Old Jul 08, 2011, 09:31 AM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
This Sunday, it will be the maiden flight of this P40. I am going to try the 5 gram brushless on this since the Airframe is only 25 grams. My target AUW is about 75 grams with 180mah 2S lipo.
mrexcel is offline Find More Posts by mrexcel
Old Jul 08, 2011, 11:23 AM
vtdiy is online now
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Should be quite a floater. Are you using 3mm foam instead of 5mm?
Looks like you are also using rudder instead of ailerons. That would also make a great indoor plane. Might build something similar for next winter flying up here. I also fly rubber powered models.
vtdiy is online now Find More Posts by vtdiy
Old Jul 08, 2011, 11:25 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
for sure. I am using 3mm foam.
This plane will be flown outdoor early morning when there is no winds.
Old Jul 09, 2011, 11:50 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Everything is ready for the maiden flight tomorrow. AUW is 80 grams and motor thrust data on HK says 90 grams pull for the 5 gram motor.
Old Jul 09, 2011, 03:23 PM
vtdiy is online now
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
That should do it, mrexcel!
I decided to give it another chance. I patched up my P-40 and added tape to the nose.I tried short test hops in a small field with very tall grass, and was able to get it trimmed right for hand launching.
Too much wind and too small space to really fly it more than a few seconds. But I hope to try again tomorrow morning in the large field, when there is less wind.
So there should be two of these P-40s flying on opposite sides of the planet tomorrow.
Old Jul 09, 2011, 06:50 PM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Bad weather here and won't be able to fly this morning. Do you know whether Electric Orange has got a Spitfire plans?
Old Jul 10, 2011, 03:47 PM
vtdiy is online now
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Sorry to hear about the weather. Flew mine last evening when the wind died, got some circuits in, but the wing folded where it had been creased and repaired. I started building a new one.
Re E.O. planes, no Spitfire, there were 4: P-51, P-40, Me109, and Zero.
He also did a built up foam J3 Cub, GeeBee Model D, and a foam version of the old Ugly Stick.
Old Jul 11, 2011, 07:09 AM
astronaut is offline
Find More Posts by astronaut
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
Awesome thread!
What potential do you think these builds have with dollar store readiboard foam? I don't have anything else unfortunately!
astronaut is offline Find More Posts by astronaut
Old Jul 11, 2011, 07:29 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
What thickness you have?
Old Jul 11, 2011, 07:35 AM
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
http://www.dollartree.com/teachers-s...6450/index.pro
this is exactly what I have (4.8mm it seems ... 3/16"). Many thanks!
They sell each sheet at my local dollar store for $1.25
Old Jul 11, 2011, 07:37 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
we called this here as "KT Boards". This is perfect for model planes
Old Jul 11, 2011, 07:40 AM
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
Really? Nice!
Do they come with a layer of paper on them too?
It just seems that once I take the paper off, the foam becomes a little weak (easily bends).
Maybe this is just me.
Thank you mrexcel
Old Jul 11, 2011, 07:41 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Its a kind of lamination we get here. Its not paper though.
Old Jul 11, 2011, 07:44 AM
Future Pilot
astronaut's Avatar
Canada
Joined Apr 2011
I see...
Alright, I will give it a try for sure! The paper makes it strong and rigid that is for sure, but it also makes it twice as heavy.
This seems like an easy plane to build so I will try different methods.
Will the brushed parkzone motor/gearbox work with these planes? That's all I have right now unfortunately. Thanks!
Old Jul 11, 2011, 07:46 AM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
to use brushed parkzone motors you will have to make the model very light. my model's airframe came to 25 grams.
Electric Orange P40 E-Combat Warbird RNAF Parkflyers 0 Jul 13, 2005 05:38 PM
Combat Electric vx Glow Combat Dezynco Sport Planes 22 Oct 10, 2004 11:46 PM
E-combat Build techniques highflier Combat 28 Mar 13, 2004 10:17 AM
Full Contact E-combat highflier Electric Plane Talk 9 May 22, 2003 05:54 PM
I need a new E combat wing, which one is the best? Ronbo Foamies (Kits) 0 May 11, 2002 04:02 PM
