Old Aug 04, 2003, 03:38 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Beta Build: Stevens Aero Groove Pt.5
edit:
This is part 5 of a great thread that has gone well over 2000 posts long now. To make it easier to read and search for info it has been split up into 500 post parts. Part 4 can be found here.
Keep up the great work People!
Greg Gallegos
Ezone Moderator
/edit
Originally posted by kepople
Correct me if I am wrong Bill, but these pants are worth the trouble, they weigh nothing, and thei coolest thing is the way they are designed, you dont have to use wheel collars.
They are even free standing...
Bill, I meant correct me about not needing wheel collars not if they were worth the trouble...They are definatley worth the trouble..
Kirby
kepople is offline Find More Posts by kepople
Old Dec 21, 2004, 08:37 AM
tommy321 is offline
Find More Posts by tommy321
Glow Free Since Aug, 2005
tommy321's Avatar
Ottawa, Ontario, Canada
Joined Aug 2004
Hey Beagle,
Do the pull pull. After you're done, you'll never go back to long pushrods again. I find they seem snappier and have less play than pushrods. I think that one trick is to select a servo head that has the same diameter as the control horn you're using. This will keep the two lines as close to parallel as possible. That way there will be very little slack in the "limp" line when the you deflect the surface.
Regarding CG, I had gotten the impression that people were having to move batteries far aft in the battery bay when using the 2808. So I went with a rear mounted elevator servo, and I mounted my rudder servo on the bottom of the fuse about 5 inches aft of the stock position. (See my pics in the previous posts). I find I need to place my battery (Apogee 2480 (~5.5oz)) right at the front of the battery compartment to get the CG at the aft edge of the spar. I'll probably slowly move it aft as I get more flights on the plane.
Long story short, if I were to do it again, I'd go with rear mounted elevator servo, and probably my rudder mounted inside the fuse.
Tom
tommy321 is offline Find More Posts by tommy321
Old Dec 21, 2004, 08:59 AM
doc-e is offline
Find More Posts by doc-e
Live to fly!
doc-e's Avatar
United States, NJ, Fair Lawn
Joined Nov 2002
Tom
Ditto!
doc-e is offline Find More Posts by doc-e
Old Dec 21, 2004, 09:20 AM
tommy321 is offline
tommy321's Avatar
Joined Aug 2004
Originally Posted by mexico
Is it hard to setup the Pulls inside the fuse once the top deck (aft of cockpit) is sheeted? Seems like it makes access to the guide tubes almost impossible.
What if you string something through there before you sheet and secure it with some masking tape at each end. Then when you're ready for your pull pull you attach the pull pull thread to your string and pull it through. Only catch is you only get one shot at it. Depending on the size and number of holes you have to get it through, you can sometimes use a 0.032 pushrod to string stuff through the fuse.
I used the string trick for doing aileron servos in the wing panels. Tape string somewhere that you can reach it through the servo hole with tweezers. Then cover without the servos installed. When complete, use the string to pull the servo wires through.
Tom
Old Dec 21, 2004, 02:58 PM
mexico is offline
Find More Posts by mexico
mexico's Avatar
NJ
Joined Aug 2003
Tom
If you suggest running string or thread through the guides prior to sheeting as a means of pulling the actual pulls through later why not use the actual pulls now and save the step of hoping to fish them through later?
mexico is offline Find More Posts by mexico
Old Dec 21, 2004, 04:38 PM
daking is offline
Find More Posts by daking
PRO BRO #157
daking's Avatar
Sterling hts, Michigan
Joined Jun 2003
edit:
This is part 6 of a great thread that has gone well over 2500 posts long now. To make it easier to read and search for info it has been split up into 500 post parts. Part 5 can be found here. The last page is here
Greg Gallegos
Ezone Moderator
/edit
Ok...
MEX.............. Your trying to to put a stick mount in your groove. right? I used the circle on the firewall to line up the output shaft of the gear box. Lined up perfect. Just make sure to add o down thrust and 2 or 3 deg right thrust !! It's a bit harder to change it later.
