WV
Joined Feb 2004
I can't remember, did you ever say how you planned to stop that monster?
I've held off converting mine to nitro because I was worried about the gyro gears going. Signats had 4 or 5 gears melt using a brushless and I would expect the nitro to do similar damage. Speaking of Signats, I sent him an aluminum hub to mount his melted gear on but never heard back from him. My gyro replacement design changes the ratio from 1:6 to 1:4 in anticipation of greater wheel RPM with the nitro motor! ![]() And YES, lets see some video!!! |
Dave, Edwin's bikes stop by hitting immovable objects, or sometimes other moving objects that can't get out of the way quick enough. I think mine is the only nitro bike in our group that actually has brakes, which gives me a real advantage sometimes. But then, I've pulled a "Valentino" on his bike more than once myself. STeve B in NC |
I counld't figure out how i was going to stop it.I was going to make an aluminum brace that would rub against the clutch bell.But because of the momentom of the gyro and back wheel spinning.Probably would have stripped the spur gear or something.If i did front disc breaks then i'm pretty sure the front rim would'nt last to long. any suggestions will be greatful. Well i did go with the third option. Like Steve said LOL.
Napa, California
Joined Jan 2004
Edwin, Doesn't the gyro freewheel when the wheel begins to decelerate? Am I missing something? In other words, if you brake the clutch bell, you're really only slowing the wheel, while the gyro continues to spin. I think your clutch bell brake idea will work. Might try teflon on the clutch bell as it can take the heat, and will apply friction smoothly. mp- |
what needs to happen is that guy who started the nitro MX bike on CNR's reader's rides page, needs to just start making those dope_ass spoked wheels for sale!! And finish that bike!
I think that clutchbell brake would work too, if you have't burnt up the gyro gears by now, just letting it freewheel isn't gonna hurt them either. Just my 2cents! Tom |
Well i tried this little expiriment. I gave it full throttle till the gyro and wheel got up to speed. Then i tried to grab the back tire to feel force it would take to stop that back wheel. Let's just say i almost lost a finger.
LOL To top that all off i had previously drilled holes in the gyro to make it lighter.Boy that grab the back wheel technic......uuuuhh wasn't to smart.LOL |
WV
Joined Feb 2004
What about something like those "saturn" brakes that have been posted in another thread? If you could attach the rings to either side of the front wheel and have a front brake squeeze on them?
I'm still confused as to what part the gyro plays in braking the rear wheel. If the clutch shoes are working correctly, they should release the gyro wheel once the rear wheel starts to decelerate. I think... If the electric motor pinion can stop without tearing up the spur gear I would think the clutch bell brake should work ok. I'm planning to use a large one-way bearing in my new gyro design. It will end up being a bit longer than the current planetary gear box, but will also allow the use of either plastic or metal gears if they are needed. Dave. |
The gyro does freewheel when off-power, so it should not have any effect. The RC10-GT used a brake shoe directly on the clutch bell, so I don't think it would be a problem in a Ricky. Plus, if too much braking force were applied, the slipper around the spur assembly would rachet a bit until it slowed down. Might wear the slipper a bit, but that's kind of what it was designed for.
Of course, I'm assuming that you kept the slipper setup in your modifications, instead of directly mounting the spur to the layshaft. |
WV
Joined Feb 2004
Just wondering... Has anyone ever really seen that thing slip? I grabbed the inside piece with pliers and tried to force it to turn and couldn't. Maybe it works, but it would definitely take some force to get it to slip. I would think on a stock bike the belt would slip first - I'll have to pull mine apart and see if the chain has caused any wear inside... Dave. |
| Thread Tools | |
| Yippee! Ricky Carmichael dirt bike CNR parts! | signats | Motorcycles | 62 | Aug 28, 2009 06:31 PM |
| Parts for the Ricky Carmichael Bike - Finally... | dmincin | Motorcycles | 88 | Nov 26, 2005 09:07 PM |
| [pictures] Ricky Carmichael, BMX track, jumps, dirt, french mag | tom4 | Motorcycles | 20 | Nov 28, 2004 12:43 PM |
| Ricky Carmichael dirt bike for sale.... | reptileman | Motorcycles | 4 | Nov 19, 2004 08:13 AM |
| Nitro Dirt Bike...Do they exist???? | FireFlyer | Motorcycles | 15 | May 17, 2004 06:20 PM |
