Espritmodel.com Heli Air
Old Jan 30, 2005, 11:02 PM
"I passed on the kool-aid"
Waco, TX
Joined Jan 2004
How far can you push an axi 2808-24 safely...
I just got one and ran it with a 9x9 apc and pulled 23 amps on 3s kokam 2000's. I have not adjusted the CC 25 from the stock timing settings. How big of a prop can I get away with and how many amps can you safely run with these motors. I would really like to get an 11x4.7 SF to work with it. Is this too big? From my intial experiences I am not really impressed with the motor...yet
papasmurf is offline Find More Posts by papasmurf
Old Jan 31, 2005, 01:56 AM
Finland
Joined Nov 2004
Going from soft timing to hard timing with at least with jeti controller boosted AXI performance a lot. Try that first.
Kema is offline Find More Posts by Kema
Old Jan 31, 2005, 04:01 AM
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
I run that motor on 8 KAN 1050 cells and an Aeronaut 10x6 folder. It draws in the neighborhood of 15 amps and I think it is a fantastic motor. My favorite in fact. It flies my 24 ounce 43" span HOB Mustang with great authority. I typically fly at 3/4 throttle most of the time. I have been flying that plane for about a year and it still brings a smile to my face. I use a CC 25 factory settings for ESC.
Len
LenBFP is offline Find More Posts by LenBFP
Old Jan 31, 2005, 07:32 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I only have the 2808/20 but if the /24 is much the same I would think 20A is close to the upper limit.
Just a naive question on this: I know soft start and fast start, and low timing advance and high timing advance, but what exactly are you referring to here?
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 31, 2005, 08:26 AM
Waco, TX
Joined Jan 2004
If 20A is the best it can do than I am probably going to have to let it go and get another geared setup. I did try an 11x4.7 SF and it pulled about 23-24 amps so that is pretty reasonable though it still didn't seem to come anywhere near my geared setups.
Old Jan 31, 2005, 09:08 AM
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
I have an APC E 11x5.5 on my 2808-24.
3s 2600 lipos
It gets warm, but as long as you're not at full throttle the whole time, it's fine.
-Hans
flybike is offline Find More Posts by flybike
Old Jan 31, 2005, 09:17 AM
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
My Groove setup pulled 27-28A WOT on a 11x8E at 5200 ASL. 3S1P 2600 Irates. However WOT was only in 'short' bursts if at all ..... Never had a problem running this way ... Note that I read that AXI is conservative with thier rating. If you are looking speed this motor probably isn't the one you are looking for. With throttle control a 10x5 or 11x4.7 would work fine ....
rclark is offline Find More Posts by rclark
Old Jan 31, 2005, 10:23 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
What is the difference between the 2808 20 and 24? I imagine it's a very similar motor? I know the 20 stated 9x5 to 10x6 depending on batteries etc. Just wondering myself what I could do with this motor. Thanks.
taekwondo is offline Find More Posts by taekwondo
Old Jan 31, 2005, 10:39 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
Never mind, I found out my own question and here is some info for you.
The 24 is rated to 11x5.5 prop. See below.
PM280820 AXI 2808/20 External Rotor Brushless Motor ..... $ 89.00
IN STOCK
AXI 2808/20
For 7 to 10 cells, 9x5 to 10x6 props. 1250 RPM/V. Max current 25 amps. Mounting options.
Examples of output for 280820:
Cell
Count Prop RPM Current Watts
to prop
7x1700 10x6 7520 18.7A 98
8x1700 9.5x5 8750 19.6A 107
10x1700 8.5x6 11,120 21.5A 164
COMBO: Order your AXI 2808/20 with a Jeti 30 amp brushless controller and SAVE!
PM280824 AXI 2808/24 External Rotor Brushless Motor ..... $ 89.00
IN STOCK
AXI 2808/24
For 6 to 10 cells, 9x5 to 11x5.5 props. 1160 RPM/V. Max current 22 amps. Mounting options.
