Old Jan 31, 2005, 04:10 PM
lakedude is offline
Find More Posts by lakedude
Pedal Power!
lakedude's Avatar
the lake
Joined Oct 2002
Ghost vs Drive Image, has Ghost been improved?
DI is similar to Ghost but is easier to use and has more options than the version of Ghost I've seen. This may be old info if Ghost has been updated.
DI 7 makes backups on the fly without the need to go to a "Dos" enviroment. DI 7 can also split files into a burnable size if the resulting backup image is too big to fit on whatever disks you are planning to burn to. These split backup files do not need to be burned directly from DI, they can be saved to a hard drive and burned later. Last time I checked Ghost did not have such options.
Any Ghost users know if Ghost has been improved to include these features?
lakedude is offline Find More Posts by lakedude
Old Feb 01, 2005, 07:38 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Symantec bought PowerQuest so they don't care which you use. One reason was they liked the "hot backup" option, good for corporate customers, so it's been put into Ghost as well.. (I used to work for them)
http://www.symantec.com/sabu/ghost/g.../features.html
Key Features
o NEW! “Hot imaging” lets you create backup images without restarting Windows®. *
o NEW! Incremental backup updates save time and disk space.*
o NEW! Scheduled backups automatically keep your backup image up to date.*
o Backs up everything on a hard drive or partition.
o Works with a wide range of hard drives and removable media, including CDR/RW and DVD+-R/RW drives, USB and FireWire® (IEEE 1394) devices, and Iomega® Zip® and Jaz® drives.
o Restores data from images created with PowerQuest™ Drive Image™ 7.0 and previous versions of Norton Ghost.*
o Symantec Recovery Disk lets you restore data from a backup image even when the computer can’t start up into Windows.
o LiveUpdate™ keeps Norton Ghost updated automatically over the Internet.
o Norton Ghost 2003 is included to back up and restore data to: Windows 9x, Me, NT; Linux®; and DOS systems.
*This feature is not available with Norton Ghost 2003.
Old Feb 02, 2005, 03:54 PM
Buzz_Man is offline
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
So . . . if I want the fastest & cheapest way to recover a hard drive I should do what - get a portable CDR/W? One of my main problems is that I'm using Windows 98 SE on 29 machines & I'm a bit leary of the USB compatibility of the drive I need to order. \(This is not a joke reply - I'm really this ignorant)
Buzz_Man is offline Find More Posts by Buzz_Man
Old Feb 02, 2005, 04:23 PM
lakedude is offline
Pedal Power!
lakedude's Avatar
the lake
Joined Oct 2002
I think it is a good question. You may need to suppy more info about exactly what you are wanting to do. Are all 29 machines the same? If so you can keep an image on a server (or anywhere actually) and "push" the image out to the machines to keep em like new all the time. This only works if the machines are the same and if the software does not need to stay current.
Do the machines not have their own burners?
Getting an image made is one thing, as you are using a system that is fully operational. RESTORING an image is another matter.
If the systems are old enough to be running 98 their hard drives are likely not that big by modern standards and seperate images for all of them may fit on a single modern hard drive. You might be able to buy a portable HD or an internal and USB enclosure to fit your backups on.
An internal DVD burner is about $65 bucks and a USB2 enclosure to put it in is about $35.
Hmmmm your systems are old enough to lack usb2, which is going to be a problem with any USB portable drive.
OK my best guess at what you can do is to set up one machine to be a server. The server will need a new internal hard drive or two depending on how big the images are. BTW they do have NICs correct? On a machine that old the fastest external connection is the network. More modern machines have USB2 and firewire in addition to a NIC card.
Anyway there is no point in me guessing what you are trying to do without more info. I'll try to help further after we get some more cards on the table.
Old Feb 02, 2005, 07:09 PM
Buzz_Man is offline
Buzz_Man's Avatar
Joined Dec 1999
Okay, here are the "cards":
29 machines
Windows 98 SE
CAD software
No networking - at all
I suspect the computers will eventually get messed up - my goal, if possible, is to be able to plug something into one of the computers, "push a button" and have the core o/s & s/w reloaded onto the hard drive. I don't think having a complete, exact image of the drive is important, that if I just copy over what's there with an original copy, that everything will work. If not, I can format, reload Win 98 SE, the drivers, the s/w & so forth.
