, Magneto-Optical or ZIP drives and in some cases portable printers. If you can find some trashed drives, these may contain motors.
http://www.smoovy.com/products/syh39001.htm
http://www.namiki.co.jp/motor-e.htm
http://www.solarbotics.com/order/def...ON=CAT&CATID=8
SFRCer is offline Find More Posts by SFRCer
Old Apr 26, 2001, 06:38 PM
SFRCer is offline
Los Angeles, CA
Joined Apr 2001
Hello,
Just to give you an idea of how small these are... these are actual peas in the picture!
http://www.rmb-group.com/smoovy.com/psg_8.html
Old Apr 26, 2001, 11:22 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Cool! And are those gearboxes on the fronts to?
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 27, 2001, 12:05 AM
dmatking is offline
Find More Posts by dmatking
Fort Worth, TX, USA
Joined Sep 2000
They look very similar to pager motors?
David M. King
dmatking is offline Find More Posts by dmatking
Old Apr 27, 2001, 03:19 PM
SFRCer is offline
Los Angeles, CA
Joined Apr 2001
Yes those brassy or black colored cylinders in front of the motors are planetary gearboxes. The gearboxes come in a choice of 1:25 or 1:125 and have a 60~70% efficiency level.
The difference between these and the regular pager motors are that most pager motors will have a maximum voltage rating of 1.3v (only a single AA cell in a pager), whereas the smoovy ones will operate between 4~10v.
There are other spec sheets at the smoovy website and even a link to buy, if you prefer.
I've also seen a small motor (smaller than a pager motor) being sold by Northwest Short Line, the model RR vendor. Any model RR shop should have these.
Hope this helps,
Bill
Old Apr 27, 2001, 06:26 PM
Achim Stegmeier is offline
Find More Posts by Achim Stegmeier
Joined Dec 2000
The main difference between the smoovy motors and the regular pager motors is that the smoovy is brushless.
Achim
Achim Stegmeier is offline Find More Posts by Achim Stegmeier
Motor Constants & Static Tests For Micro Motors Gordon Johnson Scratchbuilt Indoor and Micro Models 25 Apr 13, 2011 08:40 AM
Thrust Stands for Micro Motors mharms Scratchbuilt Indoor and Micro Models 53 Oct 09, 2005 09:44 AM
Question sources for micro-gyros Steve Shepard BladeRunner Heli 0 Dec 18, 2004 11:52 PM
Motor Constants for Micro Motors Gordon Johnson Scratchbuilt Indoor and Micro Models 6 Feb 21, 2002 10:00 AM
Sources for Mega motors iflyelectric Power Systems 3 Jan 22, 2002 02:12 PM
