Old Feb 16, 2000, 06:00 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Kevin (Cox), can we tell 'em about our (yours - that you shared with me for the F16) secret?
Old Feb 16, 2000, 06:54 PM
Bf109G is offline
Find More Posts by Bf109G
Over-engineered
Bf109G's Avatar
Ridgecrest, CA
Joined Nov 1998
Please??
Bf109G is offline Find More Posts by Bf109G
Old Feb 16, 2000, 07:26 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
The suspence is killing me, what up wid dat?
GregG is offline Find More Posts by GregG
Old Feb 16, 2000, 08:38 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Hi gang,
It is no secret and not really any magic involved. It may involve a little copyright law breaking
First off I normally buy a plastic model or a decal sheet that matches the desired scheme. I know that this isn't always practical and some hand drawn, computer art, or pictures that you took at an Airshow will work. I scan the image into the PC and enlarge it in a paint program (Adobe, PC Paintbrush...etc.) You want to enlarge it enough so that you can rework the colors if need be. For example the scanned red may appear pink or purple, you would select red from your palette and repaint it. The more you zoom in and clean the image the better the results. Check your work by zooming out it will start to look really nice after a little touch-up.
When you are happy with the image save it and print it out, you will need to play with the size until it is right. Carefully cut the image out. Using 3M77 adhesive or whatever spray the BACK of the image. and position it on the model. At this point, you can LIGHTLY coat the dried image with clear paint. It is important to do it lightly or it may run and ruin the decal. This also seals the edges to the model to give it a more flush appearance. If you don't seal it with clear (gloss or flat) it will run when it gets wet. I have done everything from the Blues Angels to an A-10 sharkmouth with this method it is actually fun I don't think I would enter it in the Scale Masters or TOP GUN but I'm happy with it
Andy, step in at anytime and tell us if you added anything else to this procedure. Or if I left something out.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Feb 16, 2000, 09:12 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Thanks Kevin, sounds like a winner to me! Alot easier than I had thought. Keep up the good work!
Old Feb 16, 2000, 09:16 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You just left out the sanding of the back side of the paper until you're left with a really thin piece to stick on - helps keep the profile down. Also that it is best printed on the expensive InkJet paper = gives brighter colors, and is easier to sand to get it nice and thin. I ruined a couple, sanding thru the paper, but I just printed those ones again..
..a
Old Feb 16, 2000, 09:21 PM
Kevin Cox's Avatar
Joined Jan 1997
Oh yeah! That part DUH!
Thanks Andy!
Old Feb 17, 2000, 12:43 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
How do you make decals with a computer?
I remember reading in a magazine an article about printing your own decals from your computer. That's all I can remember, I have forgotten the specifics. I guess I never thought I might do it myself. Well here I am, I need to make a set to finish my Islander twin. I have already designed a page with the logo and numbers that I want. Anyone have any ideas?
Old Feb 17, 2000, 03:24 AM
Kromannschmidt is offline
Find More Posts by Kromannschmidt
copenhagen, denmark
Joined May 1999
Here is another way:
With my twinstar I got some pretty ok stickers (quite many) that you could decorate the plane with.
I also got a blank stickersheet - which went straight into my inkjet with excellent results..
This way I could print whatever I wanted on it and attach it to the plane..
I should think you could get these things commercially?
Have fun
Henrik
Kromannschmidt is offline Find More Posts by Kromannschmidt
Old Feb 17, 2000, 04:00 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Henrik, you got to it first! I have been looking for a little less expensive clear contact for the very same thing!
No glue no mess, and it doesn't have to be FUEL(FOOL)PROOF !
Fred Bronk is offline Find More Posts by Fred Bronk
Old Feb 17, 2000, 10:11 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Just one other little tip. The artwork samples that come with Corel Draw include most national aircraft markings as well as some squadron motifs. I used this to generate Australian Navy roundels for my Sea Fury and they were very effective and in the right colours.
I expect similar samples can be found in other drawing packages or somewhere on the www.
DaveSawers is offline Find More Posts by DaveSawers
Old Feb 17, 2000, 01:58 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Great ideas guys, Kromannschmidt, were would one find blank stickersheet. The local hobbyshop has no idea what this is. Are you from Europe, is this something common there? Do you have to use a laserjet printer or can you get by with a deskjet? I have a Canon BJC 4300 and it wont print on clear Monokote or clear packing tape.
Old Feb 17, 2000, 02:02 PM
Joined Oct 1999
Just head for your local computer store and look throught the different types of paper they have. Both HP and Epson make self adhesive sticky paper for inkjets.
One thing to watch though is that inkjet ink is not waterproof so you must overspray with clear varnish to prevent smear.
Old Feb 18, 2000, 03:21 PM
copenhagen, denmark
Joined May 1999
Greg...
Denmark/Copenhagen=Europe ;-)
Actually I have moved to Elsinore: There is something rotten in the state of denmark place.
If it was good enough for hamlet - it'll do for me..
Btw. Agree on the computer print sheets - you can get all kinds (including the sticky ones)..
Have a good weekend all
Henrik
Old Feb 18, 2000, 05:18 PM
Kevin Cox's Avatar
Joined Jan 1997
Yes, the sticky stuff works too. But the problem that I have with the stickyback sheets is the sticky stuff has a thicker profile when applied to the model. The high quaility paper method is a lot more work but worth in SOME cases. Also when you need to work around compound curves the sticky stuff will give you a hard time.
Good luck guys!
Help! How Do You Make A Plane With Pink Foam! Draven Foamies (Scratchbuilt) 41 Jan 05, 2007 04:57 PM
How do you make the decals less glossy? TMO GWS (Grand Wing Servo) 3 Jun 23, 2004 10:11 AM
How do you make your E-Tek packs with the new PCB? Parkflyer Batteries and Chargers 8 May 13, 2003 06:54 PM
how do you make Krylon glossy p471701 Electric Plane Talk 6 Oct 06, 2001 06:22 PM
How do you make channels in foam? Jim McPherson Foamies (Kits) 8 Sep 21, 2001 08:00 PM
