Old Jan 29, 2005, 12:57 AM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
New Product
SimRaC - free plan for this great delta/canard
Please see the new SimRaC 3D v7: http://www.rcgroups.com/forums/showthread.php?t=1752080
(Just a note, this was NOT originally posted in the Foamy (Kits) section, I don't know how it got here. If a mod can move this thread to the Scratchbuilt section it would be appreciated. If not I'll post the v7.0 version as a new thread in the Scratchbuilt section.)
After myself and friends having had a huge amount of fun with this aircraft I've been persuaded to share the design.
It's basically a Simple Rafale-type Canard hence the name SimRaC
Main material: 6mm Depron and some balsa, Glue: hotmelt/5min epoxy/white woodglue
It's powered at the moment by a VL brushless motor (4 strands/0.5mm wire/8 turns) and a 1500mAh Polyquest 3S battery. Flight times are consistantly around 14 1/2 minutes indicating about a 6.5A average current draw yet it will accelerate vertically to a speck with the 6x4 APC prop it's using.
It doesn't stall - just mushes along, is very, very fast yet can slow up to a hover in a light breeze, landings are really easy - pancake technique with no forward speed or smooth and slow.
If using a performance motor don't leave out the balsa leading edge otherwise it goes so fast the whole wing starts to twist.
Glues used can be hotmelt (turn off the gun b4 it gets too hot - test on a scrap piece first), 5 min epoxy or white wood / cold glue
Just 2 servo's (elevon mixing) are required as the canards are static but the aircraft is very manouverable - doing the 'cobra' well!
C.G as indicated
enjoy
Graham
Nose high attitude for SLOW flight!
pardus is offline Find More Posts by pardus
Old Jan 29, 2005, 07:24 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Pard .... Thanks for sharing!!!!!!!!!! .... looks like a FUN little craft .....gotta' build one of these ....
gpw is offline Find More Posts by gpw
Old Jan 29, 2005, 11:05 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Thanks gpw, it really flies great with a remarkable variation of speeds and really simple/quick to build.
The plan has been altered a little from the photo's for a narrower tip chord, the plane on the photo's has had it's wing tips cut off to increase the roll rate (from 800mm to 650mm)
cheers
Graham
Old Jan 29, 2005, 12:52 PM
Iswald is offline
Find More Posts by Iswald
FLY FREE!!!!!!
South Africa
Joined Sep 2004
Ive seen this fly....Awsome!!!
Iswald is offline Find More Posts by Iswald
Old Jan 30, 2005, 12:17 AM
J.C. is offline
Find More Posts by J.C.
South Africa JHB
Joined Jun 2004
It flies very nicely....give it a try...well worth it
J.C. is offline Find More Posts by J.C.
Old Jan 30, 2005, 12:46 AM
colbyweb is offline
Find More Posts by colbyweb
Why aren't you out flyin?
colbyweb's Avatar
Overland Park, Kansas, United States
Joined Mar 2004
Looks like fun! Guess I'll have to give it a try as well
-Rick
colbyweb is offline Find More Posts by colbyweb
Old Feb 14, 2005, 08:07 AM
Merwin is offline
Find More Posts by Merwin
fly or build or fly or...
Merwin's Avatar
Altoona, PA
Joined Jul 2004
SimRaC Maiden!
Built and flew a SimRaC yesterday afternoon.
WOW, what a fun plane to fly!!! I did my
first ever rolls and inverted flight. Though this
is NOT a first trainer, my slow-flyer experience
was enough to allow me to have lots of fun!
It was a very easy to build. I built mine as a
profile to make a quicker build.
Looks great in the sky. Got lots of "wows" from
the guys. Several said it flew just like a jet.
Sorry, no pics. I built it yesterday andrushed out to fly
while still light. After the 5th crash, this one on the
pavement, it wasn't up to pictures. No motor, prop
or equipment damage!!!
Thanks, Graham, for a great design!!!! What a fun plane!
Merwin
http://flyDPF.com
Merwin is offline Find More Posts by Merwin
Old Feb 14, 2005, 10:04 PM
777 is offline
777
Find More Posts by 777
777
Bought at a price.
Winfield, Kansas, United States
Joined Jul 2002
I wonder how this would do on a regular brushed motor?
It's the kind of thing that I'm looking for as my next plane.
