Old Jan 23, 2005, 08:44 PM
trident58 is online now
Find More Posts by trident58
trident58's Avatar
granada hills. Ca
Joined Nov 2004
Dymond Take it Easy upgrade
About a month ago, during the torrential downpour in So. California, I decided to see if I could put some life back into my old Dymond Take it Easy electric glider. In its stock form, the TIE was an absolute dog, taking about 2 minutes to get to 400 feet. You also had to spend about 20 minutes between flights waiting for the motor to cool down. I pulled out the stock motor and replaced it with a Maxx Products 05 cobalt motor (6 wind) and a Graupner 8/4.5 CAM folder (HL sells an adaptor so the cam prop fits the 4 mm shaft on the motor). Total cost, about $95. Tested it out yesterday- rate of climb just about tripled, much longer motor run time on the same battery (1900SCR 7 cell), and the average flight, in almost dead air, was about 25 minutes. That relatively cheap upgrade actually made that thing fun to fly!
trident58 is online now Find More Posts by trident58
Old Jan 24, 2005, 04:50 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
WOW - that is a pretty heafty upgrade - Rloose, by flying buddy, has a TIE -and he's the one that finally convinced me to go with a gearbox. His little 480 adn 3.33 gb climbs like mad on only 8 cells. Not a bad investment for that kind of increase in power. Have fun with it -
Fly'em High
JimNM
JimNM is offline Find More Posts by JimNM
Old Jan 24, 2005, 07:34 AM
trident58's Avatar
granada hills. Ca
Joined Nov 2004
Yeah, I've been thinking about adding a gearbox too, but since I just finished my Cumic+ (AXI 2820/10, 12x8, 8 1950FAUP's), I've been happy with keeping the TIE as a beater plane for spur-of-the-moment flying sessions. Can't see myself investing any more money into it. It's definetly served its purpose!
Old Jan 24, 2005, 09:00 AM
rloose is offline
Find More Posts by rloose
ORGAN MOUNTAIN AIR FORCE
rloose's Avatar
Organ, New Mexico
Joined Sep 2002
Decalage
Trident-
I'm not sure how to spell it or pronounce it, but it is the relative angle between the plane of the wings and the plane of the horizontal stabilizer. Dymond sells several sailplanes with the same fuse as the TIE. This fuse has a BIG relative angle between wings and horizontal stab...take a close look.
I don't know WHY Dymond put in so much, but you might want to experiment with reducing it. You can shim up the trailing edge of the wing or...... I finallly did radical surgery on the fuse and removed around 3/16 " from the front of the wing saddle, making the wing and horizontal stab much closer to parallel. I still have a little relative up on the leading edge of the wing.
Result: the plane is much more stable, no porpoise behavior, floats forever and seems to climb faster with same motor/prop/gearbox. The dive test makes more sense now too.
Rich
rloose is offline Find More Posts by rloose
Old Jan 24, 2005, 09:12 AM
trident58's Avatar
granada hills. Ca
Joined Nov 2004
You know, I have noticed the plane has a tendency to balloon upwards when power is applied. I've been really lazy as far as modifying incidence, decalage, etc., so I would launch the plane with some down trim, and then retrim when I shut off the motor. A minor hassle, but after hearing what you did, I might just put a small shim under the trailing edge- should have the same effect. Not sure I want to slice any more plastic off the fuselage-it seems pretty flimsy. Forgot to mention one other mod I made- I lengthened the rudder by about 1/2". Did this by putting a little slit in the back of the rudder, and then inserting a piece of 1/32" ply. This has greatly improved the turning ability.
Jon
Old Jan 24, 2005, 09:51 AM
rloose is offline
rloose's Avatar
Organ, New Mexico
Joined Sep 2002
More Rudder
Hey Jon-
Thanks for the hint, I could use more rudder. You are right about the fuse being flimsy. I had to put a cross brace in the middle of the opening after the radical fusectomy. This makes getting the battery in or out difficult. I am currently running a 'Racing Devils' 3S1P 3000mAh Lipoly. I get 1/2 hour flights with lots of zooming around. I love it!
Rich
Protech Alpha and Topic, aka Dymond Take it Easy and Flipper? Ron D Electric Sailplanes 2 Mar 21, 2004 10:16 PM
FS: Dymond Take it Easy/Easy Lift…. MiniMaxFlyer Aircraft - Sailplanes (FS/W) 1 Jul 22, 2003 01:39 PM
FS: Dymond Take it Easy/Easy Lift…. MiniMaxFlyer Aircraft - Electric - Airplanes (FS/W) 1 Jul 22, 2003 01:36 PM
Ebay: Dymond Take it Easy Electric Glider PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 0 Aug 04, 2002 11:48 AM
Need advise with RC-DYMOND'S TAKE IT EASY... tnsfrk Electric Sailplanes 10 Feb 27, 2002 07:12 PM
