Old Feb 07, 2005, 06:16 PM
mcoccia is offline
Find More Posts by mcoccia
United States, NJ, Raritan Township
Joined Dec 2004
BEC, SBEC & UBEC Difference Between Them
I am interested in trying a separate battery to run all my electronics but I have no idea what the difference is between BEC, SCEC & UBEC. Could someone help me with this topic?
Thank you
Mark
mcoccia is offline Find More Posts by mcoccia
Old Feb 07, 2005, 06:56 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Not sure I fully understand the question as when using any type of BEC, (Battery Eliminator Circuit) you negate the need for a seperate battery. One of the many advantages to electric IMO.
BECs onboard an ESC ( most ESCs have them) are only rated for x number of cells and y number of z type of servos. Exceded either the voltatge or servo count, and you can not use the onbaord BEC. ( well you can for about 2 minute ) The Ultimate BEC (UBEC) is external to the ESC. You disable the ESCs BEC. The input to the UBEC is connected to the battery ahead of the ESC, and the output of the UBEC is plugged into the battery slot ( or any unused one) of the receiver and it acts like an onboard 4 cell pack, but without the weight, and extra maintainance associated with the extra pack.
Not sure what a SCEC is.
rcav8r2 is offline Find More Posts by rcav8r2
Old Feb 07, 2005, 06:59 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Obviously all three are BECs- Battery Eliminator Circuits.
The purpose of any BEC is to take the batter at say X volts, and convert it to 5 volts to operate the receiver and servos.
By using one you can eliminate the separate small receiver pack.
The standard BEC is a linear voltage regulator integrated circuit, or often two or more in parallel to increase the current capacity.
It functions by dropping the excess voltage across the device. The problem is that as you add cells the input voltage X increases and the power that the BEC has to absorb rises. This can cause it to overheat, leading to thermal shutdown. This is bad, since you will lose all voltage to the radio and servos until it cools down.
The practical limit is 10 or 12 round cells, although with adequate cooling 14 is sometimes possible.
The SBEC and UBEC both are switching voltage regulators. They work by taking pulses of energy from the battery, store it in an inductor and/or capacitor,
and then release it to the receiver at a lower voltage, in this case 5 ( or 6 ) volts.
The advantage over a linear regulator is that there is very little energy lost, so they will stay cool with inputs up to 40 volts.
In some cases the switching noise can cause interference with the receiver, but careful component placement can prevent that.
Hope that helps
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 07, 2005, 07:06 PM
mcoccia is offline
Joined Dec 2004
Hi,
Thank you. What happens to ESC wire that plugs into the RX then? It just hangs thier loose? I have been having a problem where my Gyro shuts down in flight and I have heard it is more effiecient to run some type of battery elim circuit to power my electronics is this true?
Mark
Old Feb 07, 2005, 07:22 PM
pmackenzie's Avatar
Joined Dec 2002
If your ESC has an onboard BEC and you decide to use an external battery,BEC, UBEC or SBEC, you have to disable the BEC in your ESC.
This is easily done by removing the red wire from the 3 pin ESC connector. You still need the other two to send control signals to the ESC.
Having said that, gyro shutdown is not normally related to BEC problems. You might just have a bad gyro or tail rotor servo.
Could you give more details of your setup?
Pat MacKenzie
Old Feb 07, 2005, 07:30 PM
mcoccia is offline
Joined Dec 2004
Pat MacKenzie
Hi,
Sure here are the details:
Trex450X
CC35
4 Hitech Hs 56 Servo's
Futaba Gy401
TP 2100MAH 3S Pack
Berg 6 Channel RX Version 3
Ferrite Ring Interference eliminator
Old Feb 07, 2005, 07:43 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
3S is too much for the CC35 onboard BEC.
You need to run an SBEC probably. The UBEC is a lot larger and heavier than the SBEC.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 07, 2005, 07:44 PM
pmackenzie's Avatar
Joined Dec 2002
Did you get a rcvr pack with your radio?
If you have or can borrow one, try it and see if it solves your tail problem. If it doesn't, there is something else wrong.
Be sure to disable the BEC as explained above.
Pat MacKenzie
Old Feb 07, 2005, 08:02 PM
TMorita is offline
Joined May 2002
If you read the EHBG, you'll see the specs for both the UBEC and the SBEC in it.
Look in "Helicopter Parts Selection" and then "BEC".
Picture of the UBEC and SBEC. White blob mounted on the Raptor is the UBEC. The tiny circuit in the package is an SBEC.
