Old Feb 05, 2005, 12:34 PM
RC-Nut-Job!
Lv2Fly's Avatar
New York
Joined Jul 2001
Why Does this happen when I use my Orbital-Pro 6.3
Hi...What do you think might be the problem.
My Orbital-Pro 6.3 works 100% when I'm connected directly to a battery sorce. No problems....
But when I connect it to my MFJ 25 amp Switching power supply it shut 's the power supply down apone trying to turn on the Orbital-Pro 6.3 unit.?
My Older Orbital 6.2 works fine it does'nt shut the power supply down at all...
I'm a little confused here...
The power supply if fairly new and it handels 25 amp with out sweating....
Hum, it seems like it's shutting my power supply down as if it were imediatly over loading it...?
Any ideas..as this unit works fine when connected directly to a battery.
Any help or suggestions would be great..Thanks..
James...
Lv2Fly is offline Find More Posts by Lv2Fly
Old Feb 05, 2005, 12:50 PM
Huntington Beach, CA
Joined Dec 2004
Have you checked the output voltage of your power supply? If the voltage on the power supply isn't above a certain point, the charger may want to shut down.
TMetalMan is offline Find More Posts by TMetalMan
Old Feb 05, 2005, 12:52 PM
RC-Nut-Job!
Lv2Fly's Avatar
New York
Joined Jul 2001
Metal...yes I did I can even adjust it....I can go from 1volt to 18volts...I have it set at 13.8....
thanks for that input....
Question why does this happen beginningdave Beginner Training Area (Aircraft-Electric) 16 May 20, 2005 09:15 PM
Why does this happen? Lammergier Power Systems 4 Oct 05, 2004 10:49 AM
Tamiya Mad Fighter - Why Does This Happen? Helicool Off-road Cars 0 Jul 06, 2004 08:38 PM
WHY DOES THIS HAPPEN TO ME!need help,P-51 related!HELP! bassplay Parkflyers 6 May 28, 2003 06:15 PM
Yippee! my tm likes to attract attention, does this happen to anyone else Pablito Parkflyers 15 Feb 12, 2002 04:22 PM
