Old Jan 23, 2005, 03:53 PM
Airbuzz is offline
Find More Posts by Airbuzz
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
3,5meter depron A380 :D
I have now started the assembly of my scale 1:22,3 Airbus A380 in depron.
Wingspan will be ca 3,5meter, I'll fill in more data later. I have started assembling the center section in a rig.
Airbuzz is offline Find More Posts by Airbuzz
Old Jan 23, 2005, 03:55 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
more pics of body assembly.
CRAZYPILOT is offline
Find More Posts by CRAZYPILOT
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
COOL.
Kenneth
CRAZYPILOT is offline Find More Posts by CRAZYPILOT
Old Jan 23, 2005, 03:56 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
this is how the body cross-section will look, with both floors inside.
Old Jan 23, 2005, 04:08 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
OOOOooooohhhhhhh AAAaaaahhhh, seriously your a masochist...
She is going to be big...
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 23, 2005, 05:31 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
yup.
Old Jan 24, 2005, 04:47 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Fy f...
you are really pushing the limits... I really wish you all the best for this one!
And it's gonna be a biggie
Subscribed!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Jan 24, 2005, 05:30 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
thank's Ben_E, I really look forward to fly this one, it's gonna be MASSIVE!! it will fly really slow with this enormous wing! I'm allso going to use a microcontroller for the gear, mainly because there's now way my Futaba radio can cope with all the functions needed for the gear retraction, handling the doors and retraction of the 5 struts. The advantage of useing a PIC microcontroller is that it's quite simple to use with RC-stuff like connecting servos, reading rx-signals, programming sequences and so forth. That will make a nice effekt as I can make the gears move in a scalelike speed and sequence.
Old Jan 24, 2005, 05:36 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
What about propulsion... 4xSp600 dd with Gunters?
Ben_E
Old Jan 24, 2005, 07:35 PM
Ado is offline
Ado
Find More Posts by Ado
Ado
Meow?
Ado's Avatar
Brisbane Intl, Australia
Joined Sep 2001
your insane
Ado is offline Find More Posts by Ado
Old Jan 24, 2005, 08:16 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
Im not sure what propulsion I'll use, it depends on what the final weight will be, I hope to have the monster under 4kg flying. One thing I do know for sure Ado, is that yes I am insane. What really made me kick off this project now is that my friend found a good stuff to make a nice layer on the depron with, I don't remember what it's called, but after aplying maby 2 thin layers of that stuff you get a really nice surface and it's possible to use any spray on top without damaging the depron. It's allso waterbased and low weight so it's perfect for this, easy to aply with airbrush to get thin layers, I'll check what that stuff is called, think it was meant for floors. I did most of the planning for this project many month ago, but I didn't want to start before I had a method of getting a nice finish, than all the hard work feels more worth it.
Old Jan 24, 2005, 08:31 PM
Ado is offline
Ado
Ado
Meow?
Ado's Avatar
Joined Sep 2001
I still got that Caribou there... hehe will get it done eventually :P
You're doing good work so far!
wish I had the say enthusiasm(sp?) as you
Old Jan 24, 2005, 08:54 PM
Neil Walker is offline
Find More Posts by Neil Walker
Texas Ranger
Neil Walker's Avatar
USA, CA, San Francisco
Joined Aug 2004
Awesome, quite a challenging project you've taken on and it looks like you're being really meticulous about it too! Are you going to try to re-create the wings as close to scale as possible? The 380 sure has very cool-looking wings... almost gull-wing like at the root with a crazy twist in them (major washout on the whole wing), and then the wingtip sails at the ends. I wonder how sensitive that wing design is, or is a visual "close enough" going to work? I guess washout makes sense on an airliner that's really designed to fly well at only one speed...
Looking forward to seeing how this turns out!
Neil Walker is offline Find More Posts by Neil Walker
Old Jan 24, 2005, 09:07 PM
Airbuzz is offline
Olle
Airbuzz's Avatar
Stockholm, Sweden
Joined Jun 2004
I'll do everything as close to scale as possible, the wing will be scale-like with all what you mentioned, the very high alpha at the root is actually very good in a model because it improves low-speed/high-alpha characteristics very much. I guess the gull-like shape of the wings is partly due to the fact that they need to get those huge engines of the ground. They have near the same diameter as a MD80 airliners body!! More construction pics comming tomorrow!
Old Jan 25, 2005, 12:32 AM
Igwe Aneke is offline
Find More Posts by Igwe Aneke
Igwe Aneke's Avatar
Netherlands
Joined Jul 2003
Damn...you're an airliner-god Airbuzz...you really are.
Igwe Aneke is offline Find More Posts by Igwe Aneke
WTB: 3.45-meter Full D-Box Graphite Wing Sled Driver Aircraft - Sailplanes (FS/W) 0 Apr 23, 2004 08:24 PM
For Sale FS 3 mm Depron CMT1961 Aircraft - Electric - Airplanes (FS/W) 0 Jan 07, 2003 08:30 PM
3 mm depron rcnutt Foamies (Kits) 8 Oct 27, 2002 07:37 AM
