I built a p-51, it looked great, but I was having some serious problems. I would be banked than I would give some elevator to pull throught the turn, and it would pitch up and hover, then fall out. I tried so many things, but I could not get it to go. I already trashed it in my failed attempts, including 1 split, and I mean split prop. I might try another design
Brian |
It was not the elevator. I believe it was yawing upwards when I was turned sideways, it flies well when it goes straight. I did check the CG and everything and it was right, I have no clue still yet as to what was going on. I was running e-tec 2 cell hp 1200, and a 350c with 9x7, 10x4.7 and 10x8 all with little succes, the 10x8 seems to be the best that I tried.
Brian |
80% mini P40
Here is my little but powerful P40.
Powered by J250 with 4x4 prop - (static test show 12 amps on a new motor) Weight without battery 4.7oz 22" wing 18" length Maiden today in not the best conditions, 10-15 mph winds with gust up to 20. I trimmed every thing for high winds and it flew straight and level until I had to turn and the wind just took it for a wild ride. Well no damages other than the naro servo coming loose. (pictures were taken after 2 small flights) Thank You to Scott and Iron for giving us ideas in combat flying. I just need to build a couple more and get some mini combat going. EDC |
Joined Mar 2005
Hi guys,
I'm getting ready to build the P51. I have a GWS 400 motor laying around that I am considering using. What do you think about this? Is this too heavy? I think the prop is a 10x6. Not sure when I will actually try to fly this. I am a total newby and am just getting pretty comfortable with the Slow Stick. But this stuff looks too cool to pass up. Let me know what you guys think of the motor/prop for this plane. I'll post pics and give reports whenever I actually think I'm ready to fly it. Thanks, Waff PS (edit) I will be using a 7 cell NiMH 750 mAH battery to start with. |
| Thread Tools | |
| Electric Orange P40 E-Combat Warbird | RNAF | Parkflyers | 0 | Jul 13, 2005 05:38 PM |
| Combat Electric vx Glow Combat | Dezynco | Sport Planes | 22 | Oct 10, 2004 11:46 PM |
| E-combat Build techniques | highflier | Combat Fuel Planes | 28 | Mar 13, 2004 10:17 AM |
| Full Contact E-combat | highflier | Electric Plane Talk | 9 | May 22, 2003 05:54 PM |
| I need a new E combat wing, which one is the best? | Ronbo | Foamies (Kits) | 0 | May 11, 2002 04:02 PM |
