Old Feb 05, 2005, 10:04 AM
FlyHoppefly is offline
Find More Posts by FlyHoppefly
Joined Feb 2005
Rant
Burnt up about Burnt out rudder(tail Motor)
Help!!!
In the last week I have burnt out two brushless tail motors on my GWS-Dragonfly. Do I need to go to a different motor or buy a gross of the Dragonfly motors.
FlyHoppefly is offline Find More Posts by FlyHoppefly
Old Feb 05, 2005, 10:36 AM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
I assume you mean brushed motors? What batteries are you running? Also what mixer board? My Pha01 was notorious for burning up tail motors on any voltage more than 8.4!
skeppley is offline Find More Posts by skeppley
Old Feb 05, 2005, 10:42 AM
Joined Feb 2005
Skeppley:
You are right about the PHao1, and they are brushed motors. But what do you recommend as a solution.I am using 7-cell batteries that came with the Dragonfly
Old Feb 05, 2005, 11:17 AM
spit-boy is offline
Find More Posts by spit-boy
spit-boy's Avatar
CA
Joined Aug 2001
I know that pain.
I built several hummingbirds before getting fed up with burnt out tail motors. I was using 3-cell lipo instead of 2 though. They are quite reliable on 2 cells. However, even on 2 cells I was never fully satisfied with the tail control - particularly with sudden throttle increases.
Then went to a zoom, which had plenty of tail drive-shaft & gear problems.
Then converted it to belt drive - much better.
Then went to the trex as it already has a belt drive.
Seems I'm always switching helis because of tail control problems!
-Jonathan.
spit-boy is offline Find More Posts by spit-boy
Old Feb 06, 2005, 11:59 PM
LittleBird is offline
Find More Posts by LittleBird
Madison Truax Fld, Wisconsin, United States
Joined May 2004
FlyHoppefly I hear you!!! Im looking into a hornet2 cuz im sick of it too!! Good luck...JP
LittleBird is offline Find More Posts by LittleBird
Old Feb 07, 2005, 12:00 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
If you use a high frequency ESC the tail motor should last a lot longer.
See the EHBG for a list of high frequency ESCs.
Toshi
TMorita is offline Find More Posts by TMorita
Old Feb 07, 2005, 05:54 AM
Joined Feb 2005
Thanks to all MicroHeli's for you knowledgable advise. I have decided to try a double motor setup. As I was advised that it will split the duties in half, which in thery should reduce the tail motor burn out. Again thank you for your advise
Old Feb 07, 2005, 10:31 AM
spyder6166 is offline
Find More Posts by spyder6166
I thought it was charged!
spyder6166's Avatar
Westchester County
Joined Jan 2005
Looks like I have just burned my tail motor out also. Just stopped working. I tested with a meter and it has juice goin back there. I have about maybe 6 hours on this stock motor. Using a NiMH 8.4V. Also a 4 in 1 board. Funny thing was that I have had an issue before where the heli would get possessed and do what it wanted. I have not got a decent hover yet. But yesterday it decided to go beserk and it shot up in the air and it acually hovered there for about 10 seconds (perfect) with out my help.go figure.lol then when it decided to let me have control back it shot into the ceiling then into the wall. I hate this Dragonfly clone!! but then after that tail motor went caput. Nothing broke on the heli! =(
spyder6166 is offline Find More Posts by spyder6166
hummingbird tail motor burnt out, what now? adr_ian64 Micro Helis 5 Mar 25, 2005 12:13 PM
burnt up about burnt out rudder tail motors FlyHoppefly Micro Helis 47 Feb 19, 2005 02:32 AM
HB V3 tail motor finally burnt out jhc1- Micro Helis 0 Jan 11, 2005 01:17 PM
Help! Feda tail motor burnt out... An-Lone Micro Helis 4 Jun 30, 2003 03:09 AM
Tiger Moth Fun. Tested new 600mAh battery. Burnt out S2 IPS motor. LESLIEx317537 Parkflyers 3 Feb 20, 2003 08:37 AM