Flyingbeagle......I have a mega in mine(2.7 oz). Then the added weight of the Cobri GB. I was a little worried about being nose heavy so i put my servo's in the tail. I had to make a new plate for the rear so i could mount both servo's back there. One on each side. Nice short linkage and the plane balance's 1/8 inch behind the spar with the back of the pack(tp 2100) at the back of the batt plate!
I made my first decal set !!! Not too bad but still a little fuzzy. They look good from a foot or two. Here are a few detail shot's of what i am talking about.
daking is offline Find More Posts by daking
Old Dec 21, 2004, 04:46 PM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Daking, where do you place your battery to balance it with the mega up front in the cobri GB and rear mounted servo's? I had a g-480 w/ mega 16/15/3 but i used a 2.1oz all metal planetary GB to avoid having to fashion a stickmount; was way too heavy.
headless is offline Find More Posts by headless
Old Dec 21, 2004, 04:57 PM
daking is offline
PRO BRO #157
daking's Avatar
Joined Jun 2003
The plane balance's 1/8 inch behind the spar with the back of the pack(tp 2100) at the back of the batt plate.
Old Dec 21, 2004, 05:42 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
Originally Posted by daking
Ok...
Sort of a stick mount. It is the Cobri flush mount. Like an aluminum stick attacked to a mounting plate.
Does the laser cut AXi mount have 2 or 3 degrees right thrust designed into it?
Old Dec 21, 2004, 06:55 PM
FlyBoyKB is offline
Find More Posts by FlyBoyKB
FlyBoyKB's Avatar
USA, OH, Cincinnati
Joined Dec 2003
Another Groove ready for covering! We're going away for Christmas so I won't get a chance to do much on it until next year now. The plane was my Christmas present from my wife so I can't finish it before Christmas. Thanks for everyones help and advise. And - Merry Christmas and Happy Holidays to all.
FlyBoyKB is offline Find More Posts by FlyBoyKB
Old Dec 21, 2004, 07:18 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
Looks great. Love the spinner. I am finishing up the fuse. Just wet the sheeting for the battery hatch.
Old Dec 21, 2004, 08:17 PM
daking is offline
PRO BRO #157
daking's Avatar
Joined Jun 2003
The plane is built with 0 right thrust but, you will need some.
You might have to add some wood to the firewall for the bottom two screw's on that flush mount. I think it would be easyer to just make a mount like fredn or i did. Save that mount for a solid firewall.
Flyboy......Nice job!
Are you gonna sheet the top? I wish i had done mine! I dont like the look of the hatch to nose joint with just the stringer's.
Dennis
Old Dec 21, 2004, 10:21 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
Dennis
If the plane is built with 0 right thrust why will "I" need some? Has Doc-e been showing people video of me flying?
BTW - Doc- I sheeted the battery hatch and the deck just aft of it tonight. Looks incredible. Like a fine piece of furniture. The more I sheet the less I want to cover up the wood. Stain with some clear covering on the fuse?
Old Dec 21, 2004, 11:06 PM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
[QUOTE=mexico]If the plane is built with 0 right thrust why will "I" need some? [QUOTE]
To correct for spiral slipstream, of course... haven't you been reading? Seriously, I would add 2 degrees of right thrust, in fact, I did
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Dec 22, 2004, 07:01 AM
doc-e is offline
Live to fly!
doc-e's Avatar
Joined Nov 2002
Do you want me to? I can post them in a heartbeat!
The Groove AXI mount does not nave any right/down thrust built into it. I find that my Groove needs its rudder offset to the right to compensate. Stella, on the other hand, has the right/down thrust built into the AXI mount and the stick mount...
Beta Build: Stevens Aero Groove Pt.7 headless Sport Planes 2240 Nov 23, 2013 03:12 PM
Beta Build: Stevens Aero Groove Pt.6 P-40 Sport Planes 499 Mar 31, 2005 02:53 PM
Beta Build: Stevens Aero Groove Pt.4 kepople Sport Planes 500 Dec 21, 2004 09:04 AM
Beta Build: Stevens Aero Groove Pt.3 kepople Sport Planes 501 Oct 06, 2004 09:20 AM
Beta Build: Stevens Aero Groove Pt.2 Jim McPherson Sport Planes 496 Apr 07, 2004 10:34 AM
