Old Mar 05, 2005, 04:21 PM
scotta is offline
Find More Posts by scotta
Electric Orange
scotta's Avatar
Orange, Australia
Joined Jun 2004
Bryan,
I hope she does to. Is that an EO Cub hading on the wall??
Scott
www.electricorange.com.au
scotta is offline Find More Posts by scotta
Old Mar 05, 2005, 06:29 PM
bgabric is offline
Find More Posts by bgabric
jumping trees
bgabric's Avatar
keller tx
Joined Dec 2003
No, thats a foamfly stagger wing. However the EO cub is my next project.
Bryan
bgabric is offline Find More Posts by bgabric
Old Mar 05, 2005, 09:32 PM
migdestroyer999 is offline
Find More Posts by migdestroyer999
Cross Into The Blue
migdestroyer999's Avatar
SW Florida
Joined Aug 2004
What are you guys happier with- The EPS-350 C gearing with 9070 prop or EPS-350 B gearing with 8060 prop? I want to use the B since it draws less amps, and the small prop makes it look better and fly faster.
migdestroyer999 is offline Find More Posts by migdestroyer999
Old Mar 06, 2005, 04:10 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Dont steal my ideas!
Dont steal My Ideas! Just kidding I lve all these litlte kits! I have a webite
www.flatfoamflyers.com and I have a plane on my site that some will say looks like one on this thread well its my a scratch build ISP A version and since the cockpit worked out so nice on mine Im flatered that someone gave me credit on a thread and used it!
also check out this link http://www.flatfoamflyers.com/zero.html
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Mar 06, 2005, 09:01 AM
bgabric is offline
jumping trees
bgabric's Avatar
keller tx
Joined Dec 2003
I got to fly my black p40 today. and wow. I learned a lot. first off the rason it was having trounle with the loops is do to the elevator trying to hard to loop the airplane. the wings would warp under the load . so at 50% she flys great... just no on my 2 cells as my 700'd will not pump out enough juice. when i make V4 (some time from now, after i lose V3) I will add a counter balanced elevator, AKA thows tab that stick oun in front of the hinge point. also, im thinking of painting the bottom tho V3 orange and slaping my razor 400 on it . (is that leagle with your rules Irone???)
Bryan
Old Mar 06, 2005, 10:31 AM
irone is offline
Find More Posts by irone
irone's Avatar
Arlington, Texas
Joined Mar 2004
Bryan......... You may put anything you want on it. The only rule is 7.4V power supply. My planes like more speed. Most of us that know how are timing our 350 and 300's anyway. That is a much better way to improve performance other than using a 3 cell lipo. The motors will burn out but usually only after many, many flights. On my recommended set-up, all surface throws should not exceed 3/4" deflection in either direction.
irone is offline Find More Posts by irone
Old Mar 06, 2005, 10:45 AM
bgabric is offline
jumping trees
bgabric's Avatar
keller tx
Joined Dec 2003
very cool. I not fond of the 350. I have tested the rz-400 staticy and I think i will be happy with the thrust on 2 cells. just for fun I hooked it up to 3 cells and the moter jump mount and almost went through the wall so I orderd a new motor mound with better gears and I should be ready to fly on thursday the 17. as soon as i get a chance i will follow your advice and taper the leading edges and trailing edges. this thing is already fast thow.
Bryan
o and look at this
http://www.gws.com.tw/english/produc...ly/3dfw190.htm
Old Mar 06, 2005, 10:47 AM
tallflyer's Avatar
Joined Jul 2002
My Little Isp Zero powered with a GWS ISP A gear and spinning a gws 1047 prop will hover, pretty tough to do with no rudder control but on a new charged 2cell 7.4 volt 340mah lipo will go vertical do rolls and loops fly inverted do all kinds of neat tricks, plane is made of 3mm depron and is I bet half the weight of the planes listed here ( weight means spead) I made a bearcat a while ago using a LPS motor and it flew pretty well Im going to try making the p40 using 3mm and the same setup I have now and see how she flys stay tunned..
I just changed this post! I had listed the wrong prop!
Old Mar 06, 2005, 10:52 AM
tallflyer's Avatar
Joined Jul 2002
bgabric
The GWS is a 3D plane high torque a little lower speed does everytrick in the book!
Old Mar 06, 2005, 11:51 AM
tallflyer's Avatar
Joined Jul 2002
Ok Guys I have a great Idea
Here is a decal I made for the p40 I will make a complete set for wings and the front end gota have those teeth.
Tell me what you think!
Old Mar 07, 2005, 07:03 AM
bgabric is offline
jumping trees
bgabric's Avatar
keller tx
Joined Dec 2003
Looks really nice I will have to print some out soon.
Bryan
Old Mar 07, 2005, 07:36 AM
tallflyer's Avatar
Joined Jul 2002
Flight packs
Im working on putting together a Flight pack for these warbirds please tell me what you think!
I would also include a copy of the plan you wanted if you dont want to download it or dont have a printer.
All for around $99.00 + Shipping PM for details
Old Mar 07, 2005, 08:48 AM
irone is offline
irone's Avatar
Arlington, Texas
Joined Mar 2004
Tallflyer........ Go to a 10amp speed controller and a EPS "B" drive 4.43 to 1 ratio with a few 8060 props. This seems to be the best set-up for E-bat. The 10amp speeder will allow for motor tuning. The GWS motor will pull all 10amps when tuned right. The "B" drive gives faster prop speeds which prevent as many wrap-ups. Also a good idea is to place a fuse in line with the motor to prevent injury to the speed control if a wrap-up occures.
TopGun Combat Planes
http://members.ebay.com/ws/eBayISAPI...serid=brodiejf
Old Mar 07, 2005, 09:07 AM
Joe_Atlanta is offline
Find More Posts by Joe_Atlanta
this space available
Joe_Atlanta's Avatar
Atlanta, GA
Joined Dec 2004
It seems many of the newer 2 cell Lipos are actually putting out closer to 8.4 V (rated at 7.4 nominal). Indeed, some dealers are even advertising them at the higher rating (Foamfly.com) . Do you check packs?
Joe
Joe_Atlanta is offline Find More Posts by Joe_Atlanta
Old Mar 08, 2005, 01:50 AM
scotta is offline
Electric Orange
scotta's Avatar
Orange, Australia
Joined Jun 2004
Tallflyer,
Pre-printed graphics seem to be the trend now, Digitalset is setting the bar really high for full graphics for foamies. I have played a bit with it but he is doing a great job. Now only if there was a cheap way of making nice glossy stickers.
I like the idea of a flight pack.
Scott
Electric Orange P40 E-Combat Warbird RNAF Parkflyers 0 Jul 13, 2005 05:38 PM
Combat Electric vx Glow Combat Dezynco Sport Planes 22 Oct 10, 2004 11:46 PM
E-combat Build techniques highflier Combat 28 Mar 13, 2004 10:17 AM
Full Contact E-combat highflier Electric Plane Talk 9 May 22, 2003 05:54 PM
I need a new E combat wing, which one is the best? Ronbo Foamies (Kits) 0 May 11, 2002 04:02 PM
