San Antonio, TX, USA
Joined Jan 2001
Once I used a 18Ah gel cell for small packs (8x500, etc). It went bad pretty quick.
Now, I use a 125Ah Marine deep-cycle battery mounted in a ply batt box on a small hand cart. Easy to move around. Batt box has fused/switched cig outlets, a small inverter for AC when needed and heavy cables for jump starting cars. It handles all day at the field with samll and large packs (12x3000) just fine. I get tired before it does. The hand cart works great on hard surfaces but if I were doing it again I would use larger/wider tires for easier rolling across a gravel parking lot. IMPORTANT NOTE: Keep a lead-acid battery used as an eflight power source on a battery maintainer of the correct type (as per cell type) and with pulse circuitry. Search the Northern Tools site for the SureCharge IV for the one I use. If it is a flooded cell check the water about every 3 monthes (use distilled, not tap, water). My batt is 3 years old with no sign of degraded performance. http://www.northerntool.com/cgi-bin/...6&prmenbr=6970 |
| Thread Tools | |
| Discussion Dose Align Battery work for T Rex?? | Son House | Mini Helis | 0 | Dec 29, 2005 06:57 PM |
| Will this battery work for the HB CP2? | Rocketman1092 | Micro Helis | 4 | Sep 29, 2005 03:08 PM |
| Would this cheap tyrco r/c battery work for projeti? | seanpr123 | Foamies (Kits) | 14 | Nov 19, 2002 01:10 PM |
| Lawn Mower Battery Amps | Ghostbear | Beginner Training Area (Aircraft-Electric) | 5 | May 25, 2002 08:57 AM |
| Lawn mower battery source? | temacc | Electric Plane Talk | 3 | Nov 10, 2001 11:30 PM |
