Old Feb 03, 2005, 11:00 PM
Gainesville, Florida, United States
Joined Sep 2001
Control surface deflections and drag
On my 38" WS DLG, I'm trying to reduce drag as much as possible. This led to a question - to reduce drag on the control surfaces and maintain authority, is it more beneficial to use smaller surfaces with larger deflections, or larger surfaces with smaller deflections? My instinct says the latter is better from an efficiency standpoint - it may be slightly heavier, though. Your input?
stjobs is offline Find More Posts by stjobs
Old Feb 09, 2005, 06:31 PM
can ya do that??...
electroboy's Avatar
California
Joined Jan 2004
I dunno for certain, but particularly in the realm of soaring flight, weight and surface area(drag) are concerns.
Just offa the top o my head I'd suggest keep wt.+drag to a minimum with smaller surface.
The goal for me when soaring is to make as few movements as possible.
so when a surface has to move, it will only be for as long as necessary to adjust attitude. Then back to most efficient flight profile- CLEAN
There's all kindsa stuff going on in flight and tradeoffs galore.
I hope some others look at your question, I'm curious too.
electroboy is offline Find More Posts by electroboy
Old Feb 09, 2005, 07:17 PM
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
Great question. Looking forward to the replies.
I THINK Ollie once replied that the latter was more efficient, but I'm not 100% on that. Would it really need to be havier to have a large surface-less throw setup? Heavier for slope soaring for example can be an advantage as well, at least around here.
I still consider myself a relative newbie at flying ~2 years, and even though i can fly, doing so efficiently seems to be the real test I try to build my planes as drag efficient as I can, only to waste it all when I fly them !!
Cheers
Paul
gouch is offline Find More Posts by gouch
Old Feb 10, 2005, 02:12 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Something tells me that the lowest drag would be an all moving wing...twisted very very little. And whose twist changed along its axis,like a propellor.
So whatever is closest to that. Large outboard ailerons, and little movement 'd say.
Old Feb 10, 2005, 07:12 AM
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
stjobs,
A reasonable size surface with minimal deflection is best. But, rigging is more important than control surface size.
The purpose of the stabilizer is to set the angle of attack of the wing. The stabilizer should fly at zero angle of attack. Ideally in level flight the wing is rigged so that the angle of incidence is the same as the angle of attack required for level flight. If the rigging is correct then there will be no control deflection at all.
If control trim is required for level flight then you have a high drag situation. It means that you are changing the angle of attack for the entire fuselage. If the fuselage is angled it creates lift. Since it has an aspect ratio less than one the induced drag is very high.
You will get much greater drag reduction by rigging the wing incidence for zero trim deflection than you will by varying control surface size.
Tom Harper is offline Find More Posts by Tom Harper
Old Feb 10, 2005, 08:00 AM
Punta Gorda, FL
Joined Apr 2002
For small angles (<3 to 5 degrees) of control deflection, the drag doesn't increase much. Above large angles of control deflection, the drag goes several times more because of the turblunce increases. You can make the controls work better for small angles. You can make the work tail area with tail long fuselage behind the wing. You can you can reduce the tail drag with small tail area but at reduced controls. You can increase drag by making the CG aft up to a point. Etc, etc.
The designer can ballance those conflecting goals. There are other goals about designing tails. With many goals, the choices are the designer's science and art.
Ollie is offline Find More Posts by Ollie
Old Feb 10, 2005, 11:58 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I prefer as small as practical, especially chord-wise, with the span altered to suit. And low deflections for non-aerobats.
On some planes I have no ailerons at all, to maintain the wing as clean as possible.
With a flying horizontal, it's the best of all worlds...
Sparky Paul is offline Find More Posts by Sparky Paul
Two Servos on Same Control Surface green66 Power Systems 10 Mar 12, 2002 02:08 PM
Drag Reduction with Control Surface Tiplets green66 Electric Plane Talk 0 Dec 15, 2001 01:19 AM
And_Now control surface hinges. CharlesD Parkflyers 6 Dec 01, 2001 08:36 AM
Omega E control surface travel sprocket Electric Sailplanes 5 Aug 05, 2001 02:09 AM
Wingo control surface gap JensJakob Foamies (Kits) 1 Jun 16, 2001 04:51 PM
