Wow Hank, why all the negativity?
<In my opinion, the drive system is the most poorly designed of all the common electric helis. The two stage gear system has an effective number of teeth of 350. This and limit on the number of cells which can be in the battery paks, precludes using any common motor, brushed or brushless, at its optimal operating rpm because of the limited number of large size (greater than 20 teeth) pinions available.>
Firstly, the heli flies quite well on the stock motor and 8 cells. It will loop, roll, fly inverted and more with the right flying skills and the proper set up. Actually, the included motor is running fairly well on its effceincy mark - I did the math a LONG time ago and the motor was around 70% effeceint on 8 cells and a 15 tooth pinion. For a brushed car motor, that is VERY good! What more do you want? Not to mention, you can find 32 pitch pinions all the way to 40 teeth at various small parts places which fit the 1/8" shafts. I have a buddy using a 40 tooth 32 pitch pinion on a very odd motor/cell set up in a Voyager - and he said he could have gotten any pinion he needed too! I think that is a poor arguement for the 2 stage gearing - firstly, it actually INCLUDES and auto hub set up. This is something the ECO 8 and Logo 10 require as hop ups. No to mention, using a motor pinion AND a seperate pinion for the tail on the ECO 8 isnt a walk in the park - sure, you can optimize set up, but the Voyager 2 stage gearing works great with the right motor, tail included!
<Many are using the Hacker B40-8L with 10 cells and a 15-17 tooth pinion. This combo would be much more effecient with a pinion of 35 teeth!>
Huh?! My motor puts out a TON of power and barely gets warm (8L, 16 tooth pinion, 10 cells)! I would say its running efficiently, wouldnt you? Putting a 35 tooth pinion on it would give a heaspeed over 3000 RPMs, that makes no sense. With the 16 tooth pinion on 10 cells I can max out around 1750 RPMs - plenty for VERY powerful flying and aerobatics!
<However, you could get the same power at much lower current if you could boost the cell count to 16. At 10 cells of sub C's the pak is already 8.5" long. And it's 4 inches between the battery mounts! If you use the 4/5 sub C's (CP1700), you could get up to 12 cells in the same length. Neither of these gets the voltage high enough for efficient motor use when using a reasonable pinion (20 teeth or less). The other option is to use AA cells. A pak of 16 of these is 8" long and they are available up to 1800 mah (NiMH). 16 cells would allow flight times approaching that of the ECO 8.>
This statement makes no sense to me. So my motor barely gets warm, flies for 5 minutes on 10 cells CP1700s with LOTS of power for aerobatics and more at around 1700+ RPMs and it is not efficient? Why not? Sure seems to be working well to me! And yes, that is with a smaller pinion than 20 teeth and on only 10 cells...Im lost here I guess. Are you saying you want PURE duration? Then the JR Voyager should NOT have been your choice! A simply bit of research and you would have know the lighter ECO 8 would have been MUCH better for this purpose!
<The other problem is pak charging. If you go to a pak of more than 8 cells, you will need a large pak charger and it will be DC powered so you will have to charge with the car or get a separate battery or a AC/DC power supply. If you have these then there will be no problem. If you don't, plan on spending upwards of $110 or so if you can scrounge a battery.>
The MRC Super Braind 959 does 1-8 cells, NiCad, NiMH with a digital readout AND is AC/DC for $48. That means you can charge 8 cells AC without an expensive charger - not to mention, this is an EXCELLENT charger that performs flawlessly! Besides, this problem relates to ALL e-helis. Whether you have a Piccolo, Hornet, ECO 8, Logo 10/16/20, you will NEED a good charger. The only place you can get away "cheap" is with a Lite Machines Corona flying on 7 cell RC car packs with a $20 RC car charger. I see in no way how this is a negative for the Voyager E. If you had a Logo 10 youd need a charger for 10-14 cells as well.
<If I had known these facts before I bought my Voyager, I would have opted for the Logo 10 which doesn't pretend to run on car battery paks!>
Im not sure how much of this is fact in all honesty. Your first statements of needing 16 cells, 35 tooth pinions, etc, etc make no sense. This heli is 100% proven as a fully aerobatic heli on 10 cells and a 16 tooth pinion! Yes, this does require a brushless motor to do so, but with 15 minutes of research time you wouldve known that. How many posts do you see where guys actually use the stock motor in the heli for long? Very few. And no, it does not pretend to fly on an RC car motor and packs - it DOES fly on them! I can send pics of a stock Voyager flying on the stock motor and 8 cells inverted a few feet off the deck - and no, it is NOT a doctored photo!
Im not sure what this post was aimed for. To me, it makes little sense as a bashing to the actual heli. Im not trying to be rude - honestly, thats the last thing Im trying to do. But put yourself in the shoes of the current Voyager owners - better yet, someone who may have JUST bought a Voyager. You made them think twice about it, which I dont think they need to do. Hands down, the Voyager is the BEST engineered heli in the 7-8 class. Yes, it is better built than an ECO 8 - lighter, no. Does it fly better than an ECO 8 - yes and no. I can get into that, but I dont think I need to.
The best I can guess is that youre not happy with your flight times. How much flight time do you want? The 9L motor and 10 3000 cells can give 10 minutes on a Voyager E. The ECO 8 I used to fly on 10 2000s got near 10 minutes on a brushless motor. Im sorry, but I doubt you will ever find in the next few years an e-heli capable of more than 10 minutes of flight time on an RC car motor and 7 or 8 cells. Is that what you want?
Jason
