Old Jan 30, 2005, 11:22 AM
agapornis is offline
Find More Posts by agapornis
agapornis
italy
Joined Jul 2004
Measure The Speed Of Your Gws Plane ...?
Hello, is there something that can record or give my top speed or speed in all the flight ?
And that you can put on the plane ?
Regards
agapornis is offline Find More Posts by agapornis
Old Jan 30, 2005, 03:00 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Regards
The easieast method does not need anthing in the aeroplane. Mark out a 100 foot course and use a stopwatch to measure the time the model takes to travel the 100 feet.
Then let T = time taken to travel 100 ft
100/T = ft /sec
ft/ sec *60*60 = ft/hr
ft/hr/5280 = MPH
So the formula is :-
MPH = 100/T*60*60/5280
Therfore MPH is aproximately = 68/T
Ken
kensp is offline Find More Posts by kensp
Old Jan 30, 2005, 05:01 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Easy way is who have friend is working in Police Dept.? Check by radar gun.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Jan 30, 2005, 05:23 PM
agapornis
italy
Joined Jul 2004
But really there is nothing that can mesure the speed like there is an on board altimeter there can be an on board speed check ?
Old Jan 30, 2005, 07:48 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Will make some tele transmition device on airbrone with more fuction, or even video.
Old Jan 31, 2005, 03:57 AM
Steve990 is offline
Find More Posts by Steve990
Birmingham Intl, Great Britain (UK)
Joined Jul 2004
On the jets forum it's been mentioned that there is a programme that will calculate the speed of a model from the doppler effect as it passes the microphone. Basically you video (or only audio I suppose) record a flat out pass then run the programme and it calculates the speed from the tonal change in the engine, hi tech enough
Steve990 is offline Find More Posts by Steve990
Old Jan 31, 2005, 04:45 AM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Eagle Tree Systems makes a black box that takes many measurements including altitude and speed. Speed is based on air pressure and uses a pitot tube that attaches to the wing out away from the prop wash. However wind can also be a factor in that reading. I reviewed the Eagle Tree System and review was posted in Ezone in early December last year. System can also read RPM, battery status, temperature, how servos are working and more. Moderator Mike
Old Jan 31, 2005, 06:50 AM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
My small handheld gps unit has a speedometer in it (will tell you top speed achieved). Also has an altimeter in it. You could chuck that in the plane and get the data from it. Only weights a few ounces.I once strapped it on my Nitro truck to get a top speed reading, worked fine.Just don't crash or loose the plane when a $500.00 gps unit is on board!!!
Jag
Jagzilla is offline Find More Posts by Jagzilla
Old Jan 31, 2005, 06:58 AM
yoyoML is offline
Find More Posts by yoyoML
Taipei Shek, Taiwan
Joined Aug 2004
It's hi tech alright, but can be done with a pair of musician's ears, a thermometer, a pen and paper, quickly. Accuracy depends mostly on the ears, though.
yoyoML is offline Find More Posts by yoyoML
Old Jan 31, 2005, 08:01 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Easy and cheap (read as free) via Doppler analysis!
Record a wav file on a PC then do a Fourier analysis for flight speed and even rpm (static & flight); a search over in EDF should get some good postings.
Did it on the audio of my Mustang’s video; no unloading & 73mph: http://rcgroups.com/gallery/showgall...500&ppuser=497 .
jrb is offline Find More Posts by jrb
Discussion How do you transport your GWS plane? JohnAsaPrice GWS (Grand Wing Servo) 10 Jul 19, 2007 05:52 AM
GWS Create your own plane kit! tallflyer Vendor Talk 5 Apr 30, 2005 10:56 AM
Cool Whose Piloting Your GWS Plane? - A thread just for the little plastic pilots! Michnet76 GWS (Grand Wing Servo) 7 Feb 23, 2005 10:55 PM
Alert *post Your Gws Plane Videos Here!* Zachary Parkflyers 0 Aug 23, 2004 06:40 AM
What Temperature do you fly your GWS plane at? TJSlayer Parkflyers 16 Feb 08, 2003 11:07 PM
