Old Jan 27, 2005, 12:43 AM
PrasadL is offline
Find More Posts by PrasadL
Believer in Technology!
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
Indoor plane from BladeRunner parts.
I did not buy BladeRunner until after Christmas because I thought it is another flying toy that never flies. Even finally the ever growing thread in this forum persuades me to take the plunge I was not too sure. So I justify my expenditure of $80 for a toy thinking I will make a 3ch proportional indoor plane from its components after its demise (few days I thought).
Now after 4 weeks later BR is proved to be the best toy I ever had and best $80 bucks I ever spend. Also I have learned to repair motors and make rotors; I know I can fly it as long as I want to. So I decided to publish the sketch of BR plane I never made for the benefit of some one not so fortunate and has BR parts. Thais may not be a workable idea I donít know because I never got to test it. Anyway here it is.
If you have more ideas or already made any planes from BR parts please post here. Thanks.
PrasadL is offline Find More Posts by PrasadL
Old Jan 27, 2005, 02:03 PM
talktodan is offline
Find More Posts by talktodan
Joined Dec 2004
good idea.. someone should try this
talktodan is offline Find More Posts by talktodan
Old Jan 27, 2005, 04:43 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
I believe it would be better to use the tail motor to control an elevator or replace the tail motor with a magnetic actuator driving an elevator.
There are some differentially controlled wings pictured on the AERONUTZ site.
http://www.aeronutz.flyer.co.uk/rcindoor.htm
A perfect application for the BR electronics.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jan 30, 2005, 09:34 PM
PrasadL is offline
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
I started developing my basic idea to workable model. Since I love my BR I wanted to make a plane from it without destroying it so I can revert back to original BR. This is the simple solution I come up with. Added weights are the weight of wings, tail fins and new landing gear. BRís two powerful N20 should be able to carry them easily. May be I might be able to shed weight by using M20s? Counter rotating props (size?) should give a perfect setup.
Old Jan 30, 2005, 10:25 PM
alan_gbk is offline
Find More Posts by alan_gbk
Alan
Malaysia
Looking forward for more information on this project
alan_gbk is offline Find More Posts by alan_gbk
Old Jan 31, 2005, 10:21 PM
Joined Dec 2004
one of my brushes went out.. thinking about doing it
Old Feb 02, 2005, 11:16 PM
Joined Dec 2004
i have a couple of motors a bit smaller than the br's that came out of a firefly knock-off... would these work, and what should the wing surfaces be made of?
Old Feb 03, 2005, 12:00 AM
PrasadL is offline
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
I was waiting for my BR to fail but it is going strong as ever. I donít have a heart to put it down. Sorry to hear about your BR but happy you have decided to do this.
BR original motors are way too powerful for a plane so you can use little smaller motors as long as they are low voltage. My BR without rotors and shaft weigh 1oz.
Measure total weight with your motors. Wing loading less than 3 oz/sq.ft is good.
2mm or 3mm Depron is the best material for wing I thank. If you donít have one buy a 2mm or 3mm foam board from Walmart and remove paper backing.
Old Feb 03, 2005, 04:41 AM
Steve Fehr is offline
Find More Posts by Steve Fehr
Steve Fehr's Avatar
Chesapeake, VA
Joined Sep 2001
How about a V-22 osprey using not only bladerunner parts, but bladerunner rotors? That'd be pretty kickin' rad!
Steve Fehr is offline Find More Posts by Steve Fehr
Old Feb 04, 2005, 09:50 AM
PrasadL is offline
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
WOW, that would be awesome!
I just discovered this thread http://www.rcgroups.com/forums/showthread.php?t=228235
If that can be done with BR parts
Old Feb 04, 2005, 12:14 PM
Steve Fehr's Avatar
Chesapeake, VA
Joined Sep 2001
The BR tail rotor might actually finally fix the gyroscopic pitch problems, too
Old Feb 04, 2005, 01:18 PM
Pete P. is offline
Find More Posts by Pete P.
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
You guys should check out the neat-o plane they have in the v-22 thread. Might work with the Bladerunner guts.
Pete P. is offline Find More Posts by Pete P.
Old Feb 07, 2005, 01:32 AM
PrasadL is offline
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
Flying BladeRunner V1
Most simple Mod. AUW 1.5oz, Wing area 80sqin, GWS3020 props.
Old Feb 07, 2005, 06:16 AM
Toronto Canada
Joined Dec 2002
PrasadL:
Great work !
How well does the tail motor work as an elevator ?
Old Feb 07, 2005, 11:38 AM
PrasadL is offline
PrasadL's Avatar
Kansas City, MO
Joined Aug 2004
Thanks, Works well on test stand. When suspended from CG, swing about 30 deg. up or down with full stick. Should do well I suppose during flight. Too windy outside and all indoor gyms occupied. Micro building is really frustrating. Had to wait days to test fly models sometimes!
Discussion indoor plane w/ bladerunner heli guts? craterking Scratchbuilt Indoor and Micro Models 2 Jun 11, 2006 05:25 PM
Discussion Whats your favorite plane from aa parts? rcoz89117 Scratchbuilt Indoor and Micro Models 9 Apr 15, 2006 12:32 AM
Micro Plane From Blimp Parts Rocketman1092 Scratchbuilt Indoor and Micro Models 8 Feb 21, 2005 09:38 AM
Question Best Indoor plane from GWS? shschon GWS (Grand Wing Servo) 3 Oct 23, 2004 01:35 AM
indoor fun fly type plane from japanese site guyaneze Scratchbuilt Indoor and Micro Models 19 Jan 04, 2004 02:15 PM
