Old Jan 25, 2005, 11:42 AM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
Quad-winged pager flyer
Here's a model that i have in construction. Its loosely based on an Armstrong-Whitworth FK.10 which had 4 wings.
I haven't finished the fuselage yet and i have yet to cover the last two wings or tail feathers. I did a test glide in its current state, (with no covered tail surfaces) and it flew very stable, despite the extra drag of this configuration.
The frame should weigh no more than 2.5 grams and expecting 2.2 grams. AUW could be 13 grams approx with one 145 mA cells (its all i have).
I have plans to add an extra removable wing if needed to reduce wing loading for slower flight. I hope its OK!
snakeX2 is offline Find More Posts by snakeX2
Old Jan 25, 2005, 11:46 AM
micromad is offline
Find More Posts by micromad
The ceiling is the limit!
micromad's Avatar
South of England
Joined Aug 2004
Wow that looks good. What did you cover it with?
micromad is offline Find More Posts by micromad
Old Jan 25, 2005, 12:08 PM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Good old food bags. Not the lightest of materials, but the lightest 'free' material you can find. I will use about 0.5 grams on this model (so maybe 2.2 gram airframe/wings)
Old Jan 25, 2005, 12:13 PM
micromad is offline
micromad's Avatar
South of England
Joined Aug 2004
What did you use to stick it to the frame?
Old Jan 25, 2005, 12:23 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Looks good. Hope it flies well. Nice to see all those reference tables taped to your wall.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jan 25, 2005, 12:34 PM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Always come in handy sir !
Micromad, i used a gluestick applied to the frame, then applied the covering and used some more glue underneath the sticks so the overlap could be tacked on. Cheers,
James,
Old Jan 25, 2005, 01:30 PM
Whacky is offline
Find More Posts by Whacky
Netherlands
Joined Jan 2005
James,
snakeX2, looks great.
Please forgive my ignorance but what is a gluestick, what glue is it.
I had the same idea using these bags as i have no source for mylar but CA would not slick to it!
Thanks.
Whacky is offline Find More Posts by Whacky
Old Jan 25, 2005, 02:40 PM
micromad is offline
micromad's Avatar
South of England
Joined Aug 2004
You can get glue sticks here:http://www.whsmith.co.uk/WHS/Go.asp?...9810826&DB=320
Thanks James for the info
Alex
Old Jan 25, 2005, 03:06 PM
Whacky is offline
Netherlands
Joined Jan 2005
using Pritt on this??? this stuf cant even stick 2 pieces of paper together
Thanks for the info.
Old Jan 25, 2005, 03:29 PM
vagarach is offline
Find More Posts by vagarach
Canada
Now I really wonder who orders Pritt over the internet, unless they live in an exceptionally remote area of the world.
vagarach is offline Find More Posts by vagarach
Old Jan 25, 2005, 03:42 PM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Whacky, with the correct aplied amount of glue (pritt stick) you should get a desent hold but only enough to keep it stuck weakly, thats why you should wrap it around and stuck again. WHS sell the official pritt stick, which is no better than most other types.
Old Jan 27, 2005, 10:19 AM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Hi guys. Construction is nearing end, but i have a little problem about the undercarridge; I want to install some but i want to keep the weight to minimal. What light weight undercarridge could i make, with wheels that could weigh next to nothing? I have CF but the weight of mine seem to come at 0.2/0.3 grams. I also expect hard landings and CF is probably a must but the fuse may suffer damge. I have another idea to have a separate lightweight cart that the quad rests on, the cart it self will travel along the 'runway' with the model and the model will take off without it. Of course i am going to try both. Cheers anyone for help.
Old Jan 27, 2005, 10:58 AM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
Try half moon hoops of carbon fiber. .010 to .020 max.
Greg
gbarc is offline Find More Posts by gbarc
Old Jan 28, 2005, 12:37 AM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Nice looking plane so far.
Do you have any links to photos of the Armstrong-Whitworth FK.10?
Billy
billystiltner is offline Find More Posts by billystiltner
Old Jan 28, 2005, 08:54 AM
Whacky is offline
Netherlands
Joined Jan 2005
Hi SnakeX2,
I have found something that will stick the Foodbags to te wood and is realy powerfull is also from Pritt, it is a small roller with doublesided tape in it.
It is used for photos, paper, glass etc. i tried a piece of balsa and a litte foodbag and it sticks like hell, it's also posible to take it off and put it back on (the bag) to correct it or to replace it when damaged.
Greats Whacky.
