Old Feb 23, 2005, 07:28 AM
ldammann is offline
Find More Posts by ldammann
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Rick
Took a peek at the plans on my computer. WOW. I kept meaning to ask you to tab the cabans to the wings.(Never mind) Looks great!!! May have to start cutting tonight.
CDRom powered I use an IPS c. That thing will hover with CD.
Thanks again
Lee
ldammann is offline Find More Posts by ldammann
Old Feb 23, 2005, 07:34 AM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Another note. The inner? depron on the center caban. I used a 3mm CF rod for the fuse so I used 3mm depron on the inner for a snug fit.
Lee
Old Feb 23, 2005, 06:59 PM
colbyweb is offline
Find More Posts by colbyweb
Why aren't you out flyin?
colbyweb's Avatar
Overland Park, Kansas, United States
Joined Mar 2004
That's cool. I didn't know exactly what you used but I have some 4mm and that's what I would use. The 1/4" fanfold or 6mm depron works pretty good with it so that's the way I drew it. The only problem if you change the thickness is that the slots will be too wide. Would you likeme to draw you up a wing with 3mm slots?
-Rick
colbyweb is offline Find More Posts by colbyweb
Old Feb 23, 2005, 09:53 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
No problem. I can adjust from there. The other thing I saw was the tabs on the outer struts don't match. I think if I cut between the two cutouts it comes out right.
Was racing tonight so haven't had a chance to look it over any more. I will build this weekend.
How do you like my new avitar?
Thanks again!
Lee
Old Feb 23, 2005, 10:14 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Hmm... the outer strut tabs do not match. I'll have to study that, I haven't noticed that.
That IS a cool avatar! Looks better than mine, I'm jealous!!
-Rick
Old Feb 23, 2005, 10:17 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Hmm, looks like I forgot to DRAW the tabs on the outer struts! Is that the problem you are talking about?
I'm going to go ahead and post the revised plan now, and whenever I get time to fix those tabs I'll re-upload them here,
So for everyone's information, this is the same plan as the other except that it uses a 3mm fuse stick and 3mm center cabane,
-Rick
Old Feb 23, 2005, 10:43 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
You know...
I'm thinking that with very little modification this little model would make a great 3D plane. Drop the undercamber, use flat plate wings... center the fuse stick between the wings.. that should do the trick. I may build one myself IF I can ever get caught up
-Rick
Old Feb 23, 2005, 10:51 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Oh yeah, here's something I noticed just today concerning the thickness of the center cabane. I decided to throw together a new version of my 3D Stik plane, because I had some ideas to lighten it up. I made a horizontal stab with 3mm depron and then made a second one from 1/4" blucor. Not certain I remember the exact measurements I got and I didn't write them down, but the blucor with the skin still on was only about .05 grams heavier than the 3mm depron. I then peeled the skin from both sides of the blucor stab and now it is about .05 grams LIGHTER than the 3mm depron. Now I'm wondering why I wasted a bunch of money on 3mm depron since it isn't gonna save any weight. Incidentally I bought a bunch of 2mm depron as well and can only see a few 10ths of a gram between 2mm and 3mm. I think blucor rules Just some food for thought for you
-Rick
Old Feb 24, 2005, 07:19 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Ditto...Blucor still the best ,I've tried ...
gpw is offline Find More Posts by gpw
Old Feb 24, 2005, 08:47 AM
Spy king is offline
Find More Posts by Spy king
Just "PLANE" crazy
Spy king's Avatar
Chennai, India
Joined Dec 2003
Its a real pity that it is avalible only in the places You people stay(
Spy king is offline Find More Posts by Spy king
Old Feb 24, 2005, 09:02 AM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Sure it is, you'd just have to order it from the US
There are at least a couple of online stores selling it by the sheet.
-Rick
Old Feb 24, 2005, 10:16 AM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Rick
You drew tabs on the outer struts, but they are singles and the wing has doubles like the center caban. It looks like if you make the slot on the wing using the ends of the two slots it would match?
Oh, and I used 2mm depron on the wings on the proto. Plenty strong in a bipe config.
Lee
Old Feb 24, 2005, 11:42 AM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Rick
If you want to try 3d with the x-tail, maybe on a plane like this?
http://www.rcgroups.com/forums/showthread.php?t=338173
Something like that should raise a few eyebrows
I do wonder what the x-tail would do for 3d. Should change some coupling issues good or bad.
Lee
Old Feb 24, 2005, 12:33 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Originally Posted by ldammann
Rick
I see what you mean now. I'll get that fixed
Lee
I think I knew that! I don't know why I put 3mm on the plan. But.... what if I told you that it was a waste of time and money to use 2mm depron? Check out the following chart that I made just this morning:
All sheets are 4 1/4" x 7 1/2". The "blue sheet" is a sheet I sliced
from a block of blue foam. The EPP is 1lb density. In my opinion
each of these materials are stiff enough for this model. The 6mm
derpon actually measures 5.7mm on my calipers. The ultrafoam
and tufflite are products sold by Troy Built Models. Both of these
products have a plastic skin on them. All measuements are made on
an almost new (2 weeks or so) scale.
2mm depron 3.4 grams
3mm depron 2.9 grams
3mm blue sheet 2.2 grams
5mm blucor (w/skin) 4.9 grams
5mm blucor (w/o skin) 3.7 grams
4mm EPP 2.2 grams
8mm EPP 3.5 grams
6mm depron 6.7 grams
5mm ultrafoam 5.2 grams
7mm tufflite 5.3 grams
After seeing this I have to wonder why I wasted my money on a carton of 2mm depron. Also, note that 6mm depron is the heaviest thing on the list.
-Rick
Old Feb 24, 2005, 12:48 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
I fixed the strut tab problem and re-uploaded them to post #66.
-Rick
Gym-Blu Simple Indoor Lightweight Stick Plane Gene Bond Foamies (Scratchbuilt) 777 Mar 23, 2016 11:56 AM
Question Gym-Blu video clips amigo Foamies (Scratchbuilt) 15 Oct 04, 2006 10:01 AM