Brad
777 is offline Find More Posts by 777
Old Feb 15, 2005, 03:35 AM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Hi Brad
It should go fine on a 6v S400, gunther prop and 8 or 9 smallish cells. It won't be as punchy but will fly fine!
Increase the span by an inch or 2 if you like which'll offset the heavier motor/battery and make the spar a little wider.
Thanks Merwin, your postive compliments are appreciated. I have just finished construction of my 5th SimRaC with some optimization for speed and control.
Improvments include: balsa elevons, balsa false-trailing edge, mylar hinges (more postive control at speed), 3mm balsa fin, 1.5mm hard balsa canards (less drag), 4mm carbon spar recessed into wing (less drag), tapered tail towards motor mount (less drag), solarfilm covered wing surfaces (less drag) and carefully rounded all edges
wing loading = 22g/dm² or 7.2 oz/ft² !
thrust to weight = 460g:380g or 1.2:1 !
wing area = 17dm² or 264 in²
power ratio = 165W/lb or 361W/kg
Calculated level flight top speed = 102km/h or 63mph
Calculated Stall speed = < 21km/h or 13mph
Motocalc's opinion:
- With a wing loading of 34.4g/dm², a model of this size will have flying characteristics suited to the intermediate pilot, for use in calm to moderate wind conditions.
- The static thrust (429g) to weight (372g) ratio is 1.15:1, which will result in
extremely short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and vertical climb-outs. This model will probably be able to perform a hover or torque roll.
- At the best lift-to-drag ratio airspeed, the excess-thrust (309g) to weight (372g) ratio is 0.83:1, which will give very steep climbs and incredible acceleration. This model can easily do consecutive loops, and has sufficient in-flight thrust for any aerobatic maneuver.
some photo's of my ver. 5.2 below
also below, the updated dxf ver. 5.2 (zipped)
Old Feb 15, 2005, 04:11 PM
experimental_pil is offline
Find More Posts by experimental_pil
Toronto, Ontario
Joined Feb 2005
What program do I need to open dwg files?
Could someone turn this into a tiled PDF?
That would be great!!!
experimental_pil is offline Find More Posts by experimental_pil
Old Feb 16, 2005, 06:41 AM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
You need a cad program or cad viewing program. Here's a link to a free cad viewer: https://fastcad.com/n-view7.html
-Rick
Old Feb 16, 2005, 07:56 AM
Toronto, Ontario
Joined Feb 2005
colby,
Is that only a 2d CAD?
It would be great if someone could make a tiled PDF of this.
Old Feb 16, 2005, 10:18 AM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
colby,
Darned if I know...
I have Autocad and so I have no need for CAD viewers. I tried last night to make a pdf for you, and had no luck getting it sized correctly. I'm not sure what size paper it was drawn for, and everything I tried came out wrong. Get a hold of Gene Bond, he's a pro at this. If it can be done he can do it Maybe I'll send him a pm about it...
-Rick
Old Feb 16, 2005, 10:26 AM
colbyweb is offline
colbyweb's Avatar
Joined Mar 2004
I sent Gene an email about it, maybe he'll fix it up for you.
-Rick
Old Feb 16, 2005, 12:40 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Here's the best I could do... I hate some of the crap AutoCad or whatever does to files. Screws up life for the rest of us... Plug-ins should clean themselves up before a file is saved!
Could not do a full sheet pdf, since the sheet size used for the original is bigger than 45"... Some limit with my version of Adobe Acrobat, I suppose. Not too many folks have plotters bigger, anyway!
Also, here's a 'clean' dxf file, I hope. Should do fine from the free viewers and other CAD programs.
Gene Bond is offline Find More Posts by Gene Bond
Free plan for a nice AP plane. Big Brother. Lynxman Aerial Photography 9 Feb 21, 2007 11:46 AM
Whats the best easy built plan for this listing? hebele Electric Plane Talk 3 Jun 25, 2005 01:31 PM
Fly RC's Free Plan for the Race-E Scrambleon Parkflyers 3 Jan 05, 2005 08:40 PM
Question What plan for this setup?????? DeeKay105 3D Flying 17 Nov 07, 2004 12:12 PM
Cool Free plan for FAT3D rcmann 3D Flying 28 Jan 30, 2004 03:01 PM
