Holland
Joined Dec 2002
Actually, I do use a WES 8x4 prop on the 11 gram Strecker motor on a 3s Irate 300 pack in my "Shockwave" design. As usual the performance data of the Strecker motors are very conservative. On a typical 3D aircraft where full power is only used in short period bursts and the motor sits out in the prop wash you can almost double the maximum power rating. The great thing about these motors is the very broad power range and efficiency.
I have resurected my Quick Citabria. When it last flew it had one of the early RFFS conversions to 2-cell opertion by Matt Keennon. It used two LiPolys and a M20-MV at 6.7:1 and a 5x3 3-bladed CF prop. Unfortunately a radio glitch sent it into a wall at considerable height and it fell to the floor in pieces.
I've put it back together with a new wing pylon, a longer tail moment, and most importantly equipment to use it as a test bed for micro BL outrunners. It has the new JMP servo RX that uses a separate ESC, a BSD lightened CC Phoenix 10 BL controller, and two Falcon servos. Batteries are either a 145x2 or 170x2 LiPoly pack, depending on the motor used. I machine a wooden adapter for each motor that presses snugly on the CF tube fuselage. This allows swapping motors at the flying site. And, since all the equipment is out in the open it's also easy to swap, say, BL controller from a 2-cell unit to a 1-cell unit like the Heino Young YGE4 BL. Tomorrow night I'll fly it with the Gary Jones Mini Disc BL from Bob Selman, and also with Uttam's 2-cell Micro Midget motor. Should be fun. Gordon |
Well the Quick Citabria flew great. How could it not fly great with so much thrust relative to its weight. With the MiniDisc motor the all up weight is 43.5g, about the same with the Mightly Midget as I added clay to the nose to balance with that lighter motor. With either motor the plane has abundant power and flys at about 40% throttle. Stall turns are easy, and there is lots of power on tap to get out of trouble. All in all it shows how much fun planes based around these motors will be.
Gordon |
| Thread Tools | |
| Help me decide on brushless motor test protocol | ScienceGuy | Power Systems | 7 | Apr 25, 2004 11:39 AM |
| Survey- New Micro Brushless motor | fill | Parkflyers | 70 | Jan 10, 2003 12:51 PM |
| Survey- New Micro Brushless motor | fill | Indoor and Micro Models | 0 | Jan 31, 2002 11:52 AM |
| Pager motor test results | epilot | Indoor and Micro Models | 3 | Dec 29, 2001 01:49 PM |
| mighty micro brushless motor and 2 escs F/S | misskimo | Aircraft - Electric - Airplanes (FS/W) | 1 | Nov 30, 2001 07:24 PM |
