Old Jan 21, 2005, 07:32 PM
seancorder is offline
Find More Posts by seancorder
Joined May 2003
How do you know what is too fast
I get concerned sometimes while flying around that the headspead on my raptor 30 is too high.
What are some indication that you are spinning the blades too fast?
Sean Corder
seancorder is offline Find More Posts by seancorder
Old Jan 21, 2005, 09:59 PM
speeddemon281 is offline
Find More Posts by speeddemon281
Food For The Maggots
speeddemon281's Avatar
New Waverly,Texas
Joined May 2004
Dude,A High head speed is a good thing.
Although,If it is to high then you can put to much stress on your blades,and can lead to weakend blade ends,which leads to blades breaking off the rotor head.
On my raptor,I have my headspeed to around 2780rpm.
If you do decide to go higher,Get some wood blades,and get some 20min Slo-cure epoxy and put a coat on the end of each blade to where it attaches to the rotor head.spread the epoxy about 4-5 inches of the end of the blade.This is good for about 2850-3000 rpm.
Here is a example:
speeddemon281 is offline Find More Posts by speeddemon281
Old Jan 21, 2005, 11:09 PM
j911brick is offline
Find More Posts by j911brick
j911brick's Avatar
Republic of Texas
Joined Jun 2004
Sean Corder
I'm still a rookie, but I was advised last week that 1,700-1,800 rpm; 1,900 for 3d. I was at over 2,000 and the guy just about had a fit. He had a opticle meter where he could measure the rpm from a distance. At about 1,700 the heli was a little easire to handle. I was also warned about running wood blades too fast. If a blade comes off the the heli basically explodes. You'll learn to hear when its about right.
james
j911brick is offline Find More Posts by j911brick
Old Jan 22, 2005, 03:50 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Even the guys dragging don't get much above 2K. And non use woodys for gosh sakes!
Smaller helis can handle more HS than larger. And Larger helis can fly well with a lower HS to boot.
Sure higher HS will be more stable, but is it worth your life?
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 22, 2005, 06:00 AM
Charlie06 is offline
Find More Posts by Charlie06
Charlie06's Avatar
New Brunswick, Canada
Joined Nov 2002
Are you kidding? I think you better check your numbers again.
My Gallery
Charlie06 is offline Find More Posts by Charlie06
Old Jan 22, 2005, 09:19 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
I can see my T-rex or Shogun swining 300mm blades at 2700 rpms (and that's still fast)... but I wouldn't get close to a set of +600mm blades going that fast.
on a .30 sized heli... 1800 to 2000 rpm is about right. lower speed will make it less responsive, which is good if you are still learing.
Find some one local to you to help you get the throttle and pitch curves set properly.
Dr Honda is offline Find More Posts by Dr Honda
Old Jan 22, 2005, 11:49 AM
melvonnar is offline
Find More Posts by melvonnar
Joined Jun 2004
Please someone tell me that---On my raptor,I have my headspeed to around 2780rpm.
--this was a mistake
melvonnar is offline Find More Posts by melvonnar
Old Jan 23, 2005, 01:38 PM
New Waverly,Texas
Joined May 2004
Whoops,re-did it and got it 1897rpm..Lol i dont know how my meter read 2780.
Old Jan 24, 2005, 08:47 AM
Joined May 2003
It seems that the heli makes a strange noise when I have them spinning at a higher speed.... With in OS.32 how easy is it to get "too fast"? Perhaps I should not worry about it at all?
How do you know what scale your car is tycofreak Electric Power Cars 1 May 01, 2005 12:54 AM
How do you know what servos to buy for a plane? FlyingMist Beginner Training Area (Aircraft-Electric) 8 May 22, 2004 08:39 AM
Using a winch: how do you know when to release? tempest411 Thermal 35 Dec 10, 2003 08:14 PM
How do you know if your ESC is fried? Tres Wright Parkflyers 3 May 16, 2002 10:19 AM
How do you know when a battery is low? Phoenix-IT Electric Heli Talk 8 Jan 26, 2002 01:24 PM
