Old Feb 07, 2005, 11:56 PM
squidbait is offline
Find More Posts by squidbait
Zzzt! Buzz! Click!
squidbait's Avatar
State of Confusion
Joined Jan 2004
How do you know if your ESC's really dead?
OK, up until now, my ESC ( E-Flite EFLA105) has been working fine in bench tests. Today, I closed up the plane after getting everything where I thought it should be. I tested the motor, and it ran for a couple of seconds as I eased the throttle forward, and then quit. I opened up the plane, and everything else is working fine, and the motor (speed 400) works fine when I apply direct power to it.
No smoke, no scorch marks, no hint of what might have gone wrong. The only thing I can see is that the motor leads might have shorted because instead of taking the time to put proper bullets on it, or just solder it directly to the ESC, the spade connectors were sticking a bit out of the rubber boots.
Is it done? Just write it off and get a new one? Or are these things fixable?
squidbait is offline Find More Posts by squidbait
Old Feb 08, 2005, 12:17 AM
netmechanic is offline
Find More Posts by netmechanic
Watts the Point
netmechanic's Avatar
KY,USA
Joined Jul 2004
Hack open the Shirnkwrap and see if you have any cooked components, Most speed controllers will still run the radio equipment even when cooked. Also give it the sniff test, cooked controllers give off a very distinct smell
P-U
netmechanic is offline Find More Posts by netmechanic
Question Installed my ParkBEC, how does it look? Q: How do you know if it's working? eckcessive Power Systems 5 Feb 09, 2007 11:36 PM
How do you know if the motor is still ok after a crash? Magna Electric Plane Talk 1 Aug 08, 2003 11:00 AM
How do you know when your motor is toast American Flyer Parkflyers 12 Jul 08, 2003 02:28 PM
how do you tell when your motor's going bad waagbuck Parkflyers 10 Sep 23, 2002 09:21 PM
How do you know if your ESC is fried? Tres Wright Parkflyers 3 May 16, 2002 09:19 AM
