Napa, California
Joined Jan 2004
I looked at the bike I have, but the battery is long gone. As far as choosing which cell to use, I would look for a cell that has decent capacity, and has a size that stacks up well to use the space under the bike. I was looking at my ER last night, there really is a lot of space on the bottom, and tons of ground clearance. If you have a digital camera, please post some pics of your project! mp- |
Joined Jan 2005
I have a buddy that is into R/C and also photography so when I get all the info I fill I need I will start putting this thing together. I'm still undecided about what to use to power it. Brushless or a high performance 380 with a good Speedo. Maybe a Novak spy?
I race off-road 1/10. Team Losi XXX, XXX-4GP,XXX-TMF2 and a XXX-NTAD so I have my hands full but when I get this project going I will be sure to post some pix's. This is the exact same battery that comes with the kits, http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXT316 The capacity is low for what I'm use to but I've read cycles get better run time than cars? I'm still looking at lipos too. Thunder power has lots of different sizes so we shall see........................... Nate |
you can make a battery pack that's just about the same size as that from the new GP 1100mah cells for longer runtime www.blindbatts.com |
This cell sounds like not so bad.
"**NEW** GP's extreme high output 2/3A cell. This is a 30+ amp cell in a small package. If you are looking for a good 10-20 amp cell for a lower price tag consider our CBP-1150 2/3A instead." http://www.unipros.com/cbpsite/loose...ssion_id=51280 |
Rijswijk The Netherlands
Joined Mar 2004
Nate,
Nice to hear that there are still some ER's. I have mine since 1982 i think, stil use it besides my HOR. I have 2 ER's, not mint in the box anymore but ....... they still dive. There are 2 versions, 1 is for 5 cell's,6 volts, side by side, the 2e is for 6 cell's 7,2 volts normal stickpack that you use in your off-road. The only difference is that the batteryholder, rearswingarm and chain are longer. I will try to make some time to make some pics. Good luck with your project. Rob |
