Old Jan 29, 2005, 08:29 PM
ldammann is offline
Find More Posts by ldammann
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Gym-Blu X2
Inspired by Gene Bond's Gym-Blu and his Quote "And surely, some nut will try a Bipe version "
20" x 7" wings, 2mm depron
CF tube fuse
X-tail, 3mm depron
4.8 oz AUW
incidence adjustable from 0 to 6 deg.
ldammann is offline Find More Posts by ldammann
Old Jan 29, 2005, 08:31 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
0 deg
Old Jan 29, 2005, 08:32 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
6 deg
Old Jan 30, 2005, 01:06 AM
colbyweb is offline
Find More Posts by colbyweb
Why aren't you out flyin?
colbyweb's Avatar
Overland Park, Kansas, United States
Joined Mar 2004
That is really cool! I had thought about doing a bipe stick plane but hadn't thought of running the stick through a central cabane like that. What a great idea!
-Rick
colbyweb is offline Find More Posts by colbyweb
Old Jan 30, 2005, 01:09 AM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Have you flown this thing yet? I'm wondering how well that X tail works. This thing is giving me a lot of new ideas .....
-Rick
Old Jan 30, 2005, 08:28 AM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Colby
I'm wondering about the tail also. Hope to find out today in a small gym.
Lee
Old Jan 30, 2005, 08:47 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I'm impressed! How are you fixing the stick in position on the wing?
It's all a lot of drag, but given enough power, it should fly nice and slow!
I think the tail will do fine, at least it does in my foggy head this morning (1st cup of coffee after a long indoor event last night)
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 30, 2005, 11:38 AM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Gene
I just put depron wedges in the back to hold an angle. Like this. Off to test fly. I'll try to get some bad vidio with my digital camera if it flys.
Old Jan 30, 2005, 08:03 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
It Flys!
And flys quite well. Learned something today that is an advantage of the X-tail.
Will try to post some bad AVI's if they aren't to big.
Old Jan 30, 2005, 08:06 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Nope, too big. Darn.
How small does an attachment have to be? They are between 1 and 2 meg.
How do you post a vid?
Old Jan 30, 2005, 09:15 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
I. Nice design, I haven't really ever cared for the v tail but the X- tail is very Sweeet.
You are another true craftsman, that put some design thought into that one. I'm envious of your Depron and would be interested to see you design some more. D.
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jan 30, 2005, 09:44 PM
meowmix is offline
Find More Posts by meowmix
You will be assimilated!
Caslte Rock, Colorado
Joined Apr 2004
So both sections of the x-tail move? Wow, that's cool. Great job.
To post your video you'll have to get it put it in the gallery, then link it here.
Eagerly awaiting!
meowmix is offline Find More Posts by meowmix
Old Jan 30, 2005, 10:00 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
How do I get them put in the gallery?
Old Jan 30, 2005, 10:25 PM
ldammann is offline
ldammann's Avatar
Oshkosh WI
Joined Mar 2004
Ok, I think I figured it out. Vids in my gallery. Sorry for the poor quality, its just a digital camera.
http://www.rcgroups.com/gallery/show...0&ppuser=29041
meowmix
Yes, both surfaces move. I think it helps keep the tail from twisting the CF tube I'm using. I built a standard v-tail Gym-Blu with the same CF tube and the tail twists so bad it won't turn right. I think with surfaces above and below the tube, instead of a larger surface all above the tube, it cuts down on the twist.
Or maybe I just don't know how to fly!
Old Jan 30, 2005, 10:43 PM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
Hmm, I've built 2 different sized stick planes using a carbon fiber tube fuse and they both fly awesome! What size carbon tube are you using? I built a small one of Gene Bond's BluStik with a 4mm carbon tube fuse, and a large 40" span stik using a 6mm carbon arrow shaft. Maybe your problem has to do with the foam flexing... you used 2mm depron on this one, what size foam did you use on the gym-blu? I built a gym-blu using 3mm sliced blue foam and it was too flimsy to fly. The wing warping was soo bad immediately after take off it would go crazy and snap into the ground.
-Rick
Gym-Blu Simple Indoor Lightweight Stick Plane Gene Bond Foamies (Scratchbuilt) 777 Mar 23, 2016 11:56 AM
Question Gym-Blu video clips amigo Foamies (Scratchbuilt) 15 Oct 04, 2006 10:01 AM