I just remembered - somewhere, I have an old Syquest 1 GB portable disk drive that I might be able to use for this, which plugs into a parallel port. The software to run this thing fits onto a floppy. I have a zillion of those 1 GB drives (this was before CDR/W machines were available/affordable). Maybe I could use this thing to achieve my goal. Sounds like it might work - all the o/s on one drive, all the CAD s/w on another drive, & so forth.
Maybe?
Old Feb 02, 2005, 08:28 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
How big are the hard drives?
Use partition magic or similar to partition the drives into two, but the second drive can be "invisible" to the host OS. You then use Ghost (or DriveImage) to make a good copy of the image. Then, WHEN it gets hosed, insert bootable CD or disc with Ghost on it, and 'restore' the image.
If new software is loaded on the machines, use a clean restore first, then back it up again to the second partition..
..a
Old Feb 03, 2005, 12:12 PM
Buzz_Man is offline
Buzz_Man's Avatar
Joined Dec 1999
Hard drive info:
19.4 gb
using 518 mb (no typos)
Partitioning would mean I'd have to start all over again from scratch, right? Yipes, I don't wanna do that if possible. Or, would it mean just copying the external device with the image on it to each machine? Now, that seems nice & easy. Hmmmm.
So - I guess I could used the right software with an external cdr/w drive, I could make an image of the entire hard drive "as is"?
I think it's time for me to jump into learning more about DI or Ghost & go from there - many thanks & happy flyin',
Buzz
Old Feb 03, 2005, 12:16 PM
Buzz_Man is offline
Buzz_Man's Avatar
Joined Dec 1999
In any event, I can't get my restore.bat file to work - any idea what's wrong with it:
cd\
cls
copy/v c:\Windows\Config\abw\root\windows\*.* c:\windows\
copy/v c:\windows\config\abw\root\windows\desktop\*.* c:\windows\desktop\
copy/v c:\windows\config\abw\root\windows\system\*.* c:\windows\system\
copy/v c:\windows\config\abw\root\windows\system32\*.* c:\windows\system32\
copy/v c:\windows\config\abw\autocad\support\*.* c:\progra~1\autoca~1\support\
Old Feb 03, 2005, 02:25 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No, Partition Magic lets your repartition a drive "on the fly"..
I wouldn't fool with external devices on a 98 system. Your backup partition can be compressed, so you'd probably only need 5 or 6GB or so..
..a
Old Feb 03, 2005, 04:01 PM
Buzz_Man is offline
Buzz_Man's Avatar
Joined Dec 1999
MEGA-THANKS!!!
I'll get Partition Magic & either Ghost or DI and get on with the plan.
Happy flyin',
Buzz
Old Feb 03, 2005, 04:38 PM
lakedude is offline
Pedal Power!
lakedude's Avatar
the lake
Joined Oct 2002
What Andy said to do is exactly how I do my single hd systems. I normally make the backup on the extra partition AND burn a copy. A backup on a hard drive does not help if the drive is going bad but is is very handy and fast if there is a software issue. The CD copy is useful if something takes your hd out and you need to load up a new hd fast.
Old Feb 04, 2005, 02:43 PM
Buzz_Man is offline
Buzz_Man's Avatar
Joined Dec 1999
Gotcha - thanks & happy flyin',
Buzz
The Rig. Micro Heli Scale flying has never been better Choppa Nutta Micro Helis 21 May 08, 2014 07:19 PM
Mini-Review Esky v3 lama vs Apache gt3 + "ghost" fusealage switchback7 Coaxial Helicopters 5 Feb 19, 2007 08:26 AM
Drive Image 7 kills Ghost lakedude Life, The Universe, and Politics 4 May 25, 2004 06:13 PM
Has there been any testing done on GWS versus APC slowfly props kitbasher Parkflyers 0 Dec 09, 2002 01:39 PM
Has Glow Power improved over the last 3 decades compared to E-power? Megowcoupe Electric Plane Talk 15 Aug 30, 2002 07:59 AM
