Old Jan 24, 2005, 01:47 PM
paul747 is offline
Find More Posts by paul747
Joined Jun 2004
lipo for space scooter 2 cell or 3 cell?
Anyone out there use lipos in there space scooter? if so what do u use a 2 cell 1500 or a 3cell 1500? What brand TP kokam or a Multiplex lipo?
paul747 is offline Find More Posts by paul747
Old Jan 24, 2005, 03:25 PM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
Use TP2100 3S
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Jan 24, 2005, 03:55 PM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
I use a 3s 1900mah 10c TP, a 3s 1800 12c CBP, and 2000mah 3s 15c kokam . With a mega 16-15-6, APC 8 X 6E. Goes straight up!
Rick
RickAvery is offline Find More Posts by RickAvery
Old Jan 25, 2005, 01:01 AM
paul747 is offline
Joined Jun 2004
what about stock motor could i use 3 cells 1200 or 1500 without killing the motor?I dont want to go past 1500 they cost way to much hell 40 bucks is to much but 70 to 80 bucks is just insane for a battery.I am looking to use a Great Planes 3 cell 1200 would that do the job in the scooter without doing harm to the batts or the motor?
Old Jan 25, 2005, 08:17 AM
Moorpark, Ca.
Joined Apr 2004
Paul,
It's not the mah thats going to kill the motor, it's the 11.1v. You will shorten the life of the motor if you were to run at WOT the whole time. A stock 400 can motor on 11.1v will probably pull around 12amps. A little high for it but if you throttle back just a little for some of the flight it should take some abuse and will have a marked increase in performance. At $10.00 these motors are cheap so run em until they die then stick another one in there. Should be fun. Also, the lower mah LiPos are usually a bit lighter, so you'll get more power & less weight. The best of all worlds!
Rick
Old Jan 25, 2005, 12:52 PM
paul747 is offline
Joined Jun 2004
Sounds good to me i'll give it a try.
Thanks for the info.
Paul
Old Feb 06, 2005, 02:47 PM
matthewh is offline
Find More Posts by matthewh
Kansas
Joined Jan 2005
I have seen in several pictures the foam around the motor on the Scooter melting. The Space Scooter has an air inlet on the side of the nose for motor cooling. Has anyone added a scoop to this to improve cooling when running over 8.4v? If so how/what did you use for a scoop?
Matthew
matthewh is offline Find More Posts by matthewh
Question AA or 2/3A for Space Scooter ragtimer Foamies (Kits) 2 Oct 23, 2006 10:27 PM
Took bad 3 cell lipo and made into a good 2 cell Waldo Pepper Batteries and Chargers 4 Jun 29, 2005 06:18 AM
Question Which new Himax outrunner (2208) would be best for a Shockie on 2 cell. EdMan Power Systems 7 Nov 08, 2004 11:22 AM
Any good inline/plana/inner driven GB for 2.5 or 3.0 ratio? Magna Power Systems 0 Oct 27, 2004 12:26 AM
Question Which Hi-max for Formosa using 2-cell Lipoly pack? Gatorfan Power Systems 16 Jan 14, 2004 08:59 AM
