Old Mar 15, 2002, 07:53 PM
SKINNI MINI flyer
Barrett's Avatar
Pearl River, LA, USA
Joined Sep 2001
My s400 7.2v and 6v both have RS380-PH stamped under the sticker. Whats up with that?
Can someone shed some light on this for me. Just curious. Maybe whoever put the sticker on it messed up.
What mabuchi motor is the s400 6v, and which one is the s400 7.2v.
Thanks in advance.
Barrett is offline Find More Posts by Barrett
Old Mar 16, 2002, 10:19 AM
Ijamsville, MD, U.S.A.
Joined Mar 2001
Barret: The 380PH is 6V and the 380SH is 7.2V; see FMA Direct web site catalog; MOTORS.
Fred Marks is offline Find More Posts by Fred Marks
Old Mar 16, 2002, 10:42 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Take a look at these
http://www.mabuchi-motor.co.jp/engli.../rs_380ph.html
http://www.mabuchi-motor.co.jp/engli.../rs_380sh.html
scirocco is offline Find More Posts by scirocco
Old Mar 16, 2002, 05:24 PM
SKINNI MINI flyer
Barrett's Avatar
Joined Sep 2001
Now im really confused. The links above say that the 380PH nominal voltage is 10.5v and the 380SH nominal voltage is 7.2v.
Seems like it should be the other way around.
The reason that i am trying to figure this out is because there is a growing e-flight population in my area, but none of the LHS will commit to popular e-flight products, like s400 motors. So im trying to find someone here in the states that will sell in bulk or wholesale. Not so that I can really make a lot of money (but that would be nice) but rather, just so I can have a supply of my favorite size motors without having to order them online. And so that fellow e-flyers can purchase a few from me whenever they need them.
And thanks for the responses guys.
Old Mar 16, 2002, 06:01 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
If you make a disc so you can tach the motor at "no" load you should see 16,4k rpm at 6V input for the 6V motor and 7,2V input for the 7,2v version.
Or just put a regular prop on it - tach it and compare with a "true" s400/6V and /7,2V at the same input voltage.
Haldor is offline Find More Posts by Haldor
Old Mar 17, 2002, 08:15 PM
MrThermal's Avatar
NE Indiana
Joined Sep 2001
S400 6V
Fred: by running 7 cell 700 mah packs on my S400 6V will that shorten motor life compared to using 6 cell 850 mah packs? Also...does Guenther make another prop besides the 125 x 110 that works great ? I have seen some talk about a generic 5 x 5 carbon prop for the S400...will this increase the current draw too much ? GottaFly
MrThermal is offline Find More Posts by MrThermal
Old Mar 17, 2002, 09:04 PM
MK
NJ
Joined Feb 2001
Voltage, or more exactly over voltage, is the thing that shortens a motor's life. Hooking it up to a higher capacity (mAh) supply will only make it run longer, given everything else the same.
MK is offline Find More Posts by MK
Old Mar 17, 2002, 10:50 PM
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Think about it - In geared applications you can use a couple of cells more with no problems, provided you keep the amps down. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Mar 17, 2002, 11:56 PM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
I have a 6V Speed 400 marked RS-380PH, and a 7.2V Speed 400 also marked RS-380PH.
You cannot tell the voltage from these part numbers. There is supposed to be winding info in 5 extra digits - but this is usually missing.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Graupner Speed 400 7.2V and 6V SAME? Peter Khor Power Systems 8 Nov 06, 2002 08:03 AM
Master Airscrew S400-7.2V current rating S55 Foamies (Kits) 0 Oct 01, 2002 02:49 PM
FS: 4 Multiplex S400 7.2V Motors......SOLD Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Aug 16, 2002 11:37 AM
Sp400 7.2v to 6v=same rpm????? deadcell Power Systems 6 Sep 30, 2001 11:18 PM
Scale twin power - - Graupner geared 2.33 S400 - 7.2v PeterH Scale Electric Planes 5 Aug 08, 2001 02:20 AM
