Old Feb 11, 2005, 10:36 PM
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
The Lockheed L-133
Okay who's gonna be first to build one then. Should be a doable aircraft as has generous wing area which includes the fornt wing set and it's also a twin.
Sluf7 is offline Find More Posts by Sluf7
Old Feb 12, 2005, 01:16 AM
WillowPtarmigan is offline
Find More Posts by WillowPtarmigan
Lagopus lagopus
WillowPtarmigan's Avatar
Houston Hobby, Texas, United States
Joined Jul 2003
Interesting design. Go for it!
WillowPtarmigan is offline Find More Posts by WillowPtarmigan
Old Feb 12, 2005, 02:16 AM
Sluf7 is offline
Sluf7's Avatar
Joined Feb 1999
The Shame was they had the engines for it with after burner in 1943 and it was canned.
Old Feb 12, 2005, 11:04 AM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
This is a beautiful plane - it's on my list of future projets as well. I wonder what the best way to build the blended wing & fuselage is?
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Feb 12, 2005, 02:11 PM
CRAZYPILOT is offline
Find More Posts by CRAZYPILOT
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
I would use vacuum shape'd pvc foam and fiberglas.
Kenneth
CRAZYPILOT is offline Find More Posts by CRAZYPILOT
Old Sep 09, 2006, 11:37 AM
kraaijer is offline
Find More Posts by kraaijer
Belgium
Joined Apr 2006
Long time that anyone posted, so I guess nobody dared
Well I just ordered the sharkit 1/72, and from there I will create an RC model.
I'm looking at a wingspan of about 1.8 meters and ducted fan. Fuselage will be glass, wings out of balsa.
If you're interested I'll do a build thread, but it won't start for another month or so when I finished investigating this machine.
If anyone has more information, plans etc, please let me know.
Cheers,
Ron
kraaijer is offline Find More Posts by kraaijer
Old Aug 13, 2012, 02:31 PM
52Sabre is offline
Find More Posts by 52Sabre
Avionics tech
52Sabre's Avatar
United States, MI, Grand Rapids
Joined Jun 2011
six years later. . .
Where we at with this? Anybody build one?
52Sabre is offline Find More Posts by 52Sabre
Old Aug 13, 2012, 04:07 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
We were waiting for you...
DanSavage is offline Find More Posts by DanSavage
Old Nov 06, 2012, 03:45 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Just a start
How about a 60" wingspan with a 90 mm fan. Scale FSA for intake would be 3.2 sq in.
p901P901 is offline Find More Posts by p901P901
Old Nov 07, 2012, 02:17 AM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
Look at frame 1:53
Planes That Never Flew - America's First Jet Fighter (49 min 57 sec)
there is something in what I thought was the intake is guns. In frame 1:59 there is a rectangular hole on the top. Is this the intake?
The model is from here http://www.fantastic-plastic.com/LockheedL-133Page.htm and does not have any intakes on the top
Old Nov 07, 2012, 03:15 PM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
EDF Location
I was going to use 1 90mm and use the forward gun area as an intake. But the intake duct would take up most of the forward section and locating the batteries is impossible.
Using 2 70mm fans there is a weird intake to fit for the 70mm fans. Using one on top would cause fan starvation when the nose is pointed up. So a additional duck was placed on the bottom. A lip was used also to get that ram air. If it was flush a vacuum would occurred from the air flowing across it. The lip can be reduced and a modified NACA duct used.
A whole new intake may need to be created, but would alter the original design.
Old Nov 07, 2012, 07:28 PM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
Lockheed J-37
The J-37 http://en.wikipedia.org/wiki/Lockheed_J37 was used in this plane.
The specs for the L-133 is here: http://en.wikipedia.org/wiki/Lockhee...L-133-02-01.29
Just found this http://www.up-ship.com/eAPR/ev1n4.htm of the layout of the plane.
Old Nov 07, 2012, 11:58 PM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
The front was both the intakes and for the guns . They ducted the intake around the sides of the cockpit. So the cockpit would be a good area for the batteries.
This is a weird intake to make. Will need to use the wheel well as a cheater.
Old Nov 08, 2012, 03:39 AM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
More progress
Still more mods to do. Here is some pictures
Old Nov 12, 2012, 11:20 AM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
Looks like a 90mm fan will not work and will have to use 70mm fans instead. The 90mm fan's intake would be up against the main wheel well and could not route intake. The 70mm fans will work but because of the intake routing around the side of the fuslage the plane needs to be scaled up 10%. Wing span will be 66". Ducting FSA is 3.25 sq" throughout and up into the fan.
Still working on updating drawings.
