Old Apr 20, 2001, 01:22 PM
jdmartin8 is offline
Find More Posts by jdmartin8
New Haven, Indiana, USA
Joined Apr 2001
What battery charger do you use?
Could someone please recommend a good charger for NiMH and NiCD batteries? I need to charge my 250mah and 600mah packs. Not so much interested in quick charging, but peak detection is a necessity. What is everyone out there using?
jdmartin8 is offline Find More Posts by jdmartin8
Old Apr 20, 2001, 01:41 PM
columbiarcdude is offline
Find More Posts by columbiarcdude
columbiarcdude's Avatar
St. Louis, Missouri
Joined Oct 2000
Astroflight 110D
columbiarcdude is offline Find More Posts by columbiarcdude
Old Apr 20, 2001, 01:42 PM
PunkerTFC is offline
Find More Posts by PunkerTFC
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
for those sizes, i would highly suggest a Jeti Mini Peak Charger (about $30 from hobby-lobby.com). It's the charger that I use. it charges great, and will handle both sizes you want. it will do NiMH packs, but the technique is a little bit different. it is explained in the manual. for Nicad packs, it will charge anything from 50 to 800 mAh, and for NiMH packs, it will charge from 300 to 1500 mAh. the NiMH packs will take an hour to charge, as they have to charge at a rate equal to their capacity. but it'll charge up a nicad pack pretty quickly. And, as the name points out, it does have peak detection, and it switches to a 15 mAh trickle charge once it reaches the peak
Punker
PunkerTFC is offline Find More Posts by PunkerTFC
Old Apr 20, 2001, 01:44 PM
Frank Hurd is offline
Find More Posts by Frank Hurd
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
I used the Simprop Intellicharger for nicads and nimh cells. It's made for various outlets such as FMA, Hobby Lobby, etc. It will meet your needs now and in the future.
Frank Hurd is offline Find More Posts by Frank Hurd
Old Apr 20, 2001, 02:01 PM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
I use the Hitec CG-335 DC-DC Multi Purpose Charger w/ Digital Display. Just turn the current down to min. (500mA) for all my Slow Flyer packs (110mA-350mA)
http://www.hitecrcd.com/Catalog/Chargers/cg335.html
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Apr 20, 2001, 02:11 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I have 2 Orbit chargers that will do ANY type battery pack.
I also have a Dymond mini charger that does up to 8 cells and is very compact. It is the same as the Multiplex. They are around $40.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 20, 2001, 07:55 PM
BobK is offline
Find More Posts by BobK
Rhode Island
Joined Oct 2000
I have a Hitec CG-335 and an Astro Flight 110D and they're both great chargers.
If you're not quick charging why is peak detecting a necessity?
BobK is offline Find More Posts by BobK
Old Apr 20, 2001, 08:07 PM
SLOW CRASH is offline
Find More Posts by SLOW CRASH
USA
Joined Jan 2001
Remeber if your using a Jeti Peak charger you'll have to get a 12V source.
SLOW CRASH is offline Find More Posts by SLOW CRASH
Old Apr 21, 2001, 03:44 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Hitec CG335 and a Simprop Intellicharger.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Apr 21, 2001, 05:21 AM
Norman Adlam is online now
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Hitec CG335 for the bigger packs (500ma to 2400ma), and Jeti mini charger for packs 110ma - 800ma
Norman Adlam is online now Find More Posts by Norman Adlam
Old Apr 21, 2001, 05:40 AM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
All the above chargers require a 12v source. Almost any peak charger will allow you to set the current. How long you wish the charge will take will be up to that and the discharge of the pack.
Old Apr 21, 2001, 05:49 AM
Achim Stegmeier is offline
Find More Posts by Achim Stegmeier
Joined Dec 2000
I'm using a Schulze isl6-430 and a Robbe PowerPeak Infinity 2.
Quick charge is of no interest as long as you don't want to use them for e-flight. The current you get out those battery packs is related to the charge rate. I.e. the very same battery pack fast charged will give you a better flight performance than charged in 14h.
The other point is that there is no sufficient delta-peak with low current ( i.e. normla charge ), esp. with small cells.
Achim
[This message has been edited by Achim Stegmeier (edited 04-21-2001).]
Achim Stegmeier is offline Find More Posts by Achim Stegmeier
Art hobby "High Force" owners, what battery pack do you use?? Masterpiece Electric Sailplanes 3 Oct 16, 2005 09:58 PM
Question What battery connectors do you use? Ado Electric Ducted Fan Jet Talk 4 May 31, 2004 04:48 PM
XE2 flyers what battery charger do You Use? jschick Foamies (Kits) 9 Nov 26, 2003 10:16 AM
What charger do you use? beefcake Foamies (Kits) 16 Apr 26, 2002 10:11 AM
What Battery Packs do you use in the Teddy? mrebman Foamies (Kits) 7 May 07, 2001 10:30 PM
