Old Mar 12, 2002, 07:35 PM
Crasher is offline
Find More Posts by Crasher
Crasher's Avatar
Joined Mar 2002
RFS-100 isn't working for me?
Just soildered two 110mah batteries together and leads... plugged them into the correct places and did the same with the motor leads (trimmed them to fit snugly into the sockets) then fired up my radio (hitec laser 4) and tried to move the throttle and nothing. Touched the motor leads to the batteries and it worked.
WTF is up?
Chris
Crasher is offline Find More Posts by Crasher
Old Mar 12, 2002, 07:50 PM
dhurd is offline
Find More Posts by dhurd
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Chris,
Did you hook up an antenna? If you didn't the reciever doesn't receive a thing. However, the motor should do a quick run upon initialization of the software. Are you getting that? If not let me know and I will make sure my dad cross ships you a new receiver.
Sincerely,
Dan
dhurd is offline Find More Posts by dhurd
Old Mar 12, 2002, 07:54 PM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
Hey! glad to see you responded so quickly. I have no antenna connected since I'm not sure which wire it is or does it matter? blue? yellow? srip a little off and plug in? and no...the motor doesn't spin at all.
Maybe my batteries are too dead? They hardly spin the motor but I'm charging them now.
Chris
Old Mar 12, 2002, 09:32 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Crasher
I think you solved your own problem. When charged you will also hear the actuators play a tune, rx antenna or no.
Keith
KeithK is offline Find More Posts by KeithK
Old Mar 12, 2002, 11:12 PM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
Nope...charged and still nothing . The actuators aren't plugged in(or built) so nothing from them...
So Dan, what next? anything else to check?
Old Mar 12, 2002, 11:31 PM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
Well my order was:
Edward King
12272 Tangerine Blvd, 33412
West Palm beach, FL
I'm off to bed guys! maybe I'll finish my lil skeeter this weekend.
Chris
Old Mar 13, 2002, 05:48 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Chris,
My RFFS100 would work without the antenna in place for operating the actuators. But, when the motor was hooked up the speed control was erratic until I plugged an antenna into the plug in the center of the unit (that's the one for the antenna). I tried mine first with actuators (I have a couple of BIRD's) and only after everything else was hooked up did I move to running a motor.
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 13, 2002, 06:20 AM
dhurd is offline
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Chris,
We should be able to cross ship you one either today or tomorrow. Please return the defective receiver when you get the new one.
Regards,
Dan
Old Mar 13, 2002, 07:35 AM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
Sounds great Dan . Does this happen a lot with these units? I know to be light you have to remove most of the safty parts of the chip.
Chris
Old Mar 13, 2002, 07:48 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Have you checked the voltage at the receiver power terminals? Might be worth a quick check. Check the crystal is firmly inserted. Test you tranny with a normal rx.
Just a thought or two.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Mar 13, 2002, 08:13 AM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
I can't check the voltage . The TX works fine with my Feather thats in my Piccolo. so...I guess something is wrong.
Old Mar 13, 2002, 08:28 AM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
How do you guys charge a two cell pack?
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Mar 13, 2002, 09:01 AM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
If you have a charger that will only go down to 4 cells, try putting 2 packs in series and charge like a 4 cell pack.
Philip
fill is offline Find More Posts by fill
Old Mar 13, 2002, 09:25 AM
Crasher is offline
Crasher's Avatar
Joined Mar 2002
Philip
Ya, I thought of that also. I'm using my hitec CG330 and charging one at a time.
dhurd is offline
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Chris,
We have come across a few receivers that have had problems. We suspect ESD from the place that populates the boards. We are now checking all receivers that are going out (eventually we are going to have the populating place do the testing BEFORE they send them to us).
Sorry for any inconvienence
Regards,
Dan
Question Search isn't working for me Al P Site Suggestions / Complaints 2 Jan 02, 2007 05:54 AM
Chat not working for me Greg McFadden Site Chat 1 Apr 26, 2004 07:36 AM
Help! my new setup isn't working....... lightbarguy Micro Helis 4 Jan 18, 2004 10:42 AM
Throttle isn't working properly with Berg 4 DSP Wings Radios 5 Sep 02, 2003 08:24 PM
not working for me either! I am checking - is it working now? aeropenguin Parkflyers 13 Apr 26, 2003 07:38 PM
