Old Feb 02, 2005, 02:37 PM
Darcy is offline
Find More Posts by Darcy
Darcy@Rubber-Power.com
Ottawa, Canada
Joined Jan 2005
Balsa Stripper
So has anyone got any good ideas about a balsa stripper?
I made one but it didn't work very well. What's the trick?
Darcy
Darcy is offline Find More Posts by Darcy
Old Feb 02, 2005, 07:14 PM
Blazer is offline
Find More Posts by Blazer
Guest
Santo, Tx.
Joined Aug 2003
Darcy - I've got a Master Airscrew stripper that works good. Uses a #11 blade. Tower sells them for around 6 bucks- Jim
Blazer is offline Find More Posts by Blazer
Old Feb 02, 2005, 08:38 PM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Me, too, Blazer; mine must be 25 years old, and has reduced many sheets with no flaw in its operation (problems and errors had to do with the operator!). Hard to go wrong on that machine.
Also, while you are at it, make sure that you look for a good supply of #11 blades, they are cheap by the box. My buddy has gone over to scalpel blades, and finds them better yet, but I still have ~40 #11 blades left!
TLyttle is offline Find More Posts by TLyttle
Old Feb 05, 2005, 06:59 PM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
Still have an old X-acto stripper that worked pretty well. (Still does)
on small/ medium balsa. The master one has been going for a long
time pretty well too.
Most of the time though I use an 'Indoor' micrometer set stripper.
Unfortunately can't remember the name, it was a long time ago.
flight999 is offline Find More Posts by flight999
Old Feb 06, 2005, 12:48 PM
Blazer is offline
Guest
Santo, Tx.
Joined Aug 2003
Hobby Lobby has an interesting stripper and balsa planer @ http://www.hobby-lobby.com/planer.htm tho I've never used either one. Jim
Old Feb 06, 2005, 01:06 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
I'll second the Master Airscrew -- I've used mine for over 30 years, 1/32 to 1/2" with no problems. The H-L looks very good, high-dollar.
howell
gwinhh is offline Find More Posts by gwinhh
Old Feb 08, 2005, 10:44 AM
Darcy is offline
Ottawa, Canada
Joined Jan 2005
So far, the best I've come up with is to cut wood with a steel ruler and blade.
The VMAR one looks quite nice. I may save my pennies to get that one.
Old Feb 08, 2005, 11:29 AM
glider34 is offline
Find More Posts by glider34
ADDICTED TO LIFT
glider34's Avatar
Connecticut
Joined Jan 2003
Jim Jones balsa stripper which is available from:
1/8" version $23.50 + $4.00 postage
3/16" version $28.50 + $4.00 postage
Jim Jones
36631 Ledgestone Dr
Clinton Twp, MI 48035
ph 810-791-0651
Very very nice quality for the money,
John
glider34 is offline Find More Posts by glider34
Old Feb 08, 2005, 11:55 AM
flight999
England
Joined Dec 2002
The main problem with many strippers is the blade is too
flexible. For strip from 1/16" upwards I have found -and use-
a minature circular saw (Dremel?) with adjustable guide.
Works on carbon or fibreglass sheet also if it isn't too thick.
Old Feb 08, 2005, 06:56 PM
Tail Spin1 is offline
Find More Posts by Tail Spin1
Zach
Illinois
Joined Feb 2004
Strippers
I have a Master Airscrew balsa striper and donít know what I would do without it.
(I guess I should say that I have 1 Ĺ balsa stripers from M.A, the first one I bought was missing a piece and after contacting M.A. they sent me a new one plus a free hat. Nice people, nice hat.)
Still the Master Airscrew isnít as precise as I would sometimes like it to be. (The blade sometimes tries to follow the grain of the wood and wonders a little as its cutting.)
The Jim Jones stripper does look nice.
I have found information on some others cutters.
Hereís a page that has information on the Jim Jones Stripper, the Master Airscrew Stripper and instructions on making your own stripper.
http://www.mindspring.com/~thayer5/f...alsastrip.html
On this page you can find the Micrometer Balsa Stripper by Ray Harlin, bit pricy though.
http://www.indoorduration.com/HarlanBrochure.htm
A tip for your Master Airscrew Stripper: take a piece of scrap ľĒ Sq. balsa and stick it over the tip of the blade. This helps keeps your blade sharper and your fingers safer.
Tail Spin1 is offline Find More Posts by Tail Spin1
Old Feb 09, 2005, 05:08 AM
flight999
England
Joined Dec 2002
Thanks Tailspin, the Harlan one is the one I couldnt remember the name of.
Personally used and have/had most of the others at one time or another,
they all work(ed) pretty well.
You have plenty here to go on Darcy!
Old Feb 09, 2005, 12:39 PM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Not quite a balsa stripper, but you all may be interested in a little device I made to cut triangular wood for corner fillets on sheet fuselages etc..
I never had any real success cutting through 1/4 sq so I bought some box section brass tube which had a 1/4 sq interior size (I did the same for 3/8 sq too). I drilled a small hole across the diagonal about 2 inches from the end and used a fine fretsaw blade to cut down the depth of a balsa knife blade. All you need to do is push one of the convex blades across the diagonal and shove the 1/4 x 1/4 in from the top. The blade slices it neatly at 45 degrees and it comes out of the bottom of the tube in two lengths.
Easy and totally foolproof.
The only consideration is that the grain must be reasonably straight and the blade sharp.
Tony
Tony Oliver is offline Find More Posts by Tony Oliver
Old Feb 09, 2005, 01:20 PM
TLyttle is offline
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
FoolPROOF?? C'mon, Tony, you know fools are too innovative...
Old Feb 09, 2005, 02:18 PM
flight999
England
Joined Dec 2002
Another 'foolproof' one for you with small sizes:-
Break off a small lwngth of razor blade and mount it on two blocks
of wood of the thickness you require and slide the piece you are cutting
through from the cutting edge making sure the wood itself stays flat on
the surface. Straight grain helps to stop it riding up!
Old Feb 09, 2005, 04:39 PM
North-East England
Joined Mar 2002
Balsa stripper madness! Inflexo The Builders Workshop 7 Feb 03, 2004 12:13 PM
Balsa stripper - home made Inflexo Parkflyers 2 Feb 02, 2004 01:16 AM
balsa Stripper survey EBerris The Builders Workshop 7 Oct 01, 2003 09:44 PM
Which balsa stripper is better? totalboss Electric Plane Talk 7 Jun 13, 2002 01:44 AM
