Old Jan 29, 2005, 11:49 AM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Mystery - Are the Align "Carbon" blades really carbon??
Got my Align "Carbon" blades yesterday. It's a puzzle to me because they look like plastic that has been spray painted black. Once someone destroys one of these new blades, maybe we will find out what they are really made from. They also have the usual lightening holes like the wood blades from Align and this is something you don't see in CF blades as it takes a way a lot of the strength of the fiber weave pattern. Notice Align didn't use the words "Carbon Fiber" on these or any catalog postings. I suspect all the carbon may be in the paint ????? They are much stiffer than the 335mm woodies so they will serve a purpose, but they are not CF blades like ModelSport and SAB sell for sure. I'll be interested to see what others think about these "Carbon" blades. This might explain why they are so cheap when compared to CF blades.
Cheers - Boyd
AMA 80393
Major USAF
Retired
Hoverup is offline Find More Posts by Hoverup
Old Jan 29, 2005, 11:58 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
Cheers - Boyd
AMA 80393
Major USAF
Retired
If you look on the Align website, it says they are injection molded carbon...i.e. something similar to a plastic glow helicopter's frame material...plastic with fine fibers of carbon (not a weave) mixed in with the material.
Once I saw mention of this, I realized why they are much less expensive than the typical carbon fiber helicopter blades you see out there. The typical carbon blades are, essentially, hand made = high labor costs. The Align carbon blades are mass produced, hence the lower cost. Actually, considering how they're made, they should be only slightly higher in price compared to the stock plastic blades included in the kit! So they're actually very expensive!!!
ScotY is offline Find More Posts by ScotY
Old Jan 29, 2005, 12:21 PM
Guinea_Pig is offline
Find More Posts by Guinea_Pig
Mwahahahaha
Guinea_Pig's Avatar
UK, newbury
Joined Dec 2002
try shorting it out accross a 12V battery, i did this with a stock piccolo blade... it did get warm
Guinea_Pig is offline Find More Posts by Guinea_Pig
Old Jan 29, 2005, 12:22 PM
Heli-Mark is offline
Find More Posts by Heli-Mark
Heli-Mark's Avatar
Red Bank, NJ
Joined Jan 2005
yeah, they are carbon injected, but they seem like a decent deal considering your other options, they are much more rigid than the abs plastic and wooden blades and at $20 I think they fill a nice category between wood and real carbon fiber.
Mark
Heli-Mark is offline Find More Posts by Heli-Mark
Old Jan 29, 2005, 12:32 PM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
Mark
Yes, I agree...IF they work well. The material a blade is made from is not important. What is important is if it's rigid enough (in both the spanwise direction and in torsion) and how it's balanced (total weight, spanwise CG AND chordwise CG).
How well to they fly? I have been trying to find some...no luck so far.
Old Jan 29, 2005, 02:51 PM
Dartos is offline
Find More Posts by Dartos
Minneapolis,USA
Joined Sep 2004
I've had appx. six flights with my align cf blades on my stock(non-stretch) T-REX, flys great, good TR clearence, I've had several boom strikes with aligns 335 wood blades, I think the woodies have too much flex and are prone to boom strike.
Dartos is offline Find More Posts by Dartos
Old Jan 29, 2005, 03:27 PM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
Hello,
What kind of flying are you doing? Curious to know, for reference re. the performance of the Align carbon blades.
When were you seeing boom strikes with the 335mm wood blades? In flight boom strikes?
Old Feb 01, 2005, 11:08 PM
spit-boy is offline
Find More Posts by spit-boy
spit-boy's Avatar
CA
Joined Aug 2001
Mission Success!
Boyd -
To resolve this issue once and for all, I decided to do a science experiment to get to the bottom of this. It would take an accurate flight path for sure -I decided on a 20 degree descending approach, with a simultanious banking angle of about 80 degrees (blades almost vertical). This would ensure the best chance of a decent blade-to-ground contact at impact. Execution was perfect, and the results - well, this mission would have exceeded even the mars rovers success - not only did I snap and destroy the blades in multiple places - I even totalled the helicopter! What more could you ask for. The only unanticipated hiccup was that the broken blades dispersed widely into the long grass. A quick search soon retrieved the pieces, and I am now happy to report, that, on close examination, indeed there does appear to be evidence inside of round, blueberry-like carbon spheres. No wait - that's a severed round carbon rod going down the middle there. It also appears to have additional carbon in the leading and trailing edges, although some of it is hard to discern from the plastic moulding. I have now applied for additional funding from "headquarters" to continue this type of valuable research.
-Jonathan.
spit-boy is offline Find More Posts by spit-boy
Old Feb 01, 2005, 11:39 PM
cwkasper is offline
Find More Posts by cwkasper
Modding & Hovering
cwkasper's Avatar
North Texas
Joined Jan 2005
spit-boy,
...ROFL&G...
Chad
cwkasper is offline Find More Posts by cwkasper
Old Feb 01, 2005, 11:47 PM
Eric Cartman is offline
Find More Posts by Eric Cartman
Joined Sep 2004
cross section pics?
Eric Cartman is offline Find More Posts by Eric Cartman
Old Feb 02, 2005, 12:09 AM
elco is offline
Find More Posts by elco
Arcadia, CA
Joined Nov 2004
Here is another dissection: http://www.daddyhobby.com/forum/show...&threadid=3495
Cheers,
elco
elco is offline Find More Posts by elco
Old Feb 02, 2005, 04:42 AM
Hoverup is offline
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Originally Posted by spit-boy
Boyd -
-Jonathan.
Another victory for Wierd Science.
Cheers - Boyd
Old Feb 02, 2005, 11:12 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Hey guys... I'm an R&D chemist. If you want to know what's inside of them... send me a sample of a broken blade. (PM me for an address) I'll run thermal on the plastic, and do a burn off on what is left. If there is carbon in it... I'll find it. I can also run an IR on it to see what kind of plastic they are using.
Just an offer.
Dr Honda is offline Find More Posts by Dr Honda
Old Feb 02, 2005, 11:35 AM
Aobid is offline
Find More Posts by Aobid
Enjoying the good life!
Aobid's Avatar
Ashburn, Virginia
Joined Feb 2002
Just an offer.
Can I send you my wife instead???
Been wondering what's inside that head for YEARS now!
Aobid is offline Find More Posts by Aobid
Old Feb 02, 2005, 12:14 PM
jsn is offline
jsn
Find More Posts by jsn
jsn
Dis-member
jsn's Avatar
USA, VA, Ashburn
Joined Mar 2003
Must not make inside your wife joke........ must stay PG rated...
jsn is offline Find More Posts by jsn
Are flat bottom blades really better for learning? neuroblade Micro Helis 2 Aug 09, 2005 08:49 AM
Am i Crazy, I like the Align Carbon Blades for the Trex. dogon1013 Mini Helis 11 Apr 13, 2005 12:38 PM
Align Carbon Blades - tracking problems.. spit-boy Mini Helis 18 Feb 02, 2005 05:11 AM
Align carbon blades for T-Rex Steph280 Mini Helis 24 Dec 28, 2004 05:51 AM
How durable are carbon blades? KasperE Micro Helis 1 Aug 25, 2003 02:42 AM