Examples of output for 280824:
Cell
to prop
7x1700 10x6 7360 16.1A 92
8x1700 9.5x5 8560 16.9A 112
10x1700 9x5 10,770 19A 157
COMBO: Order your AXI 2808/24 with a Jeti 30 amp brushless controller and SAVE!
Thanks.
Old Jan 31, 2005, 10:47 AM
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
The /20 spins the prop faster (higher KVA) .... Similar 'watts' wise....
I have a 9x4.5E on my 52" AcroCub and on 10 cells or 3S1P it rips the 26oz cub around right quick (not pylon speeds of course ) . Plus vertical is very good if not unlimited with the LiPo in there..... If I was looking for more speed the /20 would be my choice. Looking for thrust with bigger props, I'd go with the /24 . The /24 and a high pitch prop pulls a plane plenty quick too ... but not like the /20 . For example, My son is going to use my 2808/24 in his 3D Attitude for example. I will be buying another 2808/24 for the Jitterbug Bipe I am building. Speed isn't the criteria for these planes ..... If I was looking at a pattern plane between 18 and 30 ozs I'd be looking at the /20 . Hope that helps .
Old Jan 31, 2005, 11:33 AM
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
It does help. Everything helps. Thanks.
Old Jan 31, 2005, 06:34 PM
LenBFP's Avatar
Joined Jan 2002
I have two of the /24 motors and one /20. I don't know if they still make them this way, but my 20 is wound on every other stator while the /24 is wound on every one. I have been running the /20 on 2S 2200 cells with a 9x5.5. It probably is not optimal but it draws 17 amps. I have found them to be very different motors. I will probably put the /20 on a formosa II with a smaller prop.
Len
Old Jan 31, 2005, 07:06 PM
Waco, TX
Joined Jan 2004
I was going to perhaps put the /24 on my mini funtana or a wattage pitts. The 11x4.7 or 11x5.5E might work with the funtana but I was looking at the 9x9 or a 10 something for the pitts as it likes to go fast. I noticed hobby lobby had it up to an 11x5.5 and claims 37 oz. thrust but was wondering whether this was really possible. The funtana weighs about 25 oz. with a geared 20mm himax type of setup. Several have commented on putting the motors in their planes but no flight reports yet.
Old Jan 31, 2005, 07:35 PM
Where's your CofG?
Gibby's Avatar
San Diego
Joined Apr 2004
I have the /24 on my Pigi 3D with 11x4.7 and TP 2100. AUW is 23oz and I would guesstimate that I am getting close to 37oz of thrust with this set up. I have also run the /24 on a 10x7 apc SF and that's awesome but it pulls about 35 amps at static WOT. Motor seemed to do okay with it.
Gibby
Gibby is offline Find More Posts by Gibby
Old Jan 31, 2005, 09:05 PM
Where is that remote?
lazyboyflyer's Avatar
Wildomar, California, United States
Joined Sep 2004
I have an AXI 2808-20 swinging a 11X5.5 prop on 3s kokam 2000s "15c". This setup is running on the hard timing for jetti and pulling 32 amps. The motor is putting out almost 300 watts and Im guessing aroung 52 ounces of thrust because it hovers my 26 ounce Quiet Storm at a little less than half throttle. The motor is running great with no problems at all. I have been running this motor for quite a while now too. AXI rates their motor consevatively.
Lazy Boy Jr.
lazyboyflyer is offline Find More Posts by lazyboyflyer
Discussion How Bout' an AXI 2808/24 in my Mini Pulse XT? dartbrandx Parkflyers 9 Jan 30, 2007 12:03 AM
Question How far can you push a mega 16/15/3? flybyjimbo Power Systems 6 Jan 17, 2007 03:12 PM
Discussion How far can you push a Kontronik 480 33 noddy High Performance 8 May 11, 2006 04:58 PM
How far can you push an ETEC 1200 2S1P Pack OzzieFlyer Batteries and Chargers 9 Jul 05, 2003 05:34 AM
