| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Looking for CNC Mill Part II
Continued from the previous:
http://www.rcgroups.com/forums/showthread.php?t=62920 Let's keep this one more civil please. Remember, we are all here to help and learn. Steve |
#2 |
Team Black Magic
Continued from Part 1
Oz..thanks for the info. I have a Xylotex sitting on the bench right now and have been following the Xylotex users group on Yahoo, but thought I'd ask the question here. It is supposed to run the Biploar motors I bought so that's why I got it. I also saw somewhere that 24v @ 6 amps is what I should use as a PS for it. So now I need to build or buy one of those....My hobbies are going to get me in trouble with my wife one of these days. If anyone else has any input on Xylotex please let me know. |
#3 |
Model Bender
I used a 3axis and a single axis xylotex for about a year before all the chips mysteriously died in unison when I switched on my controller. They are difficult to repair without special equipment (PLCC chips) It worked very well up until then though.. 24V is an ideal voltage for the xylos and although maxed at around 30V I think that's pushing them a bit hard.
For the psu a conservative rating of 1.5X the current each motor draws is a good start. I was using 4V 1.5A motors, they barely got warm and had a decent rpm's when driven by @ 24V. ... just promise to make things for your wife when your machine is finished
#4 |
It's been a while.
I just finished reading the first thread
lots of information. I was wondering how long it takes on average to build your machines. I also downloaded KCam and TuboCNC and have been playing with them. I noticed that when I import a dxf or gcode into KCam the part is always off the grid. Is this normal? |
#5 |
Bleriot's R Us
This has happened to me too, I have only just started trying it out as well, there is a Kcam forum on the CNCzone site as well if you don't get an answer here.
#6 |
It's been a while.
I'll have to check that forum out. Thanks.
#7 |
Model Bender
The grid origin is at 0,0. I quickly tested that theory with a small part (centre of the middle circle is at 0,0) and it worked ok. Couldn't resize the grid however!
I think KCam is drawing your part correctly, check your part co-ords in your cad program, looks like the Y is offset to the negative side a little. I haven't used KCam for years, as it seemed very jerky when I tried it (I think it's written in Visual Basic?) so my experience with it is still very limited. Last edited by OzDragonFlyer; Feb 13, 2005 at 03:46 AM. |
#8 |
Hi all, welcome to the new thread
![]() Is there anyone here who has experience with the linistepper control boards? They state that they are for unipolar motors only. But you can run bipolars in unipolar mode too, right? Or was it the other way around? |
#9 | |
Unicorn
#10 | |
It's been a while.
#11 |
It's been a while.
Ok, I have started to build a CNC router using a Rotozip for the spindle. My question is, what stepper motors are ideal for this application. I have been looking at stepper motors, but there are so many of them I am not sure which ones are applicable to this type of project.
#12 |
Bleriot's R Us
There are so many different types out there.
It is all down to the size of the machine, but for a normal DIY CNC that most of the guys are building, look out for size 23 motors (56mm dia) rated about 1 to 2A with a voltage of 2-6v. These can be picked up fairly easily, check out ebay or old dot matrix or laser printers, photocopiers. |
#13 | |
It's been a while.
#14 |
Model Bender
The older (circa mid 80's-90's) large 24 pin dotmatrix printers are a great source for approx 4-5V @ 1A steppers. These are usually 1.8 degree per step as well compared to the later 7.5 degree units. A conservative rating for these motors would be 60-70 oz/in depending on when they were made.
Also look for architectural plotters, getting 3 or 4 of these will enable a rudimentary machine to be made pretty quickly. happy hunting! |
#15 |
Bipolar Unipolar discussion
http://209.41.165.153/stepper/
Link to above and select tutorials on a menu on left side.(in green) FWIW DaveP kywoodwrkr |
| Thread Tools | |
| Looking for CNC Mill Part I | PanzyPoof | The Builders Workshop | 2427 | Feb 09, 2005 07:26 PM |
| Looking for CNC Mill - thread relocated | Andy W | The Builders Workshop | 0 | Feb 02, 2005 04:02 PM |
| Looking for Triffik or Adrenalin II | Aeronut | Aircraft - Electric - Airplanes (FS/W) | 6 | Aug 04, 2004 12:05 AM |
| Looking for a helicopter spare part | David Rodriguez | rec.models.rc.helicopter | 1 | Jan 18, 2004 07:02 PM |
| Looking for a CNC 4 AXIS FOAM CUTTER | A.D. | Power Systems | 3 | Nov 13, 2001 03:44 PM |