Toshi
Old Feb 07, 2005, 09:35 PM
mcoccia is offline
Joined Dec 2004
Toshi
Toshi,
Thank you for your input but I know/see there are several people who run this setup and don't have any issue's, I am not questioning your experience but before I spend more money how can I be sure that adding a SBEC will Solve my problem? I also have the Corona with the CC45 and gy240 and I have the same problem "Sometimes" the commonality here for me is the CC products without a doubt. I looked at Castle's website and did not see specs for thier BEC as far as Volt/Amps would you have an idea?
Old Feb 07, 2005, 09:49 PM
pmackenzie's Avatar
Joined Dec 2002
Mark,
if you go to the CC website, click on the "Documents" tab and you can download the manual for the CC35.
The BEC is rated 3 amps, but on 10 cells they only allow 4 micro servos or 3 High torque servos.
So a Hornet with 4 x HS50 works fine on 3S, but 4 HS56 on the same 3S might be a bit too much.
I still wonder if your tail problems have some other source. BEC shutdown is usually quite dramatic.
The motor will stop and the helicopter will stop responding to any input.
Pat MacKenzie
Old Feb 07, 2005, 09:59 PM
mcoccia is offline
Joined Dec 2004
Mark,
Pat MacKenzie
Pat,
Yes I agree everything else is working at the time but the Gyro.
Let me describe exactly what happened maybe I am confusing everybody.
Trex in the air about 25ft 2 minutes into flight suddenly tail would just spin out of control happened 3 times I would have manually try and hold the tail with rudder input to get it down safely. Last night in my garage I was hovering and saw the Solid LED on the Gy401 goto Blinking which is non HH mode then I crashed it. Now this has also happened on my corona I will list the specs for that below.
Corona Setup:
CC45
2- Hitec HS-85MG Micro Servo
1- hitec hs 81 For Tail
Berg 6 channel RX Version 3
8 cell gp3300
Mega 16/15/3
Gy 240 gyro
Old Feb 07, 2005, 10:03 PM
mcoccia is offline
Joined Dec 2004
So since I am using a 3s2100 pack this would equal about 12 cells is this correct? I probably did not take this into consideration.
Mark
Old Feb 07, 2005, 10:04 PM
TMorita is offline
Joined May 2002
Originally Posted by mcoccia
Toshi,
Simple.
Run the T-rex for an entire pack, then land and put your finger on the BEC chip on the ESC. If it's burning hot, then you're overloading it.
I've used linear regulators such as the LM7805 to power digital circuits, and they're normally used to regulate 8 volts down to 5 volts. Consider that:
1. A linear regulator drops N volts down to 5 volts by wasting the excess power as heat,
2. An LM7805 is in a TO-220 package which is about three times larger than the surface-mount regulators used on the Phoenix series, so the LM7805 can dissipate a lot more heat,
3. An LM7805 is typically used for regulating 8 volts down to 5 volts @ 1 amp, so it's dissipating 3 watts as heat.
4. The tiny surface-mount regulator on a CC Phoenix is regulating ~12 volts down to 5 volts @ ~2 amps, so it's trying to dissipate 14 watts
So basically, the surface-mount regulator is trying to dissipate about 4x the amount of heat in a package that's 1/3rd the size of an LM7805.
Toshi
Old Feb 07, 2005, 10:15 PM
mcoccia is offline
Joined Dec 2004
Simple.
Toshi
Toshi,
I know you are very smart but you lost me and your info means quite a bit to me. Yes As I remember the ESC was hot don't know how hot though in fact I can have the bird sitting on my table with all electronics on and just playing with the controls on the TX and the ESC would get very warm. So then this is not a good setup then?
Could I invest in better controller would that solve my problem?
Discussion BEC or UBEC... what's the difference? flymeaway Power Systems 4 Mar 23, 2007 09:09 AM
Difference between 6v and 7.2v speed 400 engines??? soholingo Beginner Training Area (Aircraft-Electric) 13 Jul 20, 2001 10:50 PM
Is there a difference between the CP1700 and 1700AE cells? razzor7 Electric Plane Talk 23 Jun 28, 2001 06:38 PM
What is the difference between JR and Hitec servos foam_man Beginner Training Area (Aircraft-Electric) 1 Jun 25, 2001 07:38 AM
What is the difference between the Jarma480 & the Multiplex480? Scott C Electric Plane Talk 1 Jun 20, 2001 07:32 AM
