Seattle area
Joined Jun 2004
Low cost home-brew UBEC
I thought I would share a recent discovery at Radio Shack: 273-1863 9-Volt Vehicle DC-to-DC Adapter. Good for 1000mA, and 12-24 volt input. http://www.radioshack.com/product.as...%5Fid=273-1863
My 1oz wireless video camera needs 9V @ 270mA, and running off of 3 lipo cells means I need a regulator for the camera. KoolFlightSystems will do custom voltages of their UBEC, but they have a two week turn around, and the 2.5A capacity is overkill just for the 0.27A camera. The RS 273-1863 is based on the MC34063A switching voltage regulator, so it should be much more efficient than a simple custom solution based on the 78xx series regulator (of which 9V is not a standard part). The adapter can handle up to 7S lipo too, maybe more as the MC part is actually rated around 30V. The board is single sided, with some surface mount components on the bottom/copper side, but quite easy to adjust for other voltages once someone reverses the circuit. Also, I tested (no load) down to 9V input. From 9.4 to 24 volts it has a constant 9.35V output. Below 9.4 volts, it tracks to the input voltage -0.1.The board removed from lighter plug case and without cables weighs only 11 grams. After cables and heatshrink wrap it will be about 21 grams. Compare to a 9.6V 170mAH square battery and connector at 49 grams and only 15 minutes of video. One thing I have not tested yet is the effect on the video signal with a switcher supply, but don't expect any adverse noise from it - if so it is an easy fix. I will test that tomorrow. -Gerry |
I found Qualcomm "Rapid Charger" cellphone chargers at one of these stores, and similar Belkin and Samsung chargers at another. Your mileage may vary...these stores sell surplus and discount merchandise, and stocks vary constantly. -Flieslikeabeagle |
Seattle area
Joined Jun 2004
Cyb, it easily adapts to 5V with just a resistor pair swap. See the MC34063A data sheet such as here: http://www.ortodoxism.ro/datasheets/aic/MC34063ACN.pdf
"Home-brew" didn't intend to mean all custom - sometimes goal is to spend a few $ to save many hours of time. Certainly I could have done a custom schematic/layout/board for this. But having done this a lot in the distant past I would have learned little. Yes, often times, single unit retail electronics parts are pricey. I think of it as object oriented construction. ![]() I have been using KoolFlightSystems UBECs in my 6S EDF planes with great success. However the onboard 2.5 GHz wireless video camera needs 9V at 270mA. Efficiency: at 9.3V, 0.27A (2.51W) output load, it was drawing 0.20A +/-0.05 @12.1V, which seems fine with me. As long as it won't be 0.27A at 20V as with a linear solution. -Gerry |
gfcermak wrote:
After all, the Beatles had "Eight days a week" back in the 1960's! ![]() http://www.beatlefans.com/lyrics/eight_days_a_week.htm -Flieslikeabeagle |
Gerry and others,
We have a 9V, 1.7A BEC designed for powering cameras, lights, and other accessories. Ours is smaller and probably lighter than the Radio Shack unit you have, and it was designed with model aircraft in mind. The details for the 9V BEC are here: http://www.medusaproducts.com/Other/...-BEC-35020.htm Regards, MRI |
| Thread Tools | |
| My first Home Brew Low Winger flies !!!!! | sajeev | Foamies (Kits) | 8 | Jul 18, 2005 06:18 AM |
| hotliner on a low cost power system ? | oded mazor | Electric Sailplanes | 12 | May 07, 2002 03:42 PM |
| Low cost opportunity for cells | sjslhill | Aircraft - Electric - Airplanes (FS/W) | 4 | Dec 19, 2001 11:42 AM |
| Opportunity for low cost.... | sjslhill | Aircraft - Electric - Airplanes (FS/W) | 0 | Nov 29, 2001 01:06 PM |
| Home brew bee | K Ho | Electric Plane Talk | 0 | May 03, 2001 08:17 AM |
